His Divine ShadowMedlem sedan sep. 20002 748 inlägg
Lyckades med tråd problemet ändå, men nu har jag problem med paging, jag får det inte att funka...
Nån som vet hur man kan koppla en paging kod till detta script?
Det som torde vara det viktiga är väl rsThreads:
Set rsThreads = DB.Execute ("SELECT * FROM Posts WHERE ForumID = '" & ForumID & "' AND status = '1' ORDER BY Date DESC")
Som borde användas för pagingen, men jag vet inte hur jag ska bygga in paging här...
<!-- #INCLUDE FILE="config.inc" -->
<HTML>
<HEAD>
<TITLE>Discussion Forum : by Manas Tungare</TITLE>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1">
<LINK REL="stylesheet" HREF="forum.css">
</HEAD>
<Message BGCOLOR="#FFFFFF" LEFTMARGIN="0" TOPMARGIN="0" MARGINWIDTH="0" MARGINHEIGHT="0">
Public Sub treeMessage_Build(MessageID, Level)
Dim rsPosts
Set rsPosts = DB.Execute ("SELECT * FROM Posts WHERE ForumID = '"& Request.QueryString("ForumID") &"' ORDER BY Date ASC")
rsPosts.Filter = "MessageID = " & MessageID
<img src="images/threader.jpg" width="<%= Level * 20 %>" height="2"> <font face="arial,tahoma" size="2">
<img src="images/arrows/<%=rsPosts("Status")%>.jpg"> <a href="Message.asp?ID=<%=rsPosts("MessageID")%>" target="Message">
<%=rsPosts("Subject")%>
</a> - <%=rsPosts("Author")%> <font face="arial,tahoma" size="1" color="<% if datediff("h",Date,now()) < 24 then %>Blue<%ELSE%>Red<%END IF%>">(<%=rsPosts("Date")%> )</font>
<br>
rsPosts.Filter = "Parent = " & MessageID
If Not (rsPosts.EOF And rsPosts.BOF) Then
rsPosts.MoveFirst
While Not rsPosts.EOF
treeMessage_Build rsPosts("MessageID"), Level+1
rsPosts.MoveNext
Wend
End Sub
If Request ("ForumID") = "" Then
' We don't have a valid ForumID, so go back to the main page.
response.Redirect("thread.asp?ForumID=1")
Dim ForumID
ForumID = Request("ForumID")
Dim DB, rsForum, rsPosts, rsThreads
Set DB = Connect (ForumMDB)
Set rsForum = DB.Execute ("SELECT * FROM Forums WHERE ForumID = " & ForumID)
Set rsPosts = DB.Execute ("SELECT * FROM Posts WHERE ForumID = '" & ForumID & "' ORDER BY Date ASC")
If rsThreads.BOF And rsThreads.EOF Then
ShowError ("<P ALIGN=""center"">There are no Posts in this forum.<br><A HREF=""post.asp?ForumID="& ForumID &"&Status=1"" target=""Message""><img border=""0"" SRC=""images/newpost.jpg""></A></P>")
Else
rsThreads.MoveFirst
<table width="100%">
<tr>
<td>
<font face="arial,tahoma" size="2"><b>
<%=rsForum("Forum")%>
</b></font>
<br>
<%=rsForum("Description")%>
</font>
</td>
<td align="right" width="12%">
<A HREF="post.asp?ForumID=<%=ForumID%>&Status=1" target="Message"><img border="0" SRC="images/newpost.jpg"></A>
</td>
</tr>
</table>
<br>
While Not rsThreads.EOF
treeMessage_Build rsThreads("MessageID"), 0
rsThreads.MoveNext
Wend
<% End If %>
</HTML>
Sprit löser inga problem. Men det gör inte mjölk heller.
T-bird 1200; GeForce 256 32MB; WinNT4/XP; 512MB RAM; Dialup
[Redigerat av His Divine Shadow den 06 feb 2002]
Här så är koden som jag tänkte lägga in, men som tyvärr inte funkar.
Tack i förväg om nån vet hur detta ska pusslas ihop, har försökt i flera dagar utan framgång.
<!--#include file="../connect.asp"-->
Dim objConn
Dim strConnString
Dim strSQL
Dim objRS
Dim strName
Dim strComment
Dim dteDate
Dim intPageSize
Dim intPage
Dim intTotalPages
Dim intRecordCount
'## -- connection string, vilken provider och db ska användas --
'## -- hur många inlägg ska visas per sida --
intPageSize = 15
'## -- vilken sida ska visas --
intPage = Request.QueryString("page")
<html>
<body>
<center>
<font face="Verdana" size="2">Results for: <b>
<%=searchTerm%>
</b></font>
<br>
If intPage = "" Then intPage = 1
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.Open connection
strSQL = "SELECT * from quotes where "& what &" LIKE '%"& replace(searchTerm,"'","''") &"%' ORDER BY Subcategory ASC"
'## -- skapa ett recordset --
Set objRS = Server.CreateObject("ADODB.Recordset")
'## -- hur många poster ska visas per sida --
objRS.PageSize = intPageSize
'## -- öppna och hämta alla records --
objRS.Open strSQL, objConn, 3, 1
If objRS.EOF Then
Response.Write "<br>No results matched your query.<br><br>"
Else
'## -- vilken sida i recordset uppdelningen ska visas --
objRS.AbsolutePage = intPage
'## -- hur många sidor finns i recordset uppdelningen --
intTotalPages = objRS.PageCount
'## -- lista alla inlägg som finns i db --
Do Until objRS.EOF or intRecordCount >= intPageSize
intRecordCount = intRecordCount + 1
strName = objRS(1)
strComment = objRS(2)
dteDate = objRS(3)
HÄR BORDE KODEN SOM VISAR SIDAN KOMMA
objRS.MoveNext
Loop
'## -- clean up --
objRS.Close
Set objRS = Nothing
objConn.Close
Set objConn = Nothing
'## -- visa sidnavigeringen --
'## -- intPage = vilken sida som ska visas --
'## -- intTotalPages = hur många sidor som recordsetet är uppdelat i --
Call PageNavigation(intPage, intTotalPages)
</html>
'## -- skapa sid-navigering --
Sub PageNavigation(ByVal WichPage, ByVal HowManyPages)
Dim strScriptName
Dim I
'## -- vilken sida ska navigeringen länka till --
strScriptName = Request.ServerVariables("SCRIPT_NAME")
'## -- visa föregående, länkat eller olänkat beroende på vilken sida som visas --
If CInt(WichPage) > 1 Then %>
<A href="<%=strScriptName%>?page=<%=WichPage - 1%>&forumID=<%=forumID%>">
<font face="Verdana" size="1"><< Previous</A>
<%Else
Response.Write "<font face=""Verdana"" size=""1""><< Previous "
'## -- lista ut alla sidnummer --
For I = 1 To HowManyPages
If CInt(WichPage) <> I Then %>
<A href="<%=strScriptName%>?page=<%=I%>&forumID=<%=forumID%>"><font face="Verdana" size="1">
<%=I%></A>
Else
[ <B>
<%=I%>
</B>]</font>
Next
'## -- visa Nästa, länkad eller olänkad beroende på vilken sida som visas --
If CInt(WichPage) < CInt(HowManyPages) Then %>
<A href="<%=strScriptName%>?page=<%=WichPage + 1%>&forumID=<%=forumID%>">
<font face="Verdana" size="1">Next >></A>
Else%>
<%End If
End Sub
set objRS= nothing
set objConn = nothing
</font>
VideMedlem sedan dec. 19996 094 inlägg
Vad är det som inte fungerar?
Kunskap är makt, dessvärre är inte makt kunskap
Jag önskar jag kunde ge en bättre bild, jag har bara dessa två skilda koder nu, innan hadde jag lyckats få ihop dom så att dom någorlunda funkade, men då tappade jag det.
Det skulle ha varit mycket enklare om jag hadde denna kod kvar, så kanske ni kunnat se var jag gick fel, annars nu, så undrar jag hur jag kombinerar dessa två koder.
PatrikBMedlem sedan mars 20002 713 inlägg
Vad är det som blir fel?
cya,
PatrikB
-=* IF there is a wrong way to do something, then someone will do it *=-
OK, nu har jag koden kombinerad, men det funkar fortfarande inte.
Ni kan se det här, jag har temporärt läggt upp forumet här: http://www.uniimport.fi/forum/
Här är koden som inte funkar:
Response.Buffer = True
Response.Expires = -1000
Const ForumMDB = "/db/forum.mdb"
Public Sub ShowError(Err)
If CStr(Err) <> "" Then
Response.Write "<P CLASS=""Error"">" + CStr(Err) + "</P>"
End Sub
Function Connect (Path2DB)
Dim DB
Set DB = Server.CreateObject("ADODB.Connection")
DB.Mode = adModeReadWrite 'Since we will be adding entries.
DB.Open ("PROVIDER=Microsoft.Jet.OLEDB.4.0;DATA SOURCE=" + Server.MapPath(Path2DB))
Set Connect = DB
End Function
' Function Escape() replaces single-quotes with a pair of single-quotes.
' Otherwise we face problems inserting it into SQL statements.
Function Escape(sz)
Escape = Replace(sz, "'", "''")
End Function
' Function ShortData() formats a given Data as a nice-looking
' small string of the format:
' DD MMM, YYYY.
Public Function ShortDate(dtDate)
If Not IsNull (dtDate) Then
ShortDate = Day(dtDate) & " " & Left(MonthName (Month(dtDate)), 3) & ", " & Year(dtDate)
Else
ShortDate = dtDate
End Function
<HTML>
<HEAD>
</HEAD>
Dim rsPosts
<br>
rsPosts.MoveFirst
rsPosts.MoveNext
Wend
End Sub
Dim objConn
Dim strConnString
Dim strSQL
Dim objRS
Dim strName
Dim strComment
Dim dteDate
Dim intPageSize
Dim intPage
Dim intTotalPages
Dim intRecordCount
intPageSize = 2
ForumID = request.QueryString("ForumID")
objConn.Open forum
strSQL = "SELECT * FROM Posts WHERE ForumID = '" & ForumID & "' AND status = '1' ORDER BY Date DESC"
If objRS.EOF Then
Else
strName = objRS(1)
dteDate = objRS(3)
Dim ForumID
Else
rsThreads.MoveFirst
<tr>
<td>
</b></font>
<br>
</font>
</td>
</td>
</tr>
</table>
<br>
rsThreads.MoveNext
Wend
<% End If %>
objRS.MoveNext
Loop
'## -- clean up --
objRS.Close
Set objRS = Nothing
objConn.Close
</HTML>
Dim strScriptName
Dim I
<A href="<%=strScriptName%>?page=<%=WichPage - 1%>&forumID=<%=forumID%>"><font face="Verdana" size="1">
<< Previous</A>
<%Else
<%=I%></A>
Else
[ <B>
<%=I%>
</B>]</font>
Next
<A href="<%=strScriptName%>?page=<%=WichPage + 1%>&forumID=<%=forumID%>"><font face="Verdana" size="1">
Next >></A>
Else%>
<%End If
End Sub
set objRS= nothing
%></HTML>
eh, va lite mycket att gå igenom ... du skulle inte kunna "fimpa" allt irrelevant HTML-kod som bara stökar till det.
En annan sak. Hur såg din grundkod ut innan du försökte att göra en paging?
Det ser ut som du har lagt till ett recordset för att sköta pagingen vilket blir lite knas. Det du skall göra är att modifiera rsThreads recordsetet till paging.
cya,
PatrikB
[Redigerat av PatrikB den 07 feb 2002]
Kan ju Pröva, problemet är ju att jag inte fattar ditt som datt gällandes detta, det torde ju bli enklare om man kopierade in koden i det program man använder.
Hmm, prövade göra som du förslog och voilá det funkar, thx very much.
Om nån är intresserad får ni nog använda denna kod om ni vill ha en såndär "rekursiv tråd kod" ;)
Den funkar fin-fint.
... och lite kod skulle vi nog vilja se ... eller andra som har haft/har problem med liknande
cya,
PatrikB
