Typblandningsfel i vilkorsuttryck
16 svar · 462 visningar · startad av Mika3l
Hejsan!
Jag ska lägga in en ny produkt i databasen shop.mdb.
Men, jag får felmeddelandet
Microsoft OLE DB Provider for ODBC Drivers (0x80040E07)
[Microsoft][Drivrutin för ODBC Microsoft Access] Typblandningsfel i villkorsuttryck.
/test/mystore/admin/addprod.asp, line 331
addprod.asp
Set Upload = Server.CreateObject("Persits.Upload")
Upload.SaveVirtual("../images")
Set File = Upload.Files("bild")
kat = Trim(Upload.Form("kat"))
namn = Trim(Upload.Form("namn"))
pris = Trim(Upload.Form("pris"))
falt1 = Trim(Upload.Form("falt1"))
falt2 = Trim(Upload.Form("falt2"))
falt3 = Trim(Upload.Form("falt3"))
falt4 = Trim(Upload.Form("falt4"))
falt5 = Trim(Upload.Form("falt5"))
falt6 = Trim(Upload.Form("falt6"))
falt7 = Trim(Upload.Form("falt7"))
falt8 = Trim(Upload.Form("falt8"))
falt9 = Trim(Upload.Form("falt9"))
falt10 = Trim(Upload.Form("falt10"))
falt11 = Trim(Upload.Form("falt11"))
falt12 = Trim(Upload.Form("falt12"))
falt13 = Trim(Upload.Form("falt13"))
falt14 = Trim(Upload.Form("falt14"))
falt15 = Trim(Upload.Form("falt15"))
sfalt1 = Trim(Upload.Form("sfalt1"))
sfalt2 = Trim(Upload.Form("sfalt2"))
sfalt3 = Trim(Upload.Form("sfalt3"))
sfalt4 = Trim(Upload.Form("sfalt4"))
sfalt5 = Trim(Upload.Form("sfalt5"))
sfalt6 = Trim(Upload.Form("sfalt6"))
sfalt7 = Trim(Upload.Form("sfalt7"))
sfalt8 = Trim(Upload.Form("sfalt8"))
sfalt9 = Trim(Upload.Form("sfalt9"))
sfalt10 = Trim(Upload.Form("sfalt10"))
sfalt11 = Trim(Upload.Form("sfalt11"))
sfalt12 = Trim(Upload.Form("sfalt12"))
sfalt13 = Trim(Upload.Form("sfalt13"))
sfalt14 = Trim(Upload.Form("sfalt14"))
sfalt15 = Trim(Upload.Form("sfalt15"))
ovrigt = Trim(Upload.Form("ovrigt"))
bild = File.Filename
lank1 = Trim(Upload.Form("lank1"))
lank2 = Trim(Upload.Form("lank2"))
lank3 = Trim(Upload.Form("lank3"))
lank4 = Trim(Upload.Form("lank4"))
lank5 = Trim(Upload.Form("lank5"))
status = Trim(Upload.Form("status"))
SQL = "INSERT INTO produkter(kat, namn, pris, falt1, falt2, falt3, falt4, falt5, falt6, " & _
" falt7, falt8, falt9, falt10, falt11, falt12, falt13, falt14, falt15, sfalt1, sfalt2, " & _
" sfalt3, sfalt4, sfalt5, sfalt6, sfalt7, sfalt8, sfalt9, sfalt10, sfalt11, sfalt12, sfalt13, " & _
" sfalt14, sfalt15, ovrigt, bild, lank1, lank2, lank3, lank4, lank5, status) " & _
" VALUES('" & kat & "','" & namn & "','" & pris & "','" & falt1 & "','" & falt2 & "','" & falt3 & _
"','" & falt4 & "','" & falt5 & "','" & falt6 & "','" & falt7 & "','" & falt8 & "','" & falt9 & _
"','" & falt10 & "','" & falt11 & "','" & falt12 & "','" & falt13 & "','" & falt14 & "','" & falt15 & _
"','" & sfalt1 & "','" & sfalt2 & "','" & sfalt3 & "','" & sfalt4 & "','" & sfalt5 & _
"','" & sfalt6 & "','" & sfalt7 & "','" & sfalt8 & "','" & sfalt9 & "','" & sfalt10 & "','" & sfalt11 & _
"','" & sfalt12 & "','" & sfalt13 & "','" & sfalt14 & "','" & sfalt15 & "','" & ovrigt & "','" & bild & _
"','" & lank1 & "','" & lank2 & "','" & lank3 & "','" & lank4 & _
"','" & lank5 & "','" & status & "')"
Connection.Execute(SQL)[/red]
Response.Redirect"addprod.asp?page=done&namn=" & namn & ""
Rad 331 är "blåad".
Eftersom det är Connection.Execute(SQL) så är ju felet på någon av raderna över i SQL uttrycket, är det någon med skarpa ögon som kan se felet?
LarsG :OO :e
/Mika3l
Det stora datatestet:
Ok, då börjar vi!
För att börja testet tryck alt+F4.
MK-Studios v2!
Medlem sedan feb. 20012 412 inlägg
"','" & sfalt1 & "','" & sfalt2 & "','" & sfalt3 & "','" & sfalt4 & "',[b]'" & sfalt5 [/b]& _
"','" & sfalt6 & "','" & sfalt7 & "','" & sfalt8 & "','" & sfalt9 & "','" & sfalt10 & "',[b]'" & sfalt11 [/b]& _
"','" & lank1 & "','" & lank2 & "','" & lank3 & "',[b]'" & lank4 [/b] & _
På markerade ställen är det fel, du måse avsluta raden med " och börja den nya med " när du använder _
hajar du?
Vänligen Jörgen :)
[Redigerat av jorgen den 07 feb 2002]
Aha!
Ska kolla om det fungerar....
/Mika3l
Ok, då börjar vi!
MK-Studios v2!
Generellt bör det se ut så här:
"rad 1" & _
"rad2" & _
"rad3"
Vänligen Jörgen :)
Nej, det fungerar inte.
"' finns på raden under ;)
/Mika3l
Ok, då börjar vi!
MK-Studios v2!
Jo, jag såg det. Men raden måste avslutas (med ") fast du använder _ och sedan påbörjas igen (med ").
Vänligen Jörgen :)
Jag måste göra så för annars får det inte plats i Anteckningar ;)
Jag får prova att skriva rad för rad...
Återkommer nog snart! ;)
/Mika3l
Ok, då börjar vi!
MK-Studios v2!
" VALUES('" & kat & "','" & namn & "','" & pris & "', " & _
" '" & falt1 & "','" & falt2 & "','" & falt3 & "','" & falt4 & "', " & _
" '" & falt5 & "','" & falt6 & "','" & falt7 & "','" & falt8 & "', " & _
" '" & falt9 & "','" & falt10 & "','" & falt11 & "','" & falt12 & "', " & _
" '" & falt13 & "','" & falt14 & "','" & falt15 & "','" & sfalt1 & "', " & _
" '" & sfalt2 & "','" & sfalt3 & "','" & sfalt4 & "','" & sfalt5 & "', " & _
" '" & sfalt6 & "','" & sfalt7 & "','" & sfalt8 & "','" & sfalt9 & "', " & _
" '" & sfalt10 & "','" & sfalt11 & "','" & sfalt12 & "','" & sfalt13 & "', " & _
" '" & sfalt14 & "','" & sfalt15 & "','" & ovrigt & "','" & bild & "', " & _
" '" & lank1 & "','" & lank2 & "','" & lank3 & "','" & lank4 & "', " & _
" '" & lank5 & "','" & status & "')"
Vänligen Jörgen :)
Jag ska kolla på koden när jag kommer hem.
Sitter i skolan nu :p
Tackar!
/Mika3l
Ok, då börjar vi!
MK-Studios v2!
Hmmm...
Jag får samma jobbiga felmeddelande iallafall :l
SQL = "INSERT INTO produkter(kat, namn, pris, falt1, falt2, falt3, falt4, falt5, falt6, falt7, falt8, falt9, falt10, falt11, falt12, falt13, falt14, falt15, sfalt1, sfalt2, sfalt3, sfalt4, sfalt5, sfalt6, sfalt7, sfalt8, sfalt9, sfalt10, sfalt11, sfalt12, sfalt13, sfalt14, sfalt15, ovrigt, bild, lank1, lank2, lank3, lank4, lank5, status) "&_
Connection.Execute(SQL) är "problemraden".
/Mika3l
Ok, då börjar vi!
MK-Studios v2!
[Redigerat av Mika3l den 08 feb 2002]
Vad har du för datatyp på dina fält då?
webForum har stängt 15-17/2 för uppgradering.
Medlem sedan jan. 200262 inlägg
kör en
response.write(Sql)
response.end
innan execute,då är det lättare att se vad som är fel i sql-satsen.
PID | Autonumber(Primarykey)
kat | Text
pris | Number
falt1 - falt15 | text
sfalt1 - sfalt15 | text
ovrigt | text
bild | text
lank1 - lank5 | text
status | Yes/No
Ska prova med Response.Write.
/Mika3l
Ok, då börjar vi!
MK-Studios v2!
Får denna text när jag kör Response.Write:
INSERT INTO produkter(kat, namn, pris, falt1, falt2, falt3, falt4, falt5, falt6, falt7, falt8, falt9, falt10, falt11, falt12, falt13, falt14, falt15, sfalt1, sfalt2, sfalt3, sfalt4, sfalt5, sfalt6, sfalt7, sfalt8, sfalt9, sfalt10, sfalt11, sfalt12, sfalt13, sfalt14, sfalt15, ovrigt, bild, lank1, lank2, lank3, lank4, lank5, status) VALUES('CPU','AMD Athlon XP 1600+','1699', 'Hastighet:','Bus hastighet:','','', '','','','', '','','','', '','','','1400Mhz', '266Mhz','','','', '','','','', '','','','', '','','En riktigt bra processor från AMD! Kräver dock ganska mycket kylning...','win2000.gif', 'http://www.amd.com','http://','http://','http://', 'http://','True')
/Mika3l
Ok, då börjar vi!
MK-Studios v2!
Om pris är ett numeriskt fält skall du inte ha apostrofer runt det värdet.
Hur det är med yes/no-fält vet jag inte då jag inte använder access, men det kan nog vara så att den vill ha true/false utan apostrofer.
mvh,
Du har så rätt med pris!
Dumma mig...
Ska kolla på Yes/No fältet, är själv lite osäker på det...
Återkommer strax!
/Mika3l
Ok, då börjar vi!
MK-Studios v2!
JAAA!!!
Det fungerade!
Tack @anders!
Jag tog bort ' runt pris och Yes/No och då fungerade det, nästan...
Jag ska skickas vidare till en sida där produktens idnummer(PID) ska synas men det händer inget efter att produkten lagts till i databasen...
<% ElseIf Request.QueryString("page") = "upload" Then
" VALUES('" & kat & "','" & namn & "'," & pris & ", " & _
" '" & lank5 & "'," & status & ")"
<% ElseIf Request.QueryString("page") = "done" Then
Set rs = Connection.Execute("SELECT PID, namn FROM produkter WHERE namn = '" & Request.QueryString("namn") & "'")
<table align="center">
 <tr>
  <td>
<%=rs("namn")%> har lagts till i databasen.<br>
ProduktID/Produktnummer(PID): <strong><%=rs("PID")%></strong>
  </td>
 </tr>
</table>
<% Else
Response.Write"Sidan kunde inte hittas!"
End If %>
(Kanske var lite mycket onödig kod :q )
/Mika3l
Ok, då börjar vi!
MK-Studios v2!
121 ms — deklarationer (db)
128 ms — ändringar (db)
