EOF och BOF
6 svar · 472 visningar · startad av hallmert
Medlem sedan dec. 2004182 inlägg
Hej, jag har fått ett mycket märkligt fel i min kod. Felet kom automatiskt när sidan bara rullade (det är en del av ett community).
FEL:
ADODB.Field error '80020009'
Either BOF or EOF is True, or the current record has been deleted. Requested operation requires a current record.
/gastbok_lasa.asp, line 0
Okej, vart hittar jag rad 0?
KOD:
<!-- #include file="presentation_overlay.asp" -->
<div class="rubrik">Skicka gästboksinlägg till <%=recset("username")%></div><br>
<table width="580" cellpadding="0" cellspacing="0">
<tr>
<td width="580" valign="top">
<form name="form1" method="post" action="gastbok_skriva.asp?ID=<%=Request.QueryString("ID")%>">
<tr>
<textarea name="text" style="width: 580px;" rows="3" class="grey"></textarea>
</td>
</tr>
<tr>
<td width="580" valign="middle" align="right" height="25">
<input type="submit" value="rocka iväg gästboksinlägget" class="greyknapp">
</td>
</tr>
</table>
Set Connect2 = Server.CreateObject("ADODB.Connection")
Connect2.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("db/fanclub.mdb")
Set RecSet2 = Server.CreateObject("ADODB.Recordset")
Set MinCon = Server.CreateObject("ADODB.Connection")
MinCon.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("db/fanclub.mdb")
Const perSida = 10
Sidan = Request.QueryString("sida")
If Sidan = "" then
sida = 1
Else
sida = Sidan
MinCon.execute("update gb set readed=1 where tillid = "&Session("id") )
SQL = "Select * From gb Where tillID = "&Request.QueryString("ID") &" Order By ID DESC"
With rs
.CursorLocation = 3
.CacheSize = perSida
End With
rs.Open SQL, MinCon
if rs.eof then
response.write ""
With rs
.PageSize = perSida
.AbsolutePage = sida
End With
Sidor =  rs.PageCount
Cound = 0
Do While Not rs.EOF And Count < rs.PageSize
<%Addera2 = "Select * From members where ID ="& rs("fromid")
RecSet2.Open Addera2, Connect2, 1, 2
<tr>
<td width="65" align="center" valign="top">
<img src="fanclub-bilder/<%=RecSet2("bild")%>" width="45" height="55" border="1">
</td>
<td width="515">
	<table width="511" cellpadding="2" cellspacing="0">
	<tr>
	<td width="421" bgcolor="#dbdbdb"><a href="default.asp?visaSida=presentation&ID=<%=rs("fromid")%>"><b><%=rs("namn")%></b></a>,
	<%= replace(formatdatetime(rs("datum"),vblongdate),"den ","") & " " & formatdatetime(rs("datum"),vbshorttime) %>
	</td>
	<td width="90" height="7" bgcolor="#dbdbdb" align="right">
		<table cellpadding="0" cellspacing="0" border="0">
		<tr>
		<td><% if rs("readed") = 0 then %><b>oläst</b><% end if %></td>
		<td><% IF Session("id") & "" = Request.Querystring("ID") &"" Then %><a href="javascript:popup('gastbok_historik.asp?ID=<%=rs("fromid")%>&namn=<%=rs("namn")%>','325','485');">svara</a><% END IF%></td>
		<td width="7"></td>
		<td><% IF Session("id") & "" = Request.Querystring("ID") & "" then %><a href="default.asp?visaSida=gastbok_tabort&delID=<%=rs("id")%>">ta bort</a><% End IF %>&nbsp;</td>
		</tr>
		</table>
	</td>
	</tr>
	<tr>
	<td width="511" colspan="2" class="gb"><%=Server.HTMLEncode(rs("text"))%>
	</td>
	</tr>
	</table>
</td>
</tr>
</table>
<table height="16" cellpadding="0" cellspacing="0"><tr><td></td></tr></table>
RecSet2.Close
	Count = Count + 1
	rs.MoveNext
	Loop
Connect2.Close
Set RecSet2 = nothing
Set Connect2 = nothing
rs.Close
MinCon.Close
<%If Sidor = 1 Then%>
<%Else%>
<%End If%>
<div align="center">
<%If Sidor <> 1 Then%>
<b>Fler inlägg:</b> <%For Sid = 1 To Sidor%>
<%If (Int(Sid)) = (Int(sida)) Then%>(<%=Sid%>)<%Else%> <a href="default.asp?visaSida=gastbok_lasa&ID=<%=Request.Querystring("id")%>&sida=<%=Sid%>"><%=Sid%></a> <%End If%>
<%Next%>
<%End If%></div>
</td>
</tr>
</table>
Jag förstår verkligen INGENTING. Feler har som sagt kommit automatiskt när sidan har rullat (det är en del av ett community). Det hela är mycket märkligt. Tacksam för all hjälp! Cheers!
? Vad finns i den filen?
<!-- #include file="include-fanclub.asp" -->
<!-- #include file="presentation_textedit.asp" -->
If Session("login") <> "ok" Then
	Session("meddelande") = "Du har blivit urloggad, var god logga in igen!"
	Response.Redirect "default.asp"
Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=" & Server.MapPath("db/fanclub.mdb")&";pwd=losen"
Addera = "Select * From members Where id = " &Request.QueryString("ID")
RecSet.Open Addera, Connect, adOpenStatic, adLockOptimistic
<tr>
<td width="580" bgcolor="#3d3d3d" valign="middle" height="18" align="center">
<a href="default.asp?visaSida=gastbok_lasa&ID=<%=recset("id")%>" class="meny">gästbok</a> &nbsp;&nbsp;&nbsp;
<a href="default.asp?visaSida=mail_skicka&ID=<%=recset("id")%>" class="meny">maila</a> &nbsp;&nbsp;&nbsp;
<% IF Session("id") & "" = Request.Querystring("ID") &"" Then %><a href="default.asp?visaSida=vanner&id=<%=session("id")%>" class="meny">vännerlista</a> &nbsp;&nbsp;&nbsp;<% else %><a href="default.asp?visaSida=presentation_vanner&ID=<%=recset("id")%>" class="meny">vännerlista</a> &nbsp;&nbsp;&nbsp;<% end if %>
<a href="default.asp?visaSida=vanner_skapa&ID2=<%=recset("id")%>" class="meny">bli vän med</a> &nbsp;&nbsp;&nbsp;
<a href="default.asp?visaSida=presentation&ID=<%=recset("id")%>" class="meny">profilsida</a>
</td>
</tr>
</table><p>
Det fungerar lokalt på min maskin (webbserver) dessutom, men inte på mitt hotell.
Du har i alla fall inte kontrollerat denna.
... ault.asp?visaSida=presentation_vanner&ID=[b]<%=recset("id")%>"[/b] class="meny">vännerli ...
Sen vet jag iofs inte hur dina ytterligare inkluderade filer ser ut.
Du öppnar samma databaskoppling 3 gånger (minst). Det är onödigt.
Medlem sedan okt. 2004392 inlägg
Hmm, jag märkte att i ena Connection så har du ett lösenord, i andra har du inte det...
Och emission har rätt, en connection till samma databas räcker...
256 ms totalt · 4 externa anrop · v20260731065814-full.e96017d9
124 ms — deklarationer (db)
122 ms — ändringar (db)
