Bild upload
5 svar · 338 visningar · startad av Jesper T
Häj häj!
Vet någon hur man inplementerar ett <input type="file"> + fileupload med denna bildstorlekskollare?
<html>
<title>Untitled Document</title>
<body bgcolor="#FFFFFF" text="#000000">
function GetBytes(flnm, offset, bytes)
Dim objFSO
Dim objFTemp
Dim objTextStream
Dim lngSize
on error resume next
Set objFSO = CreateObject("Scripting.FileSystemObject")
' First, we get the filesize
Set objFTemp = objFSO.GetFile(flnm)
lngSize = objFTemp.Size
set objFTemp = nothing
fsoForReading = 1
Set objTextStream = objFSO.OpenTextFile(flnm, fsoForReading)
if offset > 0 then
strBuff = objTextStream.Read(offset - 1)
if bytes = -1 then ' Get All!
GetBytes = objTextStream.Read(lngSize) 'ReadAll
GetBytes = objTextStream.Read(bytes)
objTextStream.Close
set objTextStream = nothing
set objFSO = nothing
end function
function lngConvert(strTemp)
lngConvert = clng(asc(left(strTemp, 1)) + ((asc(right(strTemp, 1)) * 256)))
end function
function lngConvert2(strTemp)
lngConvert2 = clng(asc(right(strTemp, 1)) + ((asc(left(strTemp, 1)) * 256)))
end function
function gfxSpex(flnm, width, height, depth, strImageType)
dim strPNG
dim strGIF
dim strBMP
dim strType
strType = ""
strImageType = "(unknown)"
gfxSpex = False
strPNG = chr(137) & chr(80) & chr(78)
strGIF = "GIF"
strBMP = chr(66) & chr(77)
strType = GetBytes(flnm, 0, 3)
if strType = strGIF then
strImageType = "GIF"
Width = lngConvert(GetBytes(flnm, 7, 2))
Height = lngConvert(GetBytes(flnm, 9, 2))
Depth = 2 ^ ((asc(GetBytes(flnm, 11, 1)) and 7) + 1)
gfxSpex = True
strBuff = GetBytes(flnm, 0, -1)
lngSize = len(strBuff)
flgFound = 0
strTarget = chr(255) & chr(216) & chr(255)
flgFound = instr(strBuff, strTarget)
if flgFound = 0 then
exit function
strImageType = "JPG"
lngPos = flgFound + 2
ExitLoop = false
do while ExitLoop = False and lngPos < lngSize
do while asc(mid(strBuff, lngPos, 1)) = 255 and lngPos < lngSize
lngPos = lngPos + 1
loop
if asc(mid(strBuff, lngPos, 1)) < 192 or asc(mid(strBuff, lngPos, 1)) > 195 then
lngMarkerSize = lngConvert2(mid(strBuff, lngPos + 1, 2))
lngPos = lngPos + lngMarkerSize + 1
ExitLoop = True
loop
if ExitLoop = False then
Width = -1
Height = -1
Depth = -1
Height = lngConvert2(mid(strBuff, lngPos + 4, 2))
Width = lngConvert2(mid(strBuff, lngPos + 6, 2))
Depth = 2 ^ (asc(mid(strBuff, lngPos + 8, 1)) * 8)
gfxSpex = True
end function
sub test(flnm)
if right(flnm, 3)="gif" then
flgFound = 0
ExitLoop = false
lngPos = lngPos + 1
loop
ExitLoop = True
loop
if ExitLoop = "False" then
Width = -1
Height = -1
Depth = -1
a=width
b=height
response.write("BREDDEN ÄR: " &a &" HÖJDEN ÄR: " &b)
response.write "<br>--"
end sub
filen = request.form("filen")
call test(server.mappath("logo.gif"))
Set fso = CreateObject("Scripting.FileSystemObject")
Set fil = fso.GetFile(Server.MapPath("logo.gif"))
storlek = fil.size
storlek2 = storlek / 1000%>
filens storlek är <%= left(storlek2,4) %> kb
</html>
MVH Jesper :)
If ASPackad date-1 then ASPerin Now
Alltså hur byter jag ut denna adress:
till en request ifrån ett formulär och vidare laddar upp bilden.
Hoppas att jag varit tydlig nog?!
MVH Jesper
Kanske så här:
call test(filen)
Set fil = fso.GetFile(filen)
Upload: http://cgi.webforum.nu/wf/Forum11/HTML/000626.html
/solbulle
Hemmabio | Spelautomater | The Who | The Who II
[Redigerat av solbulle den 05 feb 2002]
Ibland ser man inte skogen för att det står så många träd ivägen! Funkar finfint!
MVH Jesper
Du kanske har fått till det helt med uppladdning och allt, annars kan du kika på detta:
bild.asp
check = request.querystring("check")
If check <> "" then
<!--#include file="outputfile.asp"-->
Dim objFSO
Dim objFTemp
Dim objTextStream
Dim lngSize
fsoForReading = 1
if offset > 0 then
objTextStream.Close
end function
end function
end function
dim strPNG
dim strGIF
dim strBMP
dim strType
strType = ""
gfxSpex = False
strGIF = "GIF"
gfxSpex = True
flgFound = 0
exit function
ExitLoop = false
lngPos = lngPos + 1
loop
ExitLoop = True
loop
Width = -1
Height = -1
Depth = -1
gfxSpex = True
end function
sub test(flnm)
flgFound = 0
ExitLoop = false
lngPos = lngPos + 1
loop
ExitLoop = True
loop
Width = -1
Height = -1
Depth = -1
a=width
b=height
response.write "<br>"
end sub
call test(server.mappath(filename))
Set fil = fso.GetFile(Server.MapPath(filename))
storlek = fil.size
<% end if %>
<br>
<FORM METHOD="Post" ENCTYPE="multipart/form-data" ACTION="bild.asp?check=1">
Fil : <INPUT TYPE="file" NAME="blob"><BR>
<INPUT TYPE="submit" NAME="ok">
</html>
upload.asp
' Author Philippe Collignon
' Email PhCollignon@email.com
Sub BuildUploadRequest(RequestBin)
'Get the boundary
PosBeg = 1
PosEnd = InstrB(PosBeg,RequestBin,getByteString(chr(13)))
boundary = MidB(RequestBin,PosBeg,PosEnd-PosBeg)
boundaryPos = InstrB(1,RequestBin,boundary)
'Get all data inside the boundaries
Do until (boundaryPos=InstrB(RequestBin,boundary & getByteString("--")))
'Members variable of objects are put in a dictionary object
Dim UploadControl
Set UploadControl = CreateObject("Scripting.Dictionary")
'Get an object name
Pos = InstrB(BoundaryPos,RequestBin,getByteString("Content-Disposition"))
Pos = InstrB(Pos,RequestBin,getByteString("name="))
PosBeg = Pos+6
PosEnd = InstrB(PosBeg,RequestBin,getByteString(chr(34)))
Name = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
PosFile = InstrB(BoundaryPos,RequestBin,getByteString("filename="))
PosBound = InstrB(PosEnd,RequestBin,boundary)
'Test if object is of file type
If PosFile<>0 AND (PosFile<PosBound) Then
'Get Filename, content-type and content of file
PosBeg = PosFile + 10
FileName = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
'Add filename to dictionary object
UploadControl.Add "FileName", FileName
Pos = InstrB(PosEnd,RequestBin,getByteString("Content-Type:"))
PosBeg = Pos+14
'Add content-type to dictionary object
ContentType = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
UploadControl.Add "ContentType",ContentType
'Get content of object
PosBeg = PosEnd+4
PosEnd = InstrB(PosBeg,RequestBin,boundary)-2
Value = MidB(RequestBin,PosBeg,PosEnd-PosBeg)
Else
Pos = InstrB(Pos,RequestBin,getByteString(chr(13)))
PosBeg = Pos+4
Value = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
'Add content to dictionary object
UploadControl.Add "Value" , Value
'Add dictionary object to main dictionary
UploadRequest.Add name, UploadControl
'Loop to next object
BoundaryPos=InstrB(BoundaryPos+LenB(boundary),RequestBin,boundary)
Loop
End Sub
'String to byte string conversion
Function getByteString(StringStr)
For i = 1 to Len(StringStr)
char = Mid(StringStr,i,1)
getByteString = getByteString & chrB(AscB(char))
Next
End Function
'Byte string to string conversion
Function getString(StringBin)
getString =""
For intCount = 1 to LenB(StringBin)
getString = getString & chr(AscB(MidB(StringBin,intCount,1)))
Next
End Function
outputfile.asp
Response.Expires=0
Response.Buffer = TRUE
Response.Clear
'Response.BinaryWrite(Request.BinaryRead(Request.TotalBytes))
byteCount = Request.TotalBytes
'Response.BinaryWrite(Request.BinaryRead(varByteCount))
RequestBin = Request.BinaryRead(byteCount)
Dim UploadRequest
Set UploadRequest = CreateObject("Scripting.Dictionary")
BuildUploadRequest RequestBin
'email = UploadRequest.Item("email").Item("Value")
contentType = UploadRequest.Item("blob").Item("ContentType")
filepathname = UploadRequest.Item("blob").Item("FileName")
filename = Right(filepathname,Len(filepathname)-InstrRev(filepathname,"\"))
value = UploadRequest.Item("blob").Item("Value")
'Create FileSytemObject Component
Set ScriptObject = Server.CreateObject("Scripting.FileSystemObject")
'Create and Write to a File
pathEnd = Len(Server.mappath(Request.ServerVariables("PATH_INFO")))-14
' Set MyFile = ScriptObject.CreateTextFile(Left(Server.mappath(Request.ServerVariables("PATH_INFO")),pathEnd)&filename)
Set MyFile = ScriptObject.CreateTextFile(Server.mappath(filename))
response.write(Server.mappath(filename))
For i = 1 to LenB(value)
MyFile.Write chr(AscB(MidB(value,i,1)))
Next
MyFile.Close
<br>
<b>Uppladdad fil : </b><%=filename%><BR>
<img src="<%=filename%>">
<!--#include file="upload.asp"-->
Mycklet kod blev det...
/solbulle
Wow, skall kolla vad det blev, återkommer!
MVH Jesper
