Hej, har en kod som ni ser nedanför, och submit knappen står det "Skicka fråga" men jag vill att det ska stå "Spara" hur gör jag för att ändra??
<!-- #include file="adovbs.inc" -->
IF Request.QueryString("DO") = "SOK" THEN
Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=" & Server.MapPath("graf/db/forum.mdb")&";"
Addera = "Select * From asp WHERE INLAGG LIKE '%" & Request.Form("sokord") & "%' ORDER BY DATUM DESC"
RecSet.Open Addera, Connect, adOpenStatic, adLockOptimistic
X=0
DO UNTIL RecSet.EOF
<tr>
<td width="20" height="15"><font size="1" face="Verdana, Arial, Helvetica, sans-serif" color="#000000">
'########## KOLLAR OM DET FINNS NYA INLÄGG ###########
Set RecSet2 = Server.CreateObject("ADODB.Recordset")
Addera2 = "Select \* From asp WHERE REF_ID =" &RecSet("ID")
RecSet2.Open Addera2, Connect, adOpenStatic, adLockOptimistic
Y=0
DO UNTIL RecSet2.EOF
IF RecSet2("DATUM") > Now() - 1 THEN
Y=1
RecSet2.Close
Exit DO
END IF
RecSet2.MOVENEXT
LOOP
<% IF Y=1 THEN %>
<img src="pil-right-red.gif" width="10" height="9">
<% END IF %>
</font></td>
<td height="15"><font size="1" face="Verdana, Arial, Helvetica, sans-serif" color="#000000">
<a href="read.asp?ID=<%=RecSet("ID")%>"><%=RecSet("RUBRIK")%></a></font></td>
<td width="100" height="15"><font size="1" face="Verdana, Arial, Helvetica, sans-serif" color="#000000">
<%=RecSet("NAMN")%> </font></td>
<td width="125" height="15"><font size="1" face="Verdana, Arial, Helvetica, sans-serif" color="#000000">
<td width="40" height="15">
<div align="center"><font size="1" face="Verdana, Arial, Helvetica, sans-serif" color="#000000"><%=RecSet("ANTALSVAR")%></font></div>
</td>
</tr>
RecSet.MOVENEXT
LOOP
RecSet.CLOSE
Connect.CLOSE
Set RecSet = nothing
Set Connect = nothing
</table>
<% END IF %>
<form name="form1" method="post" action="graf/sok.asp?DO=SOK">
<font face="Verdana, Arial, Helvetica, sans-serif"> <font size="1">
...<br>
<input type="text" name="sokord" size="20" maxlength="30" class="TABELLER">
<br>
<input type="submit" name="Submit" alt="Sök i databasen" border = "0">
</font> </font>
</font><font size="1" face="Verdana, Arial, Helvetica, sans-serif" color="#000000">
</font></p>
</td>
</tr>
</table>
