Slumpa
36 svar · 346 visningar · startad av hacktheplanet
hacktheplanetMedlem sedan nov. 2001263 inlägg
varför funkar inte scriptet har provat med att inkludera och utan nu ser koden ut såhär:
får felmess:
Körningsfel i Microsoft VBScript (0x800A0009)
Felaktigt matrisindex: '[number: -1]'
/slumpa/slumpa.asp, line 294
och
Felaktigt matrisindex: 'intRandomIndex'
/slumpa/slumpa.asp, line 292
'## -- COPYRIGHT INFORMATION see the readme.txt file that should
'##    be a part of this script. If not! contact me at info@mrwize.nu		 --
Class clsArray
	Private g_varArray ' As Variant
	Private g_bolArrayType ' As Boolean
	Private g_intPositions ' As Integer
	Private g_bolCreated ' As Boolean
	'## -- PUBLIC PROPERTIES --
	'## -- what type of array. 1-dimensional or 2-dimensional			--
	Public Property Let ArrayType(ByVal bType)
		g_bolArrayType = bType
	End Property
	Public Property Get ArrayType
		ArrayType = g_bolArrayType
	End Property
	'## -- how many positions every index in a 2-dimensional array have	--
	Public Property Let Positions(ByVal iPositions)
		g_intPositions = iPositions
	End Property
	Public Property Get Positions
		Positions = g_intPositions
	End Property
	'## -- PRIVATE PROPERTIES --
	'## -- to indicate if the array is recently created or not			--
	Private Property Let IsCreated(ByVal bCreated)
		g_bolCreated = bCreated
	End Property
	Private Property Get IsCreated
		IsCreated = g_bolCreated
	End Property
	'## -- PUBLIC METHODS --
	Public Sub SetArray(vArray)
		If IsArray(vArray) Then
			g_varArray = vArray
		Else
			'## -- set array recently created by this class --
			IsCreated = 1
			'## -- wich type of array to create --
			Select Case ArrayType
				Case 2
					Dim intPositions
					intPositions = Positions
					ReDim g_varArray(intPositions,0)
				Case Else
					ReDim  g_varArray(0)
			End Select
	End Sub
	Public Sub AddNew()
		Dim intNewIndex ' As Integer
		Dim bolIsCreated ' As Boolean
		bolIsCreated = IsCreated
		intNewIndex = MaxIndex + 1
			Case 2
				Dim intPositions ' As Integer
				If bolIsCreated <> 1 Then
					'## -- the array is not recently created and need a new index --
					ReDim Preserve g_varArray(intPositions,intNewIndex)
				Else
					'## -- array is newly created and need not a new index.
					'## -- set array not recent created --
					IsCreated = 0
			Case Else
				'## -- check if the array is newly created --
					ReDim Preserve g_varArray(intNewIndex)
				Else
					'## -- the array is recent created and need not a new index --
					'## -- set array to indicate as not recently created --
					IsCreated = 0
		End Select
	End Sub
	Public Sub Update(ByVal vData, ByVal iIndex, ByVal iPos)
		'## -- if no index is given as a argument then set index to be
		'##    updated as last created index							--
		If Len(iIndex) = 0 OR IsNull(iIndex) Then iIndex = MaxIndex()
			Case 2
				'## -- if no position for index is given as a argument
				'##    then update the first position in the index		--
				If Len(iPos) = 0 OR IsNull(iPos) Then iPos = 0
				'## -- save the new value to the array					--
				g_varArray(iPos, iIndex) = vData
			Case Else
				g_varArray(iIndex) = vData
		End Select
	End Sub
	Public Sub Delete(ByVal iIndex)
		If iIndex < MinIndex() OR iIndex > MaxIndex() Then Exit Sub '## -- illegal index value --
		Dim I, intPos
		Dim intEndIndex
		intEndIndex = MaxIndex() - 1
			Case 2
				Dim intPositions
				For I = iIndex To intEndIndex
					For intPos = 0 To intPositions
						g_varArray(intPos,intEndPosition) = g_varArray(intPos,intEndPosition + 1)
					Next
				Next
				ReDim Preserve g_varArray(intPositions,intEndIndex)
			Case Else
				For iIndex = iIndex To intEndIndex
					g_varArray(iIndex) = g_varArray(iIndex + 1)
				Next
				ReDim Preserve g_varArray(intEndIndex)
		End Select
	End Sub
	Public Sub Sort(ByVal sSortOrder, ByVal iPos)
		Dim intMaxIndex ' As Integer
		Dim I, X ' As Integer
		Dim varTemp ' As Variant
		intMaxIndex = MaxIndex()
			Case 2
				'## -- 2-dimensional array in use --
				Dim intPositions, intPos
				'## -- get total positions in array --
				If UCase(sSortOrder) = "ASC" Then
					'## -- sort ascending --
					For I = 0 To intMaxIndex
						For X = (I + 1) To intMaxIndex
							If g_varArray(iPos, I) > g_varArray(iPos,X) Then
									varTemp = g_varArray(intPos, I)
									g_varArray(intPos, I) = g_varArray(intPos, X)
									g_varArray(intPos, X) = varTemp
								Next
						Next
					Next
				ElseIf UCase(sSortOrder) = "DESC" Then
					'## -- sort descending --
							If g_varArray(iPos, I) < g_varArray(iPos,X) Then
								Next
						Next
					Next
			Case Else
				'## -- standard 1-dimensional array in use --
							If g_varArray(I) > g_varArray(X) Then
								varTemp = g_varArray(I)
								g_varArray(I) = g_varArray(X)
								g_varArray(X) = varTemp
						Next
					Next
							If g_varArray(I) < g_varArray(X) Then
						Next
					Next
		End Select
	End Sub
	'## -- get iData random values from array --
	Public Function Random(ByVal iData)
		Randomize
		Dim varArray
		Dim varArray_tmp
		Dim intMaxIndex
		Dim intRandomIndex
		Dim N
		varArray_tmp = g_varArray
			Case 2
				Dim intPos
				Dim X
				intPos = Positions
				ReDim varArray(intPos, iData - 1)
				For N = 0 To iData - 1
					'## -- get random index values from "mother" array --
					intRandomIndex = CInt(rnd * (intMaxIndex - N))
					'## -- save random data --
					For X = 0 TO intPos
						[b]varArray(X, N) = varArray_tmp(X,intRandomIndex)[/b] <---
						[b]varArray_tmp(X, intRandomIndex) = varArray_tmp(X,intMaxIndex - N)[/b] <---
					Next
				Next
			Case Else
				ReDim varArray(iData - 1)
					'## -- get random index value from "mother" array --
'Response.Write "HERE" rad 306
					 varArray(N) = varArray_tmp(intRandomIndex)
					varArray_tmp(intRandomIndex) = varArray_tmp(intMaxIndex - N)
				Next
		End Select
		'## -- return an array of iData random selected from "mother" array --
		Random = varArray
	End Function
	Public Function GetArray() ' As Variant
		GetArray = g_varArray
	End Function
	'## -- PRIVATE METHODS --
	Private Sub Class_Initialize()
		'## -- set default values --
		'## -- set the array to: not recently created.
		IsCreated = 0
	End Sub
	'## -- get last index (array size) of the array --
	Private Function MaxIndex()
			Case 2
				MaxIndex = UBound(g_varArray,2)
			Case Else
				MaxIndex = UBound(g_varArray)
		End Select
	End Function
	Private Function MinIndex()
			Case 2
				MinIndex = LBound(g_varArray,2)
			Case Else
				MinIndex = LBound(g_varArray)
		End Select
	End Function
	Private Sub Class_Terminate()
	'## -- do nothing --
	End Sub
End Class
<HTML>
<HEAD>
<TITLE>Random Image</TITLE>
<META http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</HEAD>
<BODY bgcolor="#FFFFFF" text="#000000">
strSQLimg = "SELECT [id], username, bild FROM members WHERE NOT bild = 'Bilder\Medlemmar\ingen.gif'"
'strSQLimg = "SELECT * FROM tblGuestbook"
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.Open "DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" & server.mappath("database/members.mdb")
'objConn.Open "DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" & server.mappath("../db/wizeBook.mdb")
Set objRSimg = objConn.Execute(strSQLimg)
If Not objRSimg.EOF Then
varArray = objRSimg.GetRows()
Set objRSimg = Nothing
objConn.Close
Set objConn = nothing
Set objArray = New clsArray
With objArray
.ArrayType = 2 '## -- a 2-dimensional array are set to be used --
.Positions = 2 '## -- 3 positions will be created on every index. positions start count at 0 --
.SetArray varArray
'## -- get randomly data as array --
varImages = .Random(6)
End With
Set objArray = Nothing
'## -- show random images --
If IsArray(varImages) Then
For N = 0 TO UBound(varImages,2)
'Response.write varImages(0,N) & "<BR>"
response.write "<a href=""krypin.asp?checkid=" & varImages(0,N) & """><img src=""" & varImages(2,N) & """ alt=""" & varImages(1,N) & """ border = ""0"" width= ""69"" height= ""87""></a>"
Next
</BODY>
</HTML>
easMedlem sedan sep. 2001269 inlägg
Oj va kod!!!
Det blit no lite svårt att få svar då ingen orkar kolla igenom allt ;)
Schöndells webbsajt
PatrikBMedlem sedan mars 20002 836 inlägg
.... fast, om man använda sig av rätt tråd .. finns ju en hjälpkod för denna klass :e
kommer med svar snart .... måste käka lite först
cya,
PatrikB
-=* IF there is a wrong way to do something, then someone will do it *=-
[Redigerat av PatrikB den 28 jan 2002]
Testa detta:
Randomize
Dim varArray
Dim varArray_tmp
Dim intMaxIndex
Dim intRandomIndex
Dim N
[b]If iData > intMaxIndex Then iData = intMaxIndex[/b]
den fetmarkerade är det du ska lägga till. ett par rader över det som du har fetmarkerat.
såhär eller:
Randomize
Dim varArray
Dim varArray_tmp
Dim intMaxIndex
Dim intRandomIndex
Dim N
				Next
jepp
cya,
PatrikB
Kompileringsfel i Microsoft VBScript (0x800A03EA)
Syntaxfel
/slumpa/slumpa.asp, line 311
.... nu ska jag gå o lägga mig .... har jobbat för mycket idag och ser i kors!!!
va ju rätt från början.
cya,
PatrikB
Feltyp:
Syntaxfel
/slumpa/clsarray.asp, line 311
så här ser du ut nu:
Randomize
Dim varArray
Dim varArray_tmp
Dim intMaxIndex
Dim intRandomIndex
Dim N
If iData < intMaxIndex Then iData = intMaxIndex
				Next
		End Select
		Random = varArray
	End Function
	End Function
		IsCreated = 0
	End Sub
om du tar bort raden som du la dit, funkar det då?
cya,
PatrikB
har du koden liggandes på samma sida som övrig kod?
I såfall .... kolla om klassen kommer innanför en if-sats. Gör den det får man typ dessa felmeddelanden.
Det bästa är att lägga alla classer i egna filer och sedan inkludera dem antingen längst ned på sidan eller överst .. innan/efter övrig kod
cya,
PatrikB - som nu går o kramar kudden en liten stund -
jag har inkluderat det istället!! nope funkar inte och tagit bort:
[Redigerat av hacktheplanet den 28 jan 2002]
jboy_87Medlem sedan aug. 20011 099 inlägg
PatrickB> ska det inte vara nån end function nånstans
ASP är bäst fuck the rest!!!
Det finns en end function.
FAst jag tror att du la till lite för mycket. Du skulle bara lagt till den fetmarkerade raden. Det ovanför togs med ENDAST för att visa vart den fet markerade raden skulle läggas till.
Hela Random funktionen:
Randomize
Dim varArray
Dim varArray_tmp
Dim intMaxIndex
Dim intRandomIndex
Dim N
Case 2
Dim intPos
Dim X
intPos = Positions
For X = 0 TO intPos
varArray(X, N) = varArray_tmp(X,intRandomIndex) <---
varArray_tmp(X, intRandomIndex) = varArray_tmp(X,intMaxIndex - N) <---
Next
Next
Case Else
Next
End Select
Random = varArray
End Function
Försök att få till det eller ta orginalscriptet och lägg till endast den fetmarkerade raden:
cya,
PatrikB
funkar men slumpar bara 1 bild??
nån :(
Hur många poster får du ut med .GetRows()?
dvs, skriv ut:
Response.Write UBound(varArray,2)
Du kanske bara får ut en post från databasen
cya,
PatrikB
... då vet du ju vart du ska börja leta fel .... :e
cya,
PatrikB
jag vill att typ det ser ut så här:
|bild| |bild| |bild| | osv.....
146 ms totalt · 3 externa anrop · v20260731065814-full.30151723
142 ms — hämta tråd, inlägg och bilagor (db)
