Är inte säker men får man inte det fel meddelandet om man inte har Inkluderat adovbs.inc ?
Dont drink and drive!!! smoke shit and fly!!!
7 svar · 290 visningar · startad av ampy
<% Set Connect = Server.CreateObject("ADODB.Connection")
Set RecSet = server.createobject("ADODB.Recordset")
Connect.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("gastbok.mdb")
SQL = "SELECT * FROM installningar WHERE id = "&request.querystring("id")
RecSet.Open SQL, Connect
minfont = RecSet("minfont")
minsize = RecSet("minsize")
mintext = RecSet("mintext")
minlink = RecSet("minlink")
minhover = RecSet("minhover")
minbg = RecSet("minbg")
minbgbild = RecSet("minbgbild")
minform = RecSet("minform")
mintbl = RecSet("mintbl")
<style type="text/css">
A:Visited { font-family: "<%=minfont%>" ; color:<%=minlink%> ; text-decoration:none ; font-weight:normal ; font-size:<%=minsize%>px ;}
A:Link { font-family: "<%=minfont%>" ; color:<%=minlink%> ; text-decoration:none ; font-weight:normal ; font-size:<%=minsize%>px ; }
A:Hover { font-family: "<%=minfont%>" ; color:<%=minhover%> ; text-decoration:none ; font-weight:normal ; font-size:<%=minsize%>px ; }
BODY { background-color:<%=minbg%> ; background-image:url(<%=minbgbild%> ) ; color:<%=mintext%> ; margin:10 ;}
BODY { font-family:<%=minfont%> ; font-size:<%=minsize%>px ; }
table { font-family:<%=minfont%> ; font-size:<%=minsize%>px ; }
.mess { background-color:<%=mintbl%> ; }
form { font-family:<%=minfont%>; font-size:<%=minsize%>px ; }
input { font-family:<%=minfont%>; font-size:<%=minsize%>px ; color:<%=minform%> ; border-width:1px ; border-color: Black ; }
textarea { font-family:<%=minfont%> ; font-size:<%=minsize%>px ; color:<%=minform%> ; border-width:1px ; border-color: Black ; }
</style>
<body>
<table width="600" border="0" cellspacing="0" cellpadding="0">
<tr align="center">
<td><br>
RecSet.Close
Set RecSet = Nothing
'0=================================================================================================0
' Öppna databasen
If Request.QueryString("pallebook") = "" Then
MyPage = Request("nasta_sida")
If MyPage = "" then
MyPage = 1
MyPagesize = mittantal
SQL = "SELECT * FROM gbook ORDER BY userid DESC"
Set RecSet = Server.Createobject("ADODB.Recordset")
RecSet.CursorLocation = 3
RecSet.CacheSize = 5
RecSet.open SQL, "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & Server.MapPath("gastbok.mdb")
If RecSet.EOF Then
Response.write "Just nu finns det inga inlägg i gästboken"
Else
RecSet.MoveFirst
[b]RecSet.PageSize = MyPageSize[/b]
MaxCount = Cint(RecSet.PageCount)
RecSet.AbsolutePage = MyPage
HowManyRecs = 0
HowManyFields = RecSet.Fields.Count -1
Do While Not RecSet.EOF AND HowManyRecs < RecSet.PageSize
Counter = Counter + 1
Detta felmeddelande får jag:
ADODB.Recordset fel '800a0bb9'
Parametrarna är felaktiga, ligger utanför tillåtet intervall eller skapar en inbördes konflikt.
/ampy/gratisgastbok/pallebook.asp, line 158
Rad 158 är skriven med fetstil, hoppas någon kan se vad felet är för jag lyckas inte se det.
Ampy.cjb.net
Var sätter du mittantal till något värde?
du kan inte använda metoden .PageSize efter att recordsetet är öppnat.
Om jag inte minns fel så hade vi precis detta "fenomen" för "ett par dagar" sedan.
Sätt .PageSize INNAN recordsetet öppnas
cya,
PatrikB
-=* IF there is a wrong way to do something, then someone will do it *=-
Jag hade glömt att inkluderat den ;) men jag får ändå samma felmeddelande och på samma rad :(
Ampy.cjb.net
LarsG: Jag hade satt fel på värdet på mittantal men när jag fixade det så funkade allt :D
Ampy.cjb.net
Patrik:
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/ado270/htm/mdpropagesize.asp
Där står det att pagesize kan sättas när som helst.
hmm, ... där ser man ... man lär sig ngt nytt varje dag :)
[r]
hade för mig att dessa egenskaper ska sättas innan ....eller har det ändrats i ver. 2.7?
[/r]
cya,
PatrikB
[Redigerat av PatrikB den 29 jan 2002]
