Hittade detta artikelscript men det verkar inte gå att stänga databasen och recordsettet. Hur göra?
on error resume next
u_action=request.querystring("u_action")
u_title=replace(trim(request.form("u_title")),"'","'")
u_body=replace(trim(request.form("u_body")),"'","'")
u_author=replace(trim(request.form("u_author")),"'","'")
u_log=request.querystring("u_log")
script_name=request.servervariables("script_name")
if u_action <> "add" then
select case u_action
case "insert"
sql = "insert into articles (title,body,author)"
sql = sql & " values( '" & u_title & "' , '" & u_body & "' , '" & u_author & "' )"
case "display"
sql="select * from articles where log = "&u_log
case else
sql="select * from articles order by date desc "
end select
accessdb="articles"
cn="driver={Microsoft Access Driver (*.mdb)};"
cn=cn & "dbq=" & server.mappath(accessdb)
rs.Open sql, cn
if u_action <> "insert" then
if rs.eof then
response.redirect script_name
<html>
<title>Recent Articles</title>
<body bgcolor="#FFFFFF">
if u_action="insert" then %>
Your Article was added.<br>
<% else
<% do while not rs.eof and counter < 6
counter=counter+1 %>
<% if u_action <> "display" then %>
<a href="<%= script_name %>?u_action=display&u_log=<%= rs("log")%>"><%= rs("title") %></a> <%= rs("date") %><br>
<% else %>
<b><%= rs("title") %></b><br>
by <%= rs("author") %>
<p>
<pre>
<%= rs("body") %>
</pre>
<% end if %>
rs.movenext
loop %>
<% end if
<% if u_action="add" then
<script Language="JavaScript">
function Blank_TextField_Validator(form)
if (form.u_title.value == "")
alert("Please fill in the title field.");
form.u_title.focus();
return (false);
if (form.u_body.value == "")
alert("Please fill in the body field.");
form.u_body.focus();
return (false);
if (form.u_author.value == "")
alert("Please fill in the author field.");
form.u_author.focus();
return (false);
return (true);
<form method="post" action="<%= script_name %>?u_action=insert" onsubmit="return Blank_TextField_Validator(this)">
Title<br>
<input type="text" name="u_title" size="65"><p>
Body<br>
<textarea rows="8" name="u_body" cols="65"></textarea><p>
Author<br>
<input type="text" name="u_author" size="65"><p>
<input type="submit" value="Submit">
<% else
<p><a href="<%= script_name %>">View Recent Articles</a><br>
<a href="<%= script_name %>?u_action=add">Add Your Article</a>
<% end if %>
