Ingen kod, ingen hjälp.
Vi kan lixom inte gissa hur din kod ser ut.
Problem med en if-sats
4 svar · 295 visningar · startad av morris_the_cat
Sorry, här kommer koden:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN">
<html xmlns="http://www.w3.org/1999/xhtml" >
<link rel="stylesheet" href="cominoproductions.com/comino.css" type="text/css" />
<title>Comino Productions | Artist Management | Music Publishing</title>
Function dbOpen(Connect)
Set Connect = server.createobject("ADODB.Connection")
Connect.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & server.mappath ("db/comino.mdb ")
Set Connect = Connect
End Function
Function dbClose(Connect)
Connect.Close
Set Connect = Nothing
End Function
<body>
<div id="container">
<div id="header"></div>
<div id="menycontainer">
<ul id="meny">
<% Dim pageID %>
<% pageID = 1 %>
<% If pageID = 1 then %>
<li id="active"><a href="cominoproductions.com/default?pageID=1" id="current">Start</a></li>
<li><a href="cominoproductions.com/default.asp?pageID=2">Artist Management</a></li>
<li><a href="cominoproductions.com/default.asp?pageID=3">Music Publishing</a></li>
<li><a href="cominoproductions.com/default.asp?pageID=4">Comino News</a></li>
<li><a href="cominoproductions.com/default.asp?pageID=5">Contact Us</a></li>
<% Else If pageID = 2 then %>
<li><a href="cominoproductions.com/default?pageID=1">Start</a></li>
<li id="active"><a href="cominoproductions.com/default.asp?pageID=2" id="current">Artist Management</a></li>
<% Else If pageID = 3 then %>
<li id="active"><a href="cominoproductions.com/default.asp?pageID=3" id="current">Music Publishing</a></li>
<% Else If pageID = 4 then %>
<li id="active"><a href="cominoproductions.com/default.asp?pageID=4" id="current">Comino News</a></li>
<% Else pageID = 5 %>
<li id="active"><a href="cominoproductions.com/default.asp?pageID=5" id="current">Contact Us</a></li>
</ul>
<% End If %>
<!-- menycontainer --></div>
<br />
<div id="puff">
<div id="puffHeader" align="center">Artists</div>
<br />
<br />
<!-- artistscontainer --></div>
<div id="main">
<!-- maincontainer --></div>
<div id="puff2">
<div id="puffHeader2" align="center">Comino News</div>
<br />
Bla bla bla
<br />
<!-- newscontainer --></div>
<P>
<div id="footer" align="center">Copyright bla bla</div>
</P>
<!-- container --></div>
</html>
