Newbiee frågor
14 svar · 491 visningar · startad av RDL
Medlem sedan mars 2001344 inlägg
Ingenting gör som det ska, inget mail skickas inga saker läggs in i databasen *argh*
<!-- #include file="adovbs.inc" -->
Dim Status, epost, pass, error, Connect, Addera, CDOMAIL
Status	=	Request.Querystring("status")
If Status = "ok" Then
epost	=	Request.Form("epost")
pass	=	Request.Form("pass")
error	=	0
If epost = "" Then
error = 1
If pass = "" Then
error = 1
End if
if error = 0 and Status	= "ok" Then
Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=d:\xxx\databasen.mdb"
Addera = "SELECT * FROM str_data"
RecSet.Open Addera, Connect, adOpenStatic, adLockOptimistic
RecSet.AddNew
RecSet("epost")	= epost
RecSet("pwd")	= pass
RecSet.Update
RecSet.Close
Connect.Close
Set CDOMail = Server.CreateObject("CDONTS.NewMail")
CDOMail.From = "lennart@stockticket.com"
CDOMail.To = epost
CDOMail.Subject = "Hej, du är registrerad bla bla bla"
CDOMail.Body = "_____________" &vbcrlf& "Användarnamn:" & epost &vbcrlf& "Lösenord: " &pass
CDOMail.Send
Set CDOMail = Nothing
%><html>
<title>Bli medlem</title>
<body>
<font face="verdana" size="2" color="black">Grattis du är nu medlem, dina användaruppgifer har skickats till din epostaddress</font>
</html><%
Else
%><html>
<body>
<center>
<%If error = 1 then %>
<font face="verdana" size="2" color="Red">Du glömde att fylla i något där</font>
<%End if%>
<form method="POST" action="ny_medlem.asp?status=ok">
<font face="verdana" size="2" color="black">Epostadress</font><img src="pixel.gif" alt=" " width="10" height="1"><input type="text" name="epost" size="20"><br>
<font face="verdana" size="2" color="black">Lösenord</font><img src="pixel.gif" alt=" " width="30" height="1"><input type="text" name="pass" size="20"><br>
<input type="submit" value="Skicka" name="Skicka">
</center>
</html>
<%End if%>
[Redigerat av RDL den 20 jan 2002]
Jag har total nollkoll men borde inte:
if error = 0 and Status = ok Then
vara:
if error = "0" and Status = "ok" Then
/solbulle
Hemmabio | Spelautomater | The Who
Du har missat citationstecken runt ok:
if error = 0 and Status = [b]"ok"[/b] Then
Red: Och runt 0 som solbulle skrev ovan. Varför har du tal som strängar?
Mvh,
[Redigerat av @nders den 20 jan 2002]
tack.. ändrade talen till bara tal:
error	=	0
If epost = "" Then
error = 1
If pass = "" Then
error = 1
End if
Men nu så står det: Http 500 Internt server fel hmzz.. :(
Se då till att stänga av Friendly error messages / Egna http-felmeddelanden i IE, så du får något riktigt att utgå ifrån.
Kan inte.. De ligger på en netintense server.. :(
Då ändrar du i explorer
tools -> Internet options -> Advanced
Där finns en rutan som heter
Show user friendly error messages
Klicka av den så att du får se det rätta felet.
Klickade bort visa egna egna http meddelanden.. men det funkade inte..
Vad funkade inte? Får du fortfarande 500?
Man kan ju alltid prova att starta om IE...
Yes, jag får fortfarande fram Http 500 Internt server fel..
Gällde det bara det: Show user friendly error messages för linux såg en linux pingvin där..
Va?
Är 'visa egna egna http meddelanden' = Show user friendly error messages
Har win98 om det är till någon hjälp..
Jepp, har du klickat BORT det?
/solbulle
Japp det har jag... :)
Kan du ge oss en url till sidan?
269 ms totalt · 4 externa anrop · v20260731065814-full.e96017d9
123 ms — deklarationer (db)
128 ms — ändringar (db)
