Hämta ID en gång till
3 svar · 183 visningar · startad av ampy
Medlem sedan feb. 20011 498 inlägg
Set con = Server.CreateObject("ADODB.Connection")
con.open "DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" & Server.MapPath("../../db/lankar-kommentarer.mdb")
Dim Con
Dim rst
Dim strSQL
Const adOpenStatic = 3
Const adLockReadOnly = 1
Const adCmdText = 1
strSQL = "Select * from lankar WHERE id ="& Request.Querystring("id")
Set rst = Server.CreateObject("ADODB.Recordset")
rst.Open strSQL, Con, adOpenStatic, _
adLockReadOnly, adCmdText
<TABLE height="*" bgColor=#FFFFFF cellpadding="2" cellspacing="3" borderColor=#000000 width=520 cellSpacing=0 borderColorLight=#000000 border=0 style="BORDER-BOTTOM: #000000 1px solid;  BORDER-TOP: #000000 1px solid; BORDER-RIGHT: #000000 1px solid; BORDER-LEFT: #000000 1px solid" borderColor=#000000 >
	<TR>
    		<TD style="BORDER-BOTTOM: #000000 1px dotted" width=490><FONT face=tahoma color=#000000 size=2>
		<b><a href="recension.asp?vad=kolla" target="_blank"><% =rst("namn")%></a></b><br>
		</TD>
		<TD style="BORDER-BOTTOM: #000000 1px dotted" width=30><FONT face=Verdana color=#006600 size=2>
		<b><% =rst("betyg")%>/10</b>
		</TR>
	<TR><TD><font size="1" face="verdana"><br>
		<% =rst("kommentar")%>
<br><br>
<table border="0">
<TR>
    		<TD width=255><FONT face=verdana color=#000000 size=1>
		<b>Antal besök:</b> <% =rst("klick")%> st<br>
		</TD>
		<TD width=265><FONT face=Verdana color=#000000 size=1>
		<b>Senaste besöket:</b> <% =rst("senasteklick")%>
		</TR>
</table>
</td></tr>
<tr>
<td>
<a href="http://www.webtipsen.net/ampy.gif" target="_blank"><img src="http://www.webtipsen.net/ampy.gif" border="0" width="100" height="70"></a>
</td>
</tr>
<tr>
<td><FONT face=verdana color=#000000 size=1>
<i>Denna recension skrev Jeppe den <% =rst("skrevs")%>.</i>
</td></tr>
</table>
If Request.Querystring("vad") = "kolla" Then
	rst.Update
	ID = request.querystring("id")
	Databas.Execute("UPDATE lankar Set klick=klick+1 WHERE id='"&ID&"'")
	rst("senasteklick") = Now
	rst.Update
När jag klickar på länken får jag detta felmeddelande:
Microsoft OLE DB Provider for ODBC Drivers (0x80040E14)
[Microsoft][Drivrutin för ODBC Microsoft Access] Syntaxfel (operator saknas) i frågeuttrycket 'id ='.
/ampy/lankar/kommentarer/recension.asp, line 79
Hur ska jag göra för att hämta id:t en gång till?
Ampy.cjb.net
Du är inkonsekvent när du använder kolumnen id i dina sql-frågor.
I det första fallet hanterar du det som en numerisk kolumn och i det andra fallet som en kolumn av typen text.
Ditt felmedelande indikerar att du inte skickar något värde i request.querystring("ID")
LarsG, jag fattar inte riktigt vad du menar, vilka koder ska jag byta ut?
Ampy.cjb.net
Det beror på hur kolumnen ID är definierad. Om det är numeriskt (eller räknare, som nästan alla kolumner med namn ID) så får du ta bort apostroferna.
Varför du inte får något värde i request.quersystring beror ju mer på den anropande sidan så det är svårt att säga något om det.
254 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
123 ms — deklarationer (db)
124 ms — ändringar (db)
