varför funkar det inte?
dim file 'och hur dimmar jag rätt?
file = Request.QueryString("file")
if file = "" then
thisFile = "files/default.txt"
thisFile ="files/" & file & ".txt"
if thisFile <> "" then
Set fopen = Server.CreateObject("Scripting.FileSystemObject")
[b]Set file = fopen.OpenTextFile(thisFile,1,false,0) '>>>>>>>rad22[/b]
fread = file.ReadAll
repThis = "[BREAK]" &_
"[BREAK]"
string = Replace(fread,Chr(10),"[BREAK]")
string = Replace(string,repThis,"<br><br>")
string = Replace(string,"[BREAK]","")
string = Replace(string,"[TITEL_START]","<span class=title>")
string = Replace(string,"[TITEL_SLUT]","</span>")
<%=string%>
<a href="default.asp?fil=filer">Länken</a>
Serverobjekt fel 'ASP 0177 : 800a004c'
Server.CreateObject misslyckades
del.asp, rad 22
00000000
Tack på förhand!
-- Çhørønzøñ II --
