Konvertera till aspSmartUpload
35 svar · 1 097 visningar · startad av WebbisNet
Medlem sedan feb. 20032 027 inlägg
Nån som vet hur kan konverterar detta till aspSmartUpload och enbart tillåta gif,jpg,png och mp3
Set Upload = Server.CreateObject("Persits.Upload")
Upload.OverwriteFiles = False
Upload.SetMaxSize 100000, False
Count=Upload.Save(Server.MapPath("/images/gallery"))
For Each file In Upload.Files
  If File.ImageType = "UNKNOWN" Then
      Response.Redirect "/pictureupload/gallery/?error=filetype"
      File.Delete
  Next
If file.Size = 100000 Then
        Response.Redirect "/pictureupload/gallery/?error=fileTooBig"
    File.Delete
Next
Set File = Upload.Files
rubrik = replace(Upload.form("txtRubrik"),"'","''")
kommentar = replace(Upload.form("txtKommentar"),"'","''")
If NOT File Is Nothing Then
On Error Resume Next
strFileName= Upload.Files("blob").ExtractFileName
END IF
Dim objConn
varTillhor=Session("userID")
upplagd = Now()
storlek=file.size
	SET objConn = connect()
	picture = "INSERT INTO tblUsers_Galleri"
	picture = picture & "(bild,agare,inlagd,rubrik,kommentar) "
	picture = picture & "VALUES('" & strFileName & "','"& varTillhor &"','"& upplagd&"','"& rubrik &"','"& kommentar &"')"
	objConn.Execute picture
objConn.Execute("Update tblUsers SET poang = poang+0.8 WHERE userID= " & UserID &"")
<%response.redirect "/pictureupload/gallery/?filename=" & strFileName & "&pic=" & strFileName & "&message=pic"%>
Hur tar man emot filen för att ladda upp den
<form action="/test.asp?do=upload" method="post">
<input type="file" name="file">
<input type="submit">
<%if request("do") = "upload" then
'  Variables
   Dim mySmartUpload
   Dim intCount
'  Object creation
   Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
'  Only allow txt or htm files
   mySmartUpload.AllowedFilesList = "htm,txt"
'  DeniedFilesList can also be used :
   ' Allow all files except exe, bat and asp
   ' mySmartUpload.DeniedFilesList = "exe,bat,asp"
'  Deny physical path
   mySmartUpload.DenyPhysicalPath = True
'  Only allow files smaller than 50000 bytes
   mySmartUpload.MaxFileSize = 50000
'  Deny upload if the total fila size is greater than 200000 bytes
   mySmartUpload.TotalMaxFileSize = 200000
'  Upload
   mySmartUpload.Upload
'  Save the files with their original names in a virtual path of the web server
   intCount = mySmartUpload.Save("/Upload")
   ' sample with a physical path
   ' intCount = mySmartUpload.Save("c:\temp\")
'  Trap errors
   If Err Then
      Response.Write("<b>Wrong selection : </b>" & Err.description)
   Else
   '  Display the number of files uploaded
      Response.Write(intCount & " file(s) uploaded.")
end if%>
'  Variables
   Dim mySmartUpload
   Dim intCount
'  Object creation
'  Upload
'  Trap errors
   If Err Then
   Else
end if%>
.Upload
.Save
Får bara object required :-)
<form action="/test.asp?do=upload&test=yes" method="post" ENCTYPE="multipart/form-data" >
'  Variables
   Dim mySmartUpload
   Dim intCount
'  Object creation
Request.QueryString("test")
mySmartUpload.Files("file")
'  Upload
mySmartUpload.Files("test")
'  Trap errors
   If Err Then
   Else
end if%>
Raderna med
och
borde orsaka fel, och har ingen funktion. Här är ett annat bra exempel att titta på:
http://www.aspsmart.com/scripts/aspSmartUpload/publigen/content/templates/show.asp?P=353&L=EN
jag får
Server object error 'ASP 0177 : 800401f3'
Server.CreateObject Failed
/test.asp, line 39
800401f3
och det är på raden
emission skrev:
Raderna med
och
Är komponenten installerad på servern då?
ja det ska den vara enligt deras sida
Vad är det för webhotell då?
1. Det finns två komponenter med nästan samma namn. ASP Smart Upload och ASP Upload tror jag dom heter, och är inte samma sak.
2. Enklaste sättet att ta bort en fil är med FSO: (Fungerar oberoende av komponent)
myVar = request("delete")
IF myVar <> "" THEN
	SQL = "SELECT intID, strFileName FROM [" & myTable & "] WHERE intID = " & myVar & ""
	set mySQL = Conn.Execute(SQL)
	' ## DELETE FILE
	Set fso = Server.CreateObject("Scripting.FileSystemObject")
	IF fso.fileExists( server.MapPath("\images\" & mySQL(1) ) ) THEN
		fso.DeleteFile(Server.MapPath("\images\") & "\" & mySQL(1))
	END IF
	IF fso.fileExists( server.MapPath("\images\low_" & mySQL(1) ) ) THEN
		fso.DeleteFile(Server.MapPath("\images\") & "\low_" & mySQL(1))
	END IF
	IF fso.fileExists( server.MapPath("\images\mid_" & mySQL(1) ) ) THEN
		fso.DeleteFile(Server.MapPath("\images\") & "\mid_" & mySQL(1))
	END IF
	IF fso.fileExists( server.MapPath("\images\high_" & mySQL(1) ) ) THEN
		fso.DeleteFile(Server.MapPath("\images\") & "\high_" & mySQL(1))
	END IF
	Set fso = Nothing
END IF
Oj! Det var ju heltäckande...!
Jag undrar om det inte är ASPJpeg du ska välja.
Jag vet att en av de andra komponenterna komprimerade bilder på ett mycket dåligt sätt. Minns ej om det var ASPUpload eller ASPSmarUpload!! Men ska ta reda på det...
*kollar*
Nej, jag kör ASPSmarUpload och då är det ASPUpload du helst inte ska använda. Jag har kört ASPJpeg till vissa kunder...
Får jag bara till koden för aspSmartUpload så använder jag den, och vill hellre ha denna komponent eftersom jag vill kunna skicka upp mp3, wav och zip-filer förutom bildformaten istället för aspJpeg
Skumt. Det råkar inte vara så att du utvecklar lokalt?
Utvecklar direkt på servern
Nu får jag aspSmartUpload.File error '80040460'
Unable to save file (Error 1120)
/test.asp, line 53
mappen finns men den kan inte spara
rad 53 är file.SaveAs("/images/" & file.FileName)
varför får jag detta fel
/test.asp, line 69
rad 69 är den fetmarkerade raden
<form action="?do=upload" method="post" ENCTYPE="multipart/form-data" ID="Form1">
<input type="file" name="txtFile" ID="File1">
<input type="submit" name="Submit1" ID="Submit1">
<%Select Case request.QueryString("do")
    Case "upload"
'  Variables
   Dim mySmartUpload
   Dim file
'  Object creation
'  Only allow some files
   mySmartUpload.AllowedFilesList = "htm,txt,gif,png,mp3"
'  Upload
'  Select file
   Set file = mySmartUpload.Files("txtFile")
'  Only if the file exist
    If file.IsMissing Then
        Response.Write("Filen saknas!<BR>")
    Else
    '  Save the files with his original names in a virtual path of the web server
        strFil = file.FileName
        [B]file.SaveAs("/images/" & strFil)[/B]
        ' file.SaveAs("c:\temp\" & strFil)
    '  Display the properties of the current file
        Response.Write("Name = " & file.Name & "<BR>")
        Response.Write("Size = " & file.Size & "<BR>")
        Response.Write("FileName = " & file.FileName & "<BR>")
        Response.Write("FileExt = " & file.FileExt & "<BR>")
        Response.Write("FilePathName = " & file.FilePathName & "<BR>")
        Response.Write("ContentType = " & file.ContentType & "<BR>")
        Response.Write("ContentDisp = " & file.ContentDisp & "<BR>")
        Response.Write("TypeMIME = " & file.TypeMIME & "<BR>")
        Response.Write("SubTypeMIME = " & file.SubTypeMIME & "<BR>")
End Select
Skrivrättigheter till mappen?
ja det ska jag ha enligt webhotellet
118 ms — deklarationer (db)
126 ms — ändringar (db)
