ladda upp filer
6 svar · 182 visningar · startad av evil.sid
Medlem sedan maj 200112 inlägg
tjena!
undrar om någon har en aning om varför inte denna kod fungerar på min server:
		openConnection=true
		errorMessage=errorMessage & "Following errors need to be corrected:<blockquote><blockquote><blockquote>"
		ynt="<font color='#ff0000'>--></font> You need to "
		if len(request.form("upload"))=0 then
			openConnection=false
			errorMessage=errorMessage & ynt & "select a file<br>" & vbcrlf
		if len(request.form("l_author"))=0 then
			errorMessage=errorMessage & ynt & "enter author of the file<br>" & vbcrlf
		if request.form("l_genre")=0 then
			errorMessage=errorMessage & ynt & "select genre of the file<br>" & vbcrlf
		if len(request.form("l_filesize"))=0 then
			errorMessage=errorMessage & ynt & "enter filesize of the file<br>" & vbcrlf
		if len(request.form("l_dur"))=0 then
			errorMessage=errorMessage & ynt & "enter duration of the file<br>" & vbcrlf
		if len(request.form("l_year"))=0 then
			errorMessage=errorMessage & ynt & "enter compilation year of the file<br>" & vbcrlf
		if request.form("l_descript")="[-->enter filename here<--] -->following description" or len(request.form("l_descript"))=0 then
			errorMessage=errorMessage & ynt & "submit a description of the file<br>" & vbcrlf
		if openConnection=true then
			filename=right(request.form("upload"),len(request.form("upload"))-instrrev(request.form("upload"),"\"))
			ext=right(request.form("upload"),len(request.form("upload"))-instrrev(request.form("upload"),"."))
			set con=server.createobject("adodb.connection")
			con.open "DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" & Server.MapPath("\lemonride\db\database.mdb")
			set rs=con.execute("select * from format")
			do until rs.eof
				if rs("f_format")=ext then
					f_ext=rs("f_id")
					exit do
					rs.close
					set rs=nothing
					f_ext=21
					rs.movenext
			loop
			source=request.form("upload")
			dest="d:\archive\" & filename
			set rs=con.execute("select * from music")
			sql="insert into music (l_descript,l_filesize,l_author,l_name,l_year,l_dur,l_format,l_genre) values ('"&request.form("l_descript")&"','"&request.form("l_filesize")&"','"&request.form("l_author")&"','"&filename&"',"&request.form("l_year")&",'"&request.form("l_dur")&"',"&f_ext&","&request.form("l_genre")&")"
			do until rs.eof
				if rs("l_name")=filename then
					sql="update music set l_name='"&filename&"',l_decript='"&request.form("l_descript")&"',l_author='"&request.form("l_author")&"',l_year='"&request.form("l_year")&"',l_dur='"&request.form("l_dur")&"',l_format="&f_ext&",l_genre="&request.form("l_  genre")&",l_filesize='"&request.form("l_filesize")&"' where l_name='"&filename&"'"
					exit do
				rs.movenext
			loop
			response.write "sql: " & sql & "<br>"
			response.write "dest: " & dest
rad 102
			con.execute(sql)
sedan är det ju resten
			set rs=con.execute("select u_total from login where u_usr='"&session("u_usr")&"'")
			con.execute("update login set u_total="&rs("u_total")+1&" where u_usr='"&session("u_usr")&"'")
			session("u_total")=rs("u_total")+1
			rs.close
			set rs=nothing
			call copy_file(source,dest)
			response.redirect "../archive.asp"
			con.close
			set con=nothing
			response.write errorMessage & "</blockquote></blockquote></blockquote>"
felmeddelandet jag får är:
"kan ej hitta angiven sökväg"
det fungerar om jag sitter fysiskt på servern men inte om jag sitter på någon annan dator...
[Redigerat av evil.sid den 09 jan 2002]
Antar att det är denna raden den pekar på:
Är du säker på att dem är rätt, annars skriv ut den:
response.write dest
Mostly Harmless
sql: update music set l_name='gM_Angry.xm',l_decript='[filnamnet] beskrivning',l_author='gammis',l_year='1345',l_dur='01:30',l_format=35,l_genre=136,l_filesize='5145kb' where l_name='gM_Angry.xm'
dest: d:\archive\gM_Angry.xm
Microsoft OLE DB Provider for ODBC Drivers fel '80040e10'
[Microsoft][Drivrutin för ODBC Microsoft Access] För få parametrar angavs. 1 förväntades.
/lemonride/scripts/doarchive.asp, line 102
och sub-filen ser ut så här:
	sub copy_file(source,dest)
		set fs=createobject("scripting.filesystemobject")
		fs.copyfile source,dest
		set fs=nothing
	end sub
och det är rätt fysiska sökväg
Det Access-fel du får beror oftast på att du anger ett kolumnnamn som inte finns i din tabell.
Det står
l_decript
det kanske skall vara l_descript som du använder i dina insert.
felet kvarstår...
Då vet jag inte, det brukar alltid vara problem med kolumnnamn som orsakar det felet.
tyckte att det såg lite rörigt ut så här kommer koden igen...
doarchive.asp
			do until rs.eof
					f_ext=rs("f_id")
					exit do
					rs.close
					set rs=nothing
					f_ext=21
					rs.movenext
			loop
			do until rs.eof
					sql="update music set l_name='"&filename&"',l_descript='"&request.form("l_descript")&"',l_author='"&request.form("l_author")&"',l_year='"&request.form("l_year")&"',l_dur='"&request.form("l_dur")&"',l_format="&f_ext&",l_genre="&request.form("l  _genre")&",l_filesize='"&request.form("l_filesize")&"' where l_name='"&filename&"'"
					exit do
				rs.movenext
			loop
det här är rad 102 i doarchive.asp:
			con.execute(sql)
sedan fortsätter koden:
			rs.close
			set rs=nothing
			con.close
			set con=nothing
det här är sub.inc:
		set fs=nothing
	end sub
och felmeddelandet är:
Körningsfel i Microsoft VBScript (0x800A004C)
Det går inte att hitta angiven sökväg.
/lemonride/inc/sub.inc, line 3
vidare så har jag (temporärt) givit fulständiga rättigheter till alla på hela partitionen
270 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
129 ms — deklarationer (db)
131 ms — ändringar (db)
