Hämta värde från databas innan textfil läses in
3 svar · 348 visningar · startad av devotion
Tja!
Har följande fil som läser in en textfil till en databas:
<%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%>
<html>
<title>addSolar</title>
<body>
Response.write("<div id=""myMess"">Vänta, skriver till databasen...</div>")
Response.write("<div id=""progress""></div>")
Response.Flush()
dim objConn, objRS, strLine, iEnumber, strCategory, strUnit, curPrice, strSQL, intCounter, strArticleSupplierId
strArticleSupplierId = 4
intCounter = 0
set objFSO = Server.CreateObject("Scripting.Filesystemobject")
set objFile = objFSO.OpenTextFile (Server.MapPath("\prislistor\ahlsellpris.txt"))
Set objConn = Server.CreateObject("ADODB.Connection")
ObjConn.Open = "DSN=IntranetSydostel"
while not objFile.atendofstream
intCounter = intCounter +1
    if intCounter mod 100 = 0 then
        Response.write ("<script>document.getElementById(""progress"").innerHTML=""" & intCounter & """;</script>")
        Response.flush
    strLine = objFile.ReadLine
    iEnumber = Replace(Trim(Mid(strLine, 1, 8)), "'", "''")
	strCategory = Replace(Trim(Mid(strLine, 17, 4)), "'", "''")
	curPrice = Replace(Trim(Mid(strLine, 9, 8)), "'", "''")
	'Först kör vi en UPDATE om artikeln redan finns
	strSQL = "UPDATE tblPrice SET eNumber = '" & iEnumber & "', articleSupplierId = '" & strArticleSupplierId & "', articlePrice = " & curPrice & ", articleCategory = '" & strCategory & "' " &_
			 "WHERE eNumber = '" & iEnumber & "' AND articleSupplierId = '" & strArticleSupplierId & "'"
	         objConn.Execute strSQL, lngRA, 128
	if lngRA = 0 then
		'Ny artikel, gör INSERT
		strSQL = "INSERT INTO tblPrice (eNumber, articleSupplierId, articlePrice, articleCategory) " &_
				 "VALUES ('" & iEnumber & "', '" & strArticleSupplierId & "', " & curPrice & ", '" & strCategory & "')"
	End if
wend
objFile.close
set objFile = nothing
set objFSO = nothing
objConn.Close
Set objConn = Nothing
Response.write("<script>document.getElementById(""myMess"").innerHTML=""Prislistan har lagrats i databasen! "";</script>")
</html>
Hur modifierar jag den så att innan inläsningen påbörjas så hämtas ett värde från en tabell som heter tblNextId, fält: tblArticle.Värdet ska lagras i en variabel och ökas med 1 för varje loop. när alla poster är inlästa ska det sista värdet på variablen skrivas in i tblNextId igen (uppdateras)
Har någon lite bra ideer på hur detta skulle kunna göras???
Henrik
byt intCounter mot lngID eller nått:
lngID = 0
set objRS = objConn.Execute("SELECT tblArticle FROM tblNextID")
if not objRS.EOF then
	lngID = clng(objRS(0))
objRS.Close : set objRS = nothing
, eller byt lngID i min kod mot intCounter om du inte orkar ändra i din andra kod.
Sedan är det bara att göra en update med lngID+1, men det fixar du.
mvh
ok, tack för det...
Ska testa!
Henrik
verkar funka finfint....
tackar!
Henrik
125 ms — deklarationer (db)
119 ms — ändringar (db)
