request("status") <> "" (dålig rubrik....)
10 svar · 256 visningar · startad av devotion
har följande kod för att visa uppdrag i en listmeny. Checkboxarna begränsar urvalet genom att ändra where-villkoret.
Dim objRS, objConn, strSQL, strStatus
If request("status") <> "" then
	strStatus = request("status")
Else
	strStatus = "0,1,2,3,4,5"
Response.write "<br>" & strStatus
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.ConnectionString = "DSN=uppdragNu"
objConn.Open
strSQL = "SELECT DISTINCT * " &_
		 "FROM tblTask " &_
		 "WHERE status in (" & strStatus & ") " &_
		 "ORDER BY taskNr"
Set objRS = Server.CreateObject("ADODB.Recordset")
objRS.Open strSQL, objConn, 3, 1
<form name="chooseStatus" method="post" action="chooseTask.asp">
	<table width="500" border="0" cellspacing="0" cellpadding="0">
	  <tr>
		<td width="67">Planerade</td>
		<td width="24"><input name="status" type="checkbox" id="planned" onClick="this.form.submit();" value="0" <%  If instr(request("status"), "0") <> "0" or request.form = "" then response.Write "checked" End if%>></td>
		<td width="74">Utskickade</td>
		<td width="25"><input name="status" type="checkbox" onClick="this.form.submit();" value="1" <%  If instr(request("status"), "1") <> "0" or request.form = "" then response.Write "checked" End if%>></td>
		<td width="64">Mottagna</td>
		<td width="25"><input name="status" type="checkbox" onClick="this.form.submit();" value="2" <%  If instr(request("status"), "2") <> "0" or request.form = "" then response.Write "checked" End if%>></td>
		<td width="64">P&aring;g&aring;ende</td>
		<td width="18"><input name="status" type="checkbox" onClick="this.form.submit();" value="3" <%  If instr(request("status"), "3") <> "0" or request.form = "" then response.Write "checked" End if%>></td>
		<td width="42">Klara</td>
		<td width="15"><input name="status" type="checkbox" onClick="this.form.submit();" value="4" <%  If instr(request("status"), "4") <> "0" or request.form = "" then response.Write "checked" End if%>></td>
		<td width="33">Fakt</td>
		<td width="49"><input name="status" type="checkbox" onClick="this.form.submit();" value="5" <%  If instr(request("status"), "5") <> "0" or request.form = "" then response.Write "checked" End if%>></td>
	  </tr>
	</table>
</Form>
<form name="chooseTaskForm" method="post" action=""><p><select name="taskList" size="10" id="TaskList">
      <% Do until ObjRS.EOF %>
      <option value="<% =objRS("TaskNr")%>">
      <% =objRS("TaskNr") & " " & objRS("customerName") & " "%>
      <%If Len(objRS("task")) > 30 then
	Response.Write left(objRS("task"),27) & "..."
Else
	Response.write objRS("task")
End If%>
      </option>
      <% objRS.Movenext %>
      <% Loop %>
    </select>
objRS.Close
Set objRS = Nothing
objConn.Close
Set objConn = Nothing
  </p>
  <p>
    <input name="choose" type="button" id="choose" onclick="makeChoice( this );" value="Välj!">
</p>
</html>
För att alla checkboxar ska vara ifyllda och att alla poster ska visas när fönstret öppnas har jag följande kod (ingår i koden ovanför)
Else
sen är tanken att man ska kunna begränsa urvalet genom att klicka bort checkboxarna. Det funferar ju fint till dess att man avmarkerat samtliga checkboxar. Då blir ju request("status") "" och alla poster visas i stället för inga. Jag fattar varför det blir så, men kan man göra på nått annat sätt???
Henrik
Med lite betänketid så kan man nog göra på något annat sätt, men en snabb lösning vore att lägga med ett hidden-fält som heter "status", innehållande något. Därmed blir aldrig request("status") tom när du submittar.
hmmm går verkligen det? Checkboxarna heter ju "status"
och
Henrik
Det är just därför som det går så bra.
Det enda du ska tänka på är att hoppa över hidden-värdet när du sparar informationen i databasen.
hmmmm, troligen fattar jag helt fel men jag gjorde som du sa, och la till ett hidden-fält som heter status och har värdet "1" problemet blir ju att den ettan hänger med i sql-satsen...
		 "FROM tblTask " &_
		 "ORDER BY taskNr"
då visas ju alltid uppdragen som har status "1"
help!!!!!
Henrik
Nejje. Inte "1"! Det är ju upptaget. Något annat, t.ex "0" :)
som sagt troligen är jag ju helt fel ute men om jag sätter hiddenfältet till "bäver så hamnar ju bäver i sql-satsen och då blir det ju helt fel....
Henrik
Vad sägs om att sätta värdet till..............."0"? ;)
jo, men har testat det.... men en av statusarna är just "0"....
Det bli galet!
Henrik
Men ta någon annan som inte används då... =)
hmmm ibland kan man vara bra trög.... Tack @nders för sparken i röven! och tack emission för ditt enkla men effektiva svar... (när jag tillslut fattat.....)
Jag satte hiddenfältet till "6" och vipps så funkar det...
Henrik
125 ms — deklarationer (db)
121 ms — ändringar (db)
