Hej
Jag har stora problem med att visa mina nyheter på det sätt jag vill.
Titta på denna bild så förstår ni hur jag vill att dom ska visas!
http://www.jettrocker.com/news.gif
db1 = Server.MapPath("data/nyheter.mdb")
db = Server.MapPath("data/nyheter.mdb")
Const perSida = 5
<%If Request.QueryString("do") = "" Then%>
<table width="600" align="center" cellpadding="3" cellspacing="0">
<%Set Conn = Server.CreateObject("ADODB.Connection")
Conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & db1
Sidan = Request.QueryString("sida")
If Sidan = "" then
sida = 1
Else
sida = Sidan
With RecSet
.CursorLocation = 3
.CacheSize = perSida
End With
If CStr(Request.QueryString("id")) <> "" Then
SQL = "SELECT * FROM nyheter Where id=" & Request.QueryString("id")
Else
SQL = "SELECT * FROM nyheter ORDER BY DATUM DESC"
RecSet.Open SQL, Conn%>
<tr>
<td colspan="2"><a href="admin.asp?do=login">admin</a> | <a href="index.asp">start</a></td>
</tr>
<tr>
<td colspan="2"><img src="pix.gif" width="600" height="10" border="0"></td>
</tr>
<tr>
<td height="14" valign="top"><b><font size="3"><%=RecSet("rubrik")%> </font></b></td>
<td valign="top">
<div align="right">
Session.LCID = 1033
Response.Write FormatDateTime(RecSet("datum"),1)
</td>
</tr>
<tr>
<td colspan="2" class="normal"><%=Replace(RecSet("nyhet"),vbCrLf,"<br>")%></td>
</tr>
<tr>
<td colspan="2" class="normal"><br>
Posted by <%=RecSet("skribent")%> on
Session.LCID = 1033
at <%=FormatDateTime(RecSet("datum"),3)%></td>
</tr>
<%If RecSet.EOF Then%>
<tr>
<td colspan="2">No Data!</td>
</tr>
<tr>
<td colspan="2"> </td>
</tr>
<%Else
RecSet.Close
With RecSet
.MoveFirst
.PageSize = perSida
.AbsolutePage = sida
End With
Sidor = RecSet.PageCount%>
<tr>
</tr>
<%Count = 0
Do While Not RecSet.EOF And Count < RecSet.PageSize
X = X + 1
If X Mod 2 = 0 then
color = ""
Else
color = "#33CCFF"
End If %>
<tr>
<%If Request.QueryString("sida") = "" Then%>
<td bgcolor="<%=Color%>"><a href="index.asp?id=<%=RecSet("id")%>"><%=RecSet("rubrik")%></a> </td>
<div align="right"><%=FormatDateTime(RecSet("datum"),1)%></div></td>
<%Else%>
<td bgcolor="<%=Color%>"><b>
<a href="index.asp?sida=<%=Request.QueryString("sida")%>&id=<%=RecSet("id")%>"><%=RecSet("rubrik")%></a></b></td>
<td bgcolor="<%=Color%>"><div align="right"><b><%=FormatDateTime(RecSet("datum"),1)%></b></div></td>
<%End If%>
</tr>
<%Count = Count + 1
RecSet.MoveNext
Loop
RecSet.Close
Set RecSet = nothing
End If%>
<%If Sidor > 1 Then%>
<tr>
<td colspan="2"><%If Sidor > 1 Then%>
Page
<%Else%> <%End If%> <%If Sidor <> 1 Then
For Sid = 1 To Sidor
If (Int(Sid)) = (Int(sida)) Then%>
<font color="#FF0000"><%=Sid%></font> <%Else%> <a href="index.asp?sida=<%=Sid%>"><%=Sid%></a> <%End If
Next
End If%> </td>
</tr>
<tr>
<td colspan="2">
<%End If%>
<%End If%>
</td>
</tr>
</table>
Jag har använt denna kod en gång i en gästbok för att visa 10 inlägg i taget så den kanske kan vara till någon hjälp:
If sida > 1 Then
Response.Write("<a href=""?NODE=7&page=" & sida - 1 & """>Previous 10 Entries</a> |")
Else
Response.Write("Previous 10 Entries |")
If sida < sidor Then
Response.Write("<a href=""?NODE=7&page=" & sida + 1 & """> Next 10 Entries</a>")
Else
Response.Write(" Next 10 Entries")
Finns det någon snäll människa som kan hjälpa till? :q
