nyheter+bild
0 svar · 269 visningar · startad av Krister
Medlem sedan okt. 200418 inlägg
Hej
Jag har ett scrip typ nyheter och skulle vilja att den som skriver in nyheterna även kan ladda upp en bild.
Var lägger man in "uploadscripet utan komponent" då Scriptet ser ut så här
<% response.buffer = true %>
<html>
<title>xx</title>
<style>
body, td { font-family: Verdana; color: black; font-size: 10px; }
.table { padding-bottom: 9pt; padding-right: 9pt; padding-top: 10pt; }
.div1 { padding-left: 9pt; padding-top: 9pt; }
.nav1 { padding-left: 9pt; color: white; }
.nav3 { padding-left: 9pt; color: black; font-size: 8pt; }
.nav2 {padding-right: 9pt; color: white; }
A { text-decoration: none; color: #113A67; }
</style>
<meta name="site-config-URL" content="http://localhost/config/">
<body bgcolor=white rightmargin=0 leftmargin=0 topmargin=0>
<table border=0 width=100% cellspacing=0 cellpadding=0>
<tr>
<td height=18 class=nav1 bgcolor="#2C5D92">Uppdatera din sida på ett lätt sätt</td>
</table>
if NOT (Session ("userAccess") = "granted") then
response.write ("<form action=admin.asp method=post>Användarnamn<input type=hidden name=openMethod value=logIn> <input type=text name=logIn size=10> ID pass <input type=password name=password size=10> <input type=submit value='LoggIn'> </form> ")
openMethod = request.form ("openMethod")
login = request.form ("login")
password = request.form ("password")
if openMethod = "logIn" and login = "XX" and password = "XX"  then
	response.redirect ("admin.asp")
<% if Session("userAccess") = "granted" then %>
<% page = request.queryString ("page") %>
'setting dsn connection
Set dc = Server.CreateObject("ADODB.Connection")
dc.Open "DBQ=" & Server.Mappath("database.mdb") & ";Driver={Microsoft Access Driver (*.mdb)};"
'this function provides encoding, but since it's used in the guestbook script, < and > is no longer converted to HTML
Function EncodeData(source)
result1 = source
result = ""
for i = 1 to len(result1)
resvalue=""
if mid(result1,i,1)="'" then resvalue=resvalue+"''"
if mid(result1,i,1)="|" then resvalue=resvalue+"¦"
if mid(result1,i,1)="&" then resvalue=resvalue+"&"
if mid(result1,i,1)="""" then resvalue=resvalue+"""
if mid(result1,i,1)=chr(13) then resvalue=resvalue+"<br>"
if resvalue<>"" then result = result + resvalue else result = result + Mid(result1, i, 1)
next
EncodeData = result
End Function
'this code writes all the modifications to the database
action=request.queryString("action")
'we need to know what message should we deal with
msgId = request.queryString("msgId")
if action="submit" or action="delete" then
'gets the data from the form
USER_MESSAGE = request.Form("USER_MESSAGE")
USER_NAME = request.Form("USER_NAME")
'converts the data to HTML format using the EncodeDara function
'since DB fields can't be zero-length, in case they're empty, we'll set them to " "
USER_MESSAGE = EncodeData(USER_MESSAGE)
USER_NAME = EncodeData(USER_NAME)
'opens the database and writes data to it
select case action
case "delete"
SQLCOMMAND = "DELETE GBOOK.* FROM GBOOK WHERE (id = "& msgId &");"
DC.EXECUTE(SQLCOMMAND)
case "submit"
MYSQL = "SELECT GBOOK.* FROM GBOOK WHERE (id = " & msgId & ")"
rs.Open MYSQL, dc, 1, 3
rs.Fields("USER_NAME") = USER_NAME
rs.Fields("USER_MAIL") = USER_MAIL
rs.Fields("USER_CITY") = USER_CITY
rs.Fields("USER_URL") = USER_URL
rs.Fields("USER_MESSAGE") = USER_MESSAGE
rs.Update
end select
if action="modify" then
msgId = request.queryString ("msgId")
MYSQL = "SELECT GBOOK.* FROM GBOOK WHERE (id = "& msgId &")"
rs.Open MySQL, dc, 3, 1
<form action="/uppdatera/orum/admin.asp?action=submit&msgId=<%=msgId%>" method="post">
<table align=center border=0 cellspacing=0 cellpadding=0 width="317">
</tr>
<tr> <td valign=top width="52"><strong><b>Rubrik:</b></td><td align=right width="265"><textarea cols=30 rows=4 name=USER_NAME wrap=virtual><%=rs("USER_NAME")%></textarea></td> </tr>
</strong><br>
<tr> <td valign=top width="52"><b>Nuvarande text:</b></td><td align=right width="265"><textarea cols=30 rows=4 name=USER_MESSAGE wrap=virtual><%=rs("USER_MESSAGE")%></textarea></td> </tr>
<tr> <td width="52"> </td>
<td height=50 valign=bottom align=right width="265"><input type=submit value="ändra" onclick="return confirm('Nu är Ditt meddelande ändrat');"></td> </tr>
</table>
</br>
rs.Close
<table class=nav1 width=100% border=0 cellspacing=0 cellpading=0> <tr> <td colspan=6 height=18> </td> </tr> <tr bgcolor=#2C5D92>
<td height=18 class=nav1>Nuvarande text</td>
<td height=18 class=nav1 width=60 align=center>välj</td> </tr> </table>
<table class=nav3 width=100% border=0 cellspacing=0 cellpading=0>
MYSQL = "SELECT ID, USER_MAIL, USER_NAME, USER_DATE, USER_CITY, USER_MESSAGE FROM GBOOK ORDER by ID DESC"
<% Do While (Not rs.EOF) %>
<tr><td colspan=6 height=18> </td></tr>
<tr><td height=18 class=nav3 width=122><% if len(rs("USER_DATE")) > 10 then %> <% = (left(rs("USER_DATE"),10) & "") %> <% else %> <% = (rs("USER_DATE")) %> <% End If %></td> <td height=18 class=nav3><% if len(rs("USER_NAME")) > 12 then %> <% = (left(rs("USER_NAME"), 30) & "...") %> <% else %> <% = (rs("USER_NAME")) %> <% End If %></td> <td height=18 class=nav3 width=100><a href='mailto: <%=rs("USER_MAIL")%>'><% if len(rs("USER_MAIL")) > 15 then %> <% = (left(rs("USER_MAIL"), 15) & "...") %> <% else %> <% = (rs("USER_MAIL")) %></a> <% End If %></td> <td height=18 class=nav3><% if len(rs("USER_MESSAGE")) > 40 then %> <% = (left(rs("USER_MESSAGE"), 40) & "...") %> <% else %> <% = (rs("USER_MESSAGE")) %> <% End If %></td>
<td height=18 class=nav3 width=60 align=center>T<a href='/././admin.asp?action=delete&msgId=<%=rs("ID")%>' name=msg<%=rs("ID")%> onclick="return confirm('Är du säker på att du ska ta borta detta?');">a bort </a><br><a href='/uppdatera/orum/admin.asp?action=modify&msgId=<%=rs("ID")%>'>Redigera</a><br>
<a href="/././gbook1.asp">Lägg till</a></td>
</tr>
rs.MoveNext
Loop
</table>
rs.Close
Set rs = Nothing
dc.Close
Set dc = Nothing
<% End If %>
<tr>
<td height=18 class=nav1 bgcolor="#2C5D92" ></td>
<td align=right height=18 class=nav2 bgcolor="#2C5D92"><% = formatDateTime(now, 1) %></td>
</tr>
</table>
</html>
270 ms totalt · 4 externa anrop · v20260731065814-full.868a69e5
129 ms — deklarationer (db)
129 ms — ändringar (db)
