Hjälp :-(
ASPur ASP
12 svar · 296 visningar · startad av jboy_87
jboy_87Medlem sedan aug. 20011 099 inlägg
vad är det för fel på koden!!!
On Error Resume Next
'  Variables
   Dim mySmartUpload
   Dim file
   Dim oConn
   Dim oRs
   Dim intCount
   Dim ConnectString, conn
   Dim ID
   intCount=0
'  Object creation
   Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
   mySmartUpload.AllowedFilesList = "jpg,gif"
   mySmartUpload.MaxFileSize = 500000
'  Upload
   mySmartUpload.Upload
'  Connect to the DB
   Set oConn = Server.CreateObject("ADODB.Connection")
   pictures = Server.MapPath("siteusers.mdb")
   oConn.Open "DBQ="& pictures &";Driver={Microsoft Access Driver (*.mdb)};DriverId=25;FIL=MS Access;"
'ConnectString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("etellerandet.mdb")
'Set conn = Server.CreateObject("ADODB.Connection")
'conn.open ConnectString," & pictures & "
'DBQ="& pictures &";Driver={Microsoft Access Driver (*.mdb)};DriverId=25;FIL=MS Access;"
'  Open a recordset
   strSQL = "SELECT FILENAME,FILE,username,ID FROM users WHERE username = '" & username & "'"
   Set oRs = Server.CreateObject("ADODB.recordset")
   Set oRs.ActiveConnection = oConn
   oRs.Source = strSQL
   oRs.LockType = 3
   oRs.Open
'  Select each file
   For each file In mySmartUpload.Files
   '  Only if the file exist
      If not file.IsMissing Then
      '  Add the current file in a DB field
	 oRs.Update
         file.FileToField oRs.Fields("FILE")
		 oRs("FILENAME") = username &  file.FileName
         oRs.Update
         file.SaveAs("d:\hjemmeside\pictures\" &   username   & file.filename)
	 intCount = intCount + 1
   Next
'  Display the number of files uploaded
   Response.Write(intCount & " file(s) uploaded.<BR>")
'  Destruction
   oRs.Close
   oConn.Close
   Set oRs = Nothing
   Set oConn = Nothing
If Err Then
      Response.Write("<b>Your Picture is of the wrong kind of type please go back and correct the problem: Only .Jpg and .Gif is allowed !If your think its webmaster´s failure then mail him att: <a href='mailto:webmaster@d-soft.dk?subject=LOGIN FAILURE'><h3>WEBMASTER</h3> </b><br><a href='javascript:self.history.go(-1)'><b><font color='red' font size='2'>Please go back and try again</b></font>" )
	Response.write ("<b><font size ='2' font color='blue'>Youe have uploaded your picture with success please click below to enter your profile</b></font><br><a href=profile.asp><b><font color='red' font size='2'>Back to profile :-)</b></font>")
'Response.Redirect("profil.asp?updated=true")
ASP är bäst fuck the rest!!!
Ehrm...vad går snett?
cyprysMedlem sedan dec. 20003 563 inlägg
Vore trevligt om du berättade vad felet är först.
MVH // Cyprys
Cyprys
Synd att du inte kan köpa en voodoojordglob och sedan snurra på den fort som fan och skrämma skiten ur alla.
Vad får du för felmedelande?
kolung.....det tål att tänkas på!
0 file(s) uploaded.
Ta bort On Error resume next och säg om den säger något vettigt då
MVH // Cyprys
Cyprys
nu får jag detta:
aspSmartUpload (0x800A0035)
File not found: aspsmartuploadutil.dll
/communities/dating system/Sample.asp, line 24
när jag tog bort on error resume next
har fixat skiten!!!
Det är bra om du skriver hur du gjorde så andra kan lära sig av dina misstag ;)
hahaha okej registrerade aspuploadutil.dll
hur får jag det hära och bli så här i databasen
Bilder/medlemmar/bla bla.hkjhjh
[Redigerat av jboy_87 den 19 dec 2001]
har fixat
133 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
