External Database
5 svar · 186 visningar · startad av Organick
OrganickMedlem sedan okt. 200120 inlägg
How do i make a connection to an External database? Or is it possible?
Hi!
Define external, is the database on the same server? What DB are you using?
Mostly Harmless
OK sorry! :)
It's a MSAccess Database and is on an other server.
Is the server on the same network, so you can access it throught the file system?
Mostly Harmless
I am afraid not.
The ASP-script is localized on a server in Faroe Islands and the MSAccess database is placed on a server in Denmark.
Please say it is possible. :)
I have no experience getting data from a server that not is on the network, and i don't think it is possible (please prove me wrong ;)), but, by creating a web service on the server that has the database, which returns an xml-string you could get the data via the http-protcol. But i don't think it would be very efficient though...
Maby a search on MSDN would give you the answer you are seeking... :)
Mostly Harmless
