AddaText..
3 svar · 162 visningar · startad av pleXnet
pleXnetMedlem sedan dec. 20011 inlägg
i default.asp --->
<font face="verdana" size="1">
<b>Besökarnas text</b><br><br>
</font>
Conn.Open "driver={Microsoft Access Driver (*.mdb)};dbq=" &Server.MapPath("databas.mdb")
SQL = "SELECT * FROM tabell ORDER by id desc"
RecSet.Open SQL, Conn, adOpenStatic, adLockOptimistic
<table border="0" width="200"><tr><td><font face="verdana" size="1">
<i><% = RecSet("text") %></i><br><br>
<img src="skrivet.gif"> <a href="mailto:<% = RecSet("epost") %>"><% = RecSet("namn") %></a>
RecSet.Close
Conn.Close
</font>
</td></tr></table>
<p>
<b>Skriv ett par rader!</b><br><br>
<form name="form1" method="post" action="add.asp?vad=add">
<table width="210" border="0" cellspacing="0" cellpadding="0">
  <tr>
    <td width="60"><font face="verdana" size="1">Namn:</font></td>
    <td width="100"><input name="namn" size="15"></td>
  </tr>
  <tr>
    <td width="60"><font face="verdana" size="1">Epost:</font></td>
    <td width="100"><input name="epost" size="15"></td>
  </tr>
  <tr>
    <td width="60"><font face="verdana" size="1">Text:</font></td>
    <td width="100"><input name="text" size="15" maxlength="75"></td>
  </tr>
  <tr>
    <td colspan="2"><br><input type="submit" value="Skicka"> <input type="reset" value="Rensa"></td>
  </tr>
</table>
</font>
i add.asp --->
<% Response.Buffer = True %>
<!-- #include file = "adovbs.inc" -->
If NOT session("today") = "Sj47Yts45Wj" then
If request.querystring("vad") ="add" Then
Conn.Open "driver={Microsoft Access Driver (*.mdb)};dbq=" & Server.MapPath("databas.mdb")
SQL = "Select * From tabell"
RecSet.AddNew
RecSet("namn") = Request.Form("namn")
RecSet("epost") = Request.Form("epost")
RecSet("text") = Request.Form("text")
RecSet.Update
RecSet.Close
Conn.Close
Set RecSet = nothing
Set Conn = nothing
Response.Redirect "default.asp"
END IF
ELSE
Response.Write "Tyvärr, du har redan lagt till en länk idag!"
END IF
/ pleXnet
[Redigerat av pleXnet den 17 dec 2001]
icaaqMedlem sedan okt. 20004 910 inlägg
RecSet.AddNew
RecSet.Update
RecSet.Close
Conn.Close
Set Conn = nothing
END IF
Du kan ju testa så här......
Och vad plexNet undrade var om man kan ta bort så att man adda hur mycket text man ville.....
kolung.....det tål att tänkas på!
Välkommen till wf
Vad är problemet?
Just ja Välkommen till wF :e
Genererad på 371 ms · cache AV · v20260730165559-full.f96bc7eb
