Funktionen som ger klickbara länkar fungerar inte längre.
4 svar · 282 visningar · startad av Oputres
Medlem sedan feb. 2004333 inlägg
Allå!
Så här ser min asp-fil med funktioner ut:
'------------------------------------------------------------- SKAPA KLICKBARA LÄNKAR
Function Visa(s)
On error resume next
Set objRE = new RegExp
objRE.IgnoreCase = True : objRE.Global = True
objRE.Pattern = "(http:\/\/|www\.)(\w|\&|\:|\;|\.|\/|\?|\~|\=|-)+"
Set m = objRE.Execute(s)
For Each o In m
If Right(o.Value, 1)="." Or Right(o.Value, 1)="!" Or Right(o.Value, 1)="?" Or Right(o.Value, 1)="," Then
If Left(o.Value, 3) = "www" Then s = Replace(s, o.Value, "<A HREF=""http://" & Left(o.Value, Len(o.Value)-1) & """ target=""_blank"">" & Left(o.Value, Len(o.Value)-1) & "</A>" & Right(o.Value, 1)) Else s = Replace(s, o.Value, "<A HREF=""" & Left(o.Value, Len(o.Value)-1) & """>" & Left(o.Value, Len(o.Value)-1) & "</A>" & Right(o.Value, 1))
Else
If Left(o.Value, 3) = "www" Then s = Replace(s, o.Value, "<A HREF=""http://" & o.Value & """ target=""_blank"">" & o.Value & "</A>") Else s = Replace(s, o.Value, "<A HREF=""" & o.Value & """ target=""_blank"">" & o.Value & "</A>")
Next
Set objRE = Nothing
'----------- Tillåten HTML kod
'[B][ och ] är bytt mot ( och ) eftersom forumet annars tolkar koden[/B]
s = Replace(s, "(B)", "<b>")
s = Replace(s, "(/B)", "</b>")
s = Replace(s, "(I)", "<i>")
s = Replace(s, "(/I)", "</i>")
s = Replace(s, "(U)", "<u>")
s = Replace(s, "(/U)", "</u>")
s = Replace(s, vbCrLf, "<br>")
s = Replace(s,"","") '[B]Denna rad skall ersätta en fyrkant, vilket inte syns i forumet[/B]
Visa = s
End Function
'------------------------------------------------------------- KONVERTERA FORM-INNEHÅLL FÖR DB-UPPDATERING
Function Uppdatera(sfix)
sfix = Replace(Trim(sfix), "'", "''")
sfix = Replace(sfix, "|", "")
Uppdatera = sfix
End Function
'------------------------------------------------------------- KORTA NER EN TEXT
Function WordLeft(strText, intNoOfWords)
	Dim arrText, strippedText, I
	arrText = Split(strText, " ")
	If UBound(arrText) => intNoOfWords Then
		For I = 0 To (intNoOfWords - 1)
			If i = (intNoOfWords - 1) Then
				strippedText = strippedText & arrText(i) & "..."
			Else
				strippedText = strippedText & arrText(i) & " "
			End if
		Next
	Else
		strippedText = strText
	WordLeft = strippedText
End Function
Jag länkar in den med:
<!-- #include file="inst/funktioner.asp" -->
...och skriver så här för att nyttja funktionen Visa() som bör ge klickbara länkar och ersätter med <b>:
If Not RS.EOF Then
  strPresentation = RS("Presentation")
  If Len(strPresentation) > 0 Then
    Response.Write Visa(Server.HTMLEncode(strPresentation))
Alla HTML-formateringar fungerar som de skall, dock ej funktionen som skall ge klickbara länkar. Den har tidigare fungerat på andra hemsidor men jag har nu lagt in flera funktioner (html-konventeringen har dock alltid funnits där, fast den har nu utökats) och bara bytt namn på den. Hittar ni något fel?
Medlem sedan jan. 2000978 inlägg
Jag tycker dina IF-satser ser väldigt konstiga ut i visa-funktionen. Kolla igenom dom noga för du har troligen glömt minst ett endif.
Eller så har du klistrat in dom fel. ;)
Medlem sedan jan. 2003438 inlägg
Testade precis din kod, hittar inget fel.
Har du lust att kopiera in texten "strPresentation", om den är väldigt lång så kan du korta ner den en aning.
En liten kort fråga, länkarna är av rätt format?
https://www.webforum.nu
http://www.webforum.nu
strPresentation bara av en testtext, bl.a. med länkarna:
http://www.monstrum.se
https://www.monstrum.se
Ingen av dem blir klickbara. Grejen är ju att funktionerna tidigare har fungerat på en annan sida. Kan det ha att göra med mina includes?
När man anropar default.asp inkluderas funktioner.asp och man skickas vidare till default.asp?Sida=Start vilken inkluderar start.asp där funktionerna körs. Fast det faktum att alla funktioner på sidan fungerar förbryllar ju något.
Ta bort on error resume next.
Det går ju inte att felsöka om man inte får några felmeddelanden...
253 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
119 ms — deklarationer (db)
118 ms — ändringar (db)
