<a href="blogga_las.asp?UserID=<%=request.querystring("UserID")%>&do=rosta&ID=<%=request.QueryString("ID")%>&rosta=5">5</a>
Sådär ser en länk ut..
SQL = "SELECT * FROM blogg Where intAnvID = "&request.querystring("UserID")&""
set RS2 = Connect.Execute(SQL)
När jag klickar på länken får jag felmesset:
ADODB.Recordset.1 (0x80004005)
SQLState: 4 Native Error Code: 1064 [TCX][MyODBC]You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
/com/blogga_las.asp, line 18
Hatar detta fel..
