JMail - Vad skall fixas...
0 svar · 134 visningar · startad av Robson
Medlem sedan dec. 2001200 inlägg
för att den skall lista alla mailen i inkorgen. Tacksam för svar.
Set pop3 = Server.CreateObject( "JMail.POP3" )
pop3.Connect "userid", "password", "my@mailserver.com"
Response.Write( "You have " & pop3.count & " mails in your mailbox!<br><br>" )
if pop3.count > 0 then
Set msg = pop3.Messages.item(1) ' Note the first element of this array is 1
' since the POP3 server starts counting at 1
ReTo = ""
ReCC = ""
Set Recipients = msg.Recipients
separator = ", "
' We now need to get all the recipients,
' both normal and Carbon Copy (CC) recipients
' and store them in a variabel
For i = 0 To Recipients.Count - 1
	If i = Recipients.Count - 1 Then
		separator = ""
	Set re = Recipients.item(i)
	If re.ReType = 0 Then
		ReTo = ReTo & re.Name & "&nbsp;(\<a href=""mailto:"& re.EMail &"""\>" & re.EMail & "\</a\> )" & separator
		ReCC = ReTo & re.Name & "&nbsp;(\<a href=""mailto:"& re.EMail &"""\>" & re.EMail & "\</a\> )" & separator
Next
' This function iterates through the Attachments object,
' and saves the attachment to the server's disk.
' It also returns a nicely formatted string with a
' link to the attachment.
Function getAttachments()
  	Set Attachments = msg.Attachments
  	separator = ", "
  	For i = 0 To Attachments.Count - 1
		If i = Attachments.Count - 1 Then
			separator = ""
	 	Set at = Attachments(i)
	 	at.SaveToFile( "c:\\EMail\\attachments\\" & at.Name )
	 	getAttachments = getAttachments & "\<a href=""/EMail/attachments/" & at.Name &"""\>" &\_
	 						at.Name & "(" & at.Size  & " bytes)" & "\</a\>" & separator
  	Next
End Function
\<html\>
  \<body\>
	\<TABLE\>
	  \<tr\>
		\<td\>Subject\</td\>
		\<td\>\<%= msg.Subject %\>\</td\>
	  \</tr\>
	  \<tr\>
		\<td\>From\</td\>
		\<td\>\<%= msg.FromName %\>\</td\>
	  \</tr\>
	  \<tr\>
		\<td\>Recipients To\</td\>
		\<td\>\<%= ReTO %\>\</td\>
	  \</tr\>
	  \<tr\>
		\<td\>Recipients CC\</td\>
		\<td\>\<%= ReCC %\>\</td\>
	  \</tr\>
	  \<tr\>
		\<td\>Attachments\</td\>
		\<td\>\<%= getAttachments %\>\</td\>
	  \</tr\>
	  \<tr\>
		\<td\>Body\</td\>
		\<td\>\<pre\>\<%= msg.Body %\>\</pre\>\</td\>
	  \</tr\>
	\</TABLE\>
  \</body\>
\</html\>
pop3.Disconnect
288 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
132 ms — deklarationer (db)
151 ms — hämta tråd, inlägg och bilagor (db)
124 ms — ändringar (db)
