vet inte om det hjälper dig, men så här ser min global.asa ut:
<SCRIPT LANGUAGE="VBScript" RUNAT="Server">
ReDim TopicName(0)
ReDim TopicDescription(0)
Sub Application_OnStart
' Set our user count to 0 when we start the server
Application("ActiveUsers") = 0
Application("active_users")=""
' set title
Application("Title") = "ASP Chat"
' Create your chat rooms below, do not modify anything else/
CreateRoom "Data", "Diskutera data"
CreateRoom "Kärlek", "Kärleksnästet"
CreateRoom "Allmän", "Allt mellan himmel och jord"
CreateRoom "Sport", "Sportfånar"
'CreateRoom "Room Name", "Room Description"
Application("TopicNames") = TopicName
Application("TopicDescriptions") = TopicDescription
Dim Users()
Redim Users(1)
Dim UsersGroup()
Redim UsersGroup(1)
Application("Users") = Users
Application("UsersGroup") = UsersGroup
Dim UsersIP()
Redim UsersIP(1)
Dim UsersTimeOn()
Redim UsersTimeOn(1)
Dim UsersIdleOn()
Redim UsersIdleTime(1)
Application("UsersIP") = UsersIP
Application("UsersTimeOn") = UsersTimeOn
Application("UsersIdleTime") = UsersIdleTime
End Sub
Sub Session_OnStart
Session("Usname")=""
' Change Session Timeout to 20 minutes (if you need to)
Session.Timeout = 10
' Set a Session Start Time
' This is only important to assure we start a session
Session("Start") = Now
' Increase the active visitors count when we start the session
Application.Lock
Application("ActiveUsers") = Application("ActiveUsers") + 1
Application.UnLock
End Sub
Sub Session_OnEnd
' Decrease the active visitors count when the session ends.
Application.Lock
Application("ActiveUsers") = Application("ActiveUsers") - 1
Application.UnLock
un=Session("Usname")
if un<>"" and Application("active_users")<>"" then
tmp=Application("active_users")
idx=instr(tmp,un & "*")
tmp2=left(tmp,idx-1) & right(tmp,len(tmp)-idx-len(un))
Application("active_users")=tmp2
Topic = Session("Topic")
Name = Session("Name")
Users = Application("Users")
UsersIP = Application("UsersIP")
UsersTimeOn = Application("UsersTimeOn")
UsersIdleTime = Application("UsersIdleTime")
Match = 1
If IsArray(Users) Then
UsersGroup = Application("UsersGroup")
NumOfUsers = UBound(Users)
If NumOfUsers = 1 Then
Set Application("Users") = Nothing
Set Application("UsersGroup") = Nothing
Set Application("UsersIP") = Nothing
Set Application("UsersIdleTime") = Nothing
Set Application("UsersTimeOn") = Nothing
Else
ReDim UpdatedUsers(1)
ReDim UpdatedUsersGroup(1)
ReDim UpdatedUsersIP(1)
ReDim UpdatedUsersTimeOn(1)
ReDim UpdatedUsersIdleTime(1)
For I = 1 To NumOfUsers
If Name <> Users(I) Then
ReDim Preserve UpdatedUsers(Match)
ReDim Preserve UpdatedUsersGroup(Match)
UpdatedUsers(Match) = Users(I)
UpdatedUsersGroup(Match) = UsersGroup(I)
ReDim Preserve UpdatedUsersIP(Match)
ReDim Preserve UpdatedUsersTimeOn(Match)
ReDim Preserve UpdatedUsersIdleTime(Match)
UpdatedUsersIP(Match) = UsersIP(I)
UpdatedUsersTimeOn(Match) = UsersTimeOn(I)
UpdatedUsersIdleTime(Match) = UsersIdleTime(I)
Match = Match + 1
Next
Application("Users") = UpdatedUsers
Application("UsersGroup") = UpdatedUsersGroup
Application("UsersIP") = UpdatedUsersIP
Application("UsersTimeOn") = UpdatedUsersTimeOn
Application("UsersIdleTime") = UpdatedUsersIdleTime
Set fileObject = Server.CreateObject("Scripting.FileSystemObject")
textFile = Application("filebase") & Replace(Topic, "+", "_") & ".txt"
'If fileObject.FileExists(textfile) Then
Set inStream = fileObject.OpenTextFile(textFile,1,TRUE,FALSE)
file = inStream.ReadAll
Set inStream = Nothing
file = file & "<FONT SIZE=2 FACE='Vedana,Arial' Color=#808080><b>***[" & Name & " has exited (" & Now & ")]***</b></FONT><br>"
Set outStream = fileObject.CreateTextFile(textFile,True)
outStream.WriteLine(file)
outStream.Close
Set outStream = Nothing
'End If
Session("Enter") = True
End Sub
Sub CreateRoom(Name, Description)
nLen = UBound(TopicName)+1
ReDim Preserve TopicName(nLen)
TopicName(nLen) = Name
ReDim Preserve TopicDescription(nLen)
TopicDescription(nLen) = Description
End Sub
</SCRIPT>
har onlineräknare och chat, mina chatrum är iofs nere nu, men det beror inte på global.asa utan lathet :e
Säg till om du vill ha mer beskrivning av hur du ska visa antalet online, chatrum mm, så svarar jag imorrn, när jag inte e så trött :e
Data-Doktorn
Min egen musik!
Mitt coverband
