Vad menar du med att den inte kan ladda? Vad är det med utskriften som blir fel?
Försöker kolla sidan "skarpt"
<html>
<title>P93s Gästbok</title>
<style TYPE="text/css"><!--
a:link {color:#FFcc00; text-decoration: underline
a:visited {color:#FFcc00; text-decoration: none}
a:active {color:#FFcc00; text-decoration: underline}
a:hover {color:#000080; text-decoration: none}
--></style>
<style type="text/css">
.style2 {color: #FFCC00}
.style3 {color: #FFCC00; font-size: xx-large; }
.style4 {color: #FFCC00; font-size: large; }
.style5 {font-size: xx-large}
.style6 {font-size: large}
.style7 {color: #FFCC00; font-size: medium; }
</style>
<% dim minCon 'Connection
dim rsGbok 'recordsetten för nya inlägg
dim strSQL
dim indag, dat
Session.LCID = 1053
function fix(S)
if S > 2 AND S <= 20 then
fix = S & "e"
Else
if S > 23 AND S <= 30 then
fix = S & "e"
Else
fix = S & "a"
end function
'byta ut första bokstaven
Function FirstVersal(txt)
versal = UCase(Left(txt,1)) & LCase(Right(txt, Len(txt)-1))
FirstVersal = versal
End Function
<body><img src="images/spifbanner.jpg" width="742" height="170">
<table width="740" border="0">
<tr>
<td width="182" height="63" scope="col"><img src="images/pojkar100.jpg" width="175" height="75"></td>
</td>
<TD nowrap bgcolor="#0000FF"> <span class="style4">Gästbok </span>
<a href="p93_skriv.asp" target="_blank" class="style7">Skriv nya inlägg</a></TD>
</tr>
</table>
<%Set minCon = Server.CreateObject("ADODB.Connection")
set rsGbok = Server.CreateObject("ADODB.Recordset")
minCon.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("\spifbasket\db\guests.mdb")
strSQL =" SELECT * FROM guestbook ORDER by ID DESC"
rsGbok.Open strSQL, minCon, 3, 3
Do While Not rsGbok.EOF
//'eftersom sidan ligger på en amerikansk server så har vi 6 timmars tidsdifferens
indag = Cdate(rsGbok("Datum"))
vdag = DateAdd("h",6,indag)
dat = FirstVersal(WeekDayName(WeekDay(vdag)))&"en "& " den " & fix(DatePart("d", vdag)) & " " & MonthName(Month(vdag)) &" kl " & FormatDateTime(vdag,4)
Response.Write "<P>" & dat & " skrevs följande:</P>"
//' i VBScript kan man inte använda sig utav radbrytningar därför behövs följande: Replace(rsGbok("Message"), vbCrLf, "<br>" & vbCrLf)
Response.Write "<P><B><FONT SIZE=""4""><I>" & Replace(rsGbok("Message"), vbCrLf, "<br>" & vbCrLf) & "</I></FONT></B></P><BR><B><U>"
Response.Write " av:"
Response.Write "</U></B> " & rsGbok("Namn")
Response.Write "<BR><A HREF=""mailto:" & rsGbok("Epost") & """>Skicka insändaren E-post: </A>"
Response.Write "<P></P><P></P><HR></HR>"
rsGbok.MoveNext
Loop
rsGbok.Close
Set rsGbok = Nothing
minCon.Close
Set minCon = Nothing
</html>
Brinkster kan ej ladda - utan fel utskrift
Samma sak med
<html>
<title>skriv</title>
--></style>
</style>
<tr>
</td>
<TD nowrap bgcolor="#0000FF"> <span class="style4">Skriv i gästboken </span></TD>
</tr>
</table>
namn = trim(Request.Form("namn"))
Epost = trim(Request.Form("mail"))
Message = trim(Request.Form("message"))
if namn = "" or Epost = "" or Message = "" then
if request.form("skriv") <> "" then response.write "Du måste fylla i alla fält<br>"
<table width="710" border="1" align="center" bordercolor="#FFFFFF" bgcolor="#0000FF">
<tr>
<td><form name="skriv" method="post" action="p93_skriv.asp?cmd=Send">
<p><br>
<span class="style2">Namn:</span><br>
<input type="text" name="namn" size="50" value="<%=Server.htmlencode(namn)%>">
</p>
<p><span class="style2">E-post</span><br>
<input type="text" name="mail" size="50" value="<%=Server.htmlencode(Epost)%>">
</p>
<p><span class="style2">Meddelande:</span><br>
<textarea name="message" cols="70"><%=Server.htmlencode(Message)%></textarea>
<p align="right">
<input type="submit" name="skriv" value="Lägg till">
</td>
</tr>
</table>
if namn <> "" and Epost <> "" and Message <> "" then
Set gbok = Server.CreateObject( "Adodb.Connection" )
gbok.Provider = "Microsoft.Jet.OLEDB.4.0"
MdbFilePath = Server.MapPath("\spifbasket\db\guests.mdb")
gbok.ConnectionString = "Data Source='" & MdbFilePath & "'"
gbok.open
strSQL = "INSERT INTO guestbook(namn, Epost, Message, Datum) VALUES('" & namn & "','" & Epost & "','" & Message & "','" & now() & "')"
gbok.Execute( strSQL )
Set gbok = Nothing
Response.Redirect "p93_gbok.asp"
</html>
