Behöver hjälp att lägga in...
0 svar · 100 visningar · startad av Javawebb
Medlem sedan nov. 20019 inlägg
Kan inte så mycket asp men nu behöver jag hjälp med att lägga in så att man kan ta bort filer i en mapp. detta är ett upload script som laddar upp filer till en mapp så nu vill jag också att man ska kunna ta bort filer, men vet inte hur jag ska göra.
<% @EnableSessionState = False %>
<% Option Explicit %>
<% Response.Expires = 0 %>
Dim UPLOAD_PATH
UPLOAD_PATH = Server.MapPath("upload")
Dim g_oFso, g_oFolder, g_oFile
	Set g_oFso	= Server.CreateObject("Scripting.FileSystemObject")
	Set g_oFolder	= g_oFso.getFolder(UPLOAD_PATH)
If (Request.ServerVariables("REQUEST_METHOD") = "POST") Then
	Dim g_oUpload
		Set g_oUpload	= get_upload_files()
	Dim fpos, fcontent
		fcontent	= g_oUpload("upload").Item("content")
	Set g_oFile	= g_oFso.CreateTextFile(UPLOAD_PATH & "\\" & extract_filename(g_oUpload("upload").Item("filename")))
	For fpos = 1 to LenB(fcontent)
		g_oFile.Write chr(AscB(MidB(fcontent, fpos, 1)))
	Next
	g_oFile.Close: Set g_oFile	= Nothing
	Response.Redirect Request.ServerVariables("SCRIPT_NAME")
Response.Write "\<html\>\<body\>\<table\>"
Response.Write "\<tr\>\<td\>\<hr\>\</td\>\</tr\>"
For Each g_oFile In g_oFolder.Files
	Response.Write "\<tr\>\<td\>\<a href=""upload/" & g_oFile.Name & """\>" & g_oFile.name & "\</a\>\</td\>\</tr\>"
Next
Response.Write "\<tr\>\<td align=""right""\>\<form name=""frmUpload"" method=""post"" enctype=""multipart/form-data"" action=""" & Request.ServerVariables("SCRIPT_NAME") & """\>"
Response.Write "\<input type=""file"" name=""upload""\> &nbsp; \<input type=""submit"" value=""Ladda upp""\>\</td\>\</tr\>"
Response.Write "\</table\>\</body\>\</html\>"
Function get_upload_files()
Dim upload_object, request_binaries
Dim position_start, position_end
Dim boundary, boundary_pos
	Set upload_object	= Server.CreateObject("Scripting.Dictionary")
	request_binaries	= Request.BinaryRead(Request.TotalBytes)
	position_start		= 1
	position_end		= InstrB(position_start, request_binaries, get_byte_string(chr(13)))
	boundary			= MidB(request_binaries, position_start, (position_end - position_start))
	boundary_pos		= InstrB(1, request_binaries, boundary)
	Do Until (boundary_pos = InstrB(request_binaries, boundary & get_byte_string("--")))
		If Not(Response.IsClientConnected) Then Response.End
		Dim name, pos_file
		position_start	= (InstrB(InstrB(boundary_pos, request_binaries, get_byte_string("Content-Disposition")), request_binaries, get_byte_string("name=")) + 6)
		position_end	= InstrB(position_start, request_binaries, get_byte_string(chr(34)))
		name			= get_string(MidB(request_binaries, position_start, (position_end - position_start)))
		pos_file		= InstrB(boundary_pos, request_binaries, get_byte_string("filename="))
		If  ((pos_file \<\> 0) AND (pos_file \< InstrB(position_end, request_binaries, boundary))) Then
			upload_object.Add name, Server.CreateObject("Scripting.Dictionary")
			position_start	= (pos_file + 10)
			upload_object.item(name).Add "filename", get_string(MidB(request_binaries, position_start, (position_end - position_start)))
			position_start	= (InstrB(position_end, request_binaries, get_byte_string("Content-Type:")) + 14)
			upload_object.item(name).Add "content-type", get_string(MidB(request_binaries, position_start, (position_end - position_start)))
			position_start	= (position_end + 4)
			position_end	= InstrB(position_start, request_binaries, boundary) - 2
			upload_object.item(name).Add "size", ((position_end - position_start))
			upload_object.item(name).Add "content", MidB(request_binaries, position_start, (position_end - position_start))
		boundary_pos	= InstrB(boundary_pos + LenB(boundary), request_binaries, boundary)
	Loop
	Set get_upload_files = upload_object
End Function
Function get_byte_string(str)
	Dim cnt
	For cnt = 1 to Len(str)
		get_byte_string	= get_byte_string & chrB(AscB(Mid(str, cnt, 1)))
	Next
End Function
Function get_string(str)
	Dim cnt
	For cnt = 1 to LenB(str)
		get_string	= get_string & chr(AscB(MidB(str, cnt, 1)))
	Next
End Function
Function extract_filename(filename)
	extract_filename	= Right(filename, Len(filename) - InStrRev(filename, "\\", -1, 1))
End Function
Här är all kod! Hoppas att ni kan hjälpa mig....
259 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
123 ms — deklarationer (db)
123 ms — ändringar (db)
