updateable query.
2 svar · 137 visningar · startad av larsson
larssonMedlem sedan nov. 200037 inlägg
Halloj !!
varför får jag detta felmeddalende ?
insert into Kontakt (Lognamn,Losen,Anvandare,Adress,Postnummer,Ort,TelArbete,TelefonBostad,Mobiltelefon,Fax,Epost,Anteckningar) values ('test','test','test','test','test','test','test','test','test','test','test','test')
Microsoft OLE DB Provider for ODBC Drivers error '80004005'
[Microsoft][ODBC Microsoft Access Driver] Operation must use an updateable query.
/nyhet/anvandare.asp, line 91
Rad 91 är med fet stil.
<%@LANGUAGE="VBSCRIPT"%>
<!--#include file="../Connections/svbsf.asp" -->
' *** Edit Operations: declare variables
MM_editAction = CStr(Request("URL"))
If (Request.QueryString <> "") Then
MM_editAction = MM_editAction & "?" & Request.QueryString
' boolean to abort record edit
MM_abortEdit = false
' query string to execute
MM_editQuery = ""
' *** Insert Record: set variables
If (CStr(Request("MM_insert")) <> "") Then
MM_editConnection = MM_svbsf_STRING
MM_editTable = "Kontakt"
MM_editRedirectUrl = "finns.asp"
MM_fieldsStr = "Lognamn|value|Losen|value|Anvandare|value|Adress|value|Postnummer|value|Ort|value|TelArbete|value|TelefonBostad|value|Mobiltelefon|value|Fax|value|Epost|value|Anteckningar|value"
MM_columnsStr = "Lognamn|',none,''|Losen|',none,''|Anvandare|',none,''|Adress|',none,''|Postnummer|',none,''|Ort|',none,''|TelArbete|',none,''|TelefonBostad|',none,''|Mobiltelefon|',none,''|Fax|',none,''|Epost|',none,''|Anteckningar|',n one,''"
' create the MM_fields and MM_columns arrays
MM_fields = Split(MM_fieldsStr, "|")
MM_columns = Split(MM_columnsStr, "|")
' set the form values
For i = LBound(MM_fields) To UBound(MM_fields) Step 2
MM_fields(i+1) = CStr(Request.Form(MM_fields(i)))
Next
' append the query string to the redirect URL
If (MM_editRedirectUrl <> "" And Request.QueryString <> "") Then
If (InStr(1, MM_editRedirectUrl, "?", vbTextCompare) = 0 And Request.QueryString <> "") Then
MM_editRedirectUrl = MM_editRedirectUrl & "?" & Request.QueryString
Else
MM_editRedirectUrl = MM_editRedirectUrl & "&" & Request.QueryString
' *** Insert Record: construct a sql insert statement and execute it
' create the sql insert statement
MM_tableValues = ""
MM_dbValues = ""
FormVal = MM_fields(i+1)
MM_typeArray = Split(MM_columns(i+1),",")
Delim = MM_typeArray(0)
If (Delim = "none") Then Delim = ""
AltVal = MM_typeArray(1)
If (AltVal = "none") Then AltVal = ""
EmptyVal = MM_typeArray(2)
If (EmptyVal = "none") Then EmptyVal = ""
If (FormVal = "") Then
FormVal = EmptyVal
Else
If (AltVal <> "") Then
FormVal = AltVal
ElseIf (Delim = "'") Then ' escape quotes
FormVal = "'" & Replace(FormVal,"'","''") & "'"
Else
FormVal = Delim + FormVal + Delim
If (i <> LBound(MM_fields)) Then
MM_tableValues = MM_tableValues & ","
MM_dbValues = MM_dbValues & ","
End if
MM_tableValues = MM_tableValues & MM_columns(i)
MM_dbValues = MM_dbValues & FormVal
Next
MM_editQuery = "insert into " & MM_editTable & " (" & MM_tableValues & ") values (" & MM_dbValues & ")"
If (Not MM_abortEdit) Then
' execute the insert
Set MM_editCmd = Server.CreateObject("ADODB.Command")
MM_editCmd.ActiveConnection = MM_editConnection
MM_editCmd.CommandText = MM_editQuery
**MM_editCmd.Execute**
MM_editCmd.ActiveConnection.Close
If (MM_editRedirectUrl \<\> "") Then
  Response.Redirect(MM_editRedirectUrl)
~~ kanske inte ännu, men snart så funkar det :- ) ~~
Här på wF finns en eminent sökfunktion uppe till höger. Om du använder den så hittar du massor om detta.
Mvh,
All your base are belong to me.
Tack, får maila till webbhotelet att dom lägger till det.
Ändå så sa dom att det inte skulle vara några problem, bara att köra ;)
265 ms totalt · 3 externa anrop · v20260731065814-full.30151723
134 ms — hämta forumlista (db)
122 ms — hämta statistik (db)
