paging
4 svar · 213 visningar · startad av jboy_87
jboy_87Medlem sedan aug. 20011 099 inlägg
snälla n´ån hjälp mig vad är det för fel på min paging funkar inte :-<
<% Response.Buffer = True %>
<!-- #include file="style.css" -->
<html>
<body>
<table border="0" width="561" cellspacing="0" cellpadding="0" height="36">
mypage = Request("whichpage")
If mypage = "" then
   mypage = 1
mypagesize = 15
SQL = "Select * From members Order by username"
Set rstemp = Server.Createobject("ADODB.Recordset")
rstemp.cursorlocation = 3
rstemp.cachesize = 5
MdbFilePath = Server.MapPath("database/members.mdb")
rstemp.open SQL, "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & MdbFilePath & ";"
If rstemp.EOF then
   Response.write "Där fanns det ju inget... " & sok
Else %>
  <tr>
          <td bgcolor="#FF9900" height="1" width="92"><font color="#000000" face="Verdana, Arial, Helvetica, sans-serif" size="1"><b>
          Lägg till</b></font></td>
          <td bgcolor="#FF9900" width="213"><b>
          <font size="1" face="Verdana">Användarnamn:&nbsp;</font></b></td>
          <td bgcolor="#FF9900" width="208" height="1"><font face="Verdana, Arial, Helvetica, sans-serif" size="1"><b><font color="#000000">
          Ålder:</font></b><font color="#000000"><b>&nbsp;</b></font></font></td>
          <td bgcolor="#FF9900" width="99" height="1"><font color="#000000" face="Verdana, Arial, Helvetica, sans-serif" size="1"><b>
          Kön:&nbsp;</b></font></td>
          <td bgcolor="#FF9900" width="99" height="1"><font face="Verdana, Arial, Helvetica, sans-serif" size="1"><b>
          Status:&nbsp;</b></font></td>
          </tr>
   rstemp.movefirst
   rstemp.pagesize = mypagesize
   maxcount = Cint(rstemp.pagecount)
   rstemp.absolutepage = mypage
   howmanyrecs = 0
   howmanyfields = rstemp.fields.count -1
   Do While Not RStemp.EOF AND howmanyrecs < rstemp.pagesize
   counter = counter + 1
   If counter mod 2 = 0 then
      color = "#FFFFFF"
   Else
      color = "#F0F0F0"
    <tr bgcolor="<%= color %>">
    <td width="92" height="19"><font size="1" color="#000000" face="Verdana, Arial, Helvetica, sans-serif"><a href="add_friend.asp?id2=<%=RSTemp("id")%>" target="main1">
          Bli kompis</a></font></td>
    <td width="213" height="19"><font size="1" face="verdana, arial"><a href="whois.asp?checkid=<% =RStemp("id") %>"><% =RStemp("username") %></td>
    <td width="208" height="19"><font size="1" face="verdana, arial"><% =RStemp("syfte") %></td>
    <td width="99" height="19"><font size="1" face="verdana, arial"><% =RStemp("kunskap") %></td>
    <td><font size="1" <%if rstemp("status") = "offline" then%> color="#FF0000" <%else%>color="#00CC00" <%end if%>face="Verdana, Arial, Helvetica, sans-serif" face="Verdana, Arial, Helvetica, sans-serif"><%=RStemp("status")%></font></td>
  </tr>
<%   rstemp.movenext
   howmanyrecs = howmanyrecs + 1
   Loop
   rstemp.close
   Set rstemp = nothing
   <tr><td width="612" height="19" colspan="8">
   <hr noshade color="#000000" size="1">
   If maxcount <> 0 then
   response.write "sida " & mypage & " av " & maxcount & "<br>" & sidor:
   pad = "0"
   scriptname = request.Servervariables("script_name")
   for counter = 1 to maxcount
   If counter >= 10 then
      pad = ""
   ref = "<a href='" & scriptname & "?whichpage=" & counter & "&pagesize=" & mypagesize & "'>" & pad & counter & "</a> "
   response.write ref & " "
   if counter mod 10 = 0 then
      response.write "<br>"
   Next
%> </font>
</td></tr>
</table>
</html>
ASP är bäst fuck the rest!!!
Vad är problemet?
All your base are belong to me.
fan asså vad dum jag e förlåt gjorde fel jag gör alltid fel förfan jag blir galen tack endå :-(
Klart man får göra fel! :)
Men man får gärna också berätta vad det är som inte fungerar, så blir det lättare att hjälpa till. :)
Mvh,
fixade skiten onödig inlägg
