Jag får inte min kod att fungera som jag vill. Även om jag laddar upp en bild så uppfylls bara villkoret efter <% Else %> är det nån som kan hjälpa mig?
Set Upload = Server.CreateObject("Persits.Upload")
Count = Upload.Save(Server.MapPath("bilder"))
' Obtain file object
Set File = Upload.Files("BILD")
If Not File Is Nothing Then
Connect.Open = "Driver={Microsoft Access Driver (*.mdb)};DBQ=" & Server.MapPath("db/max.mdb")
' If you use SQL Server, the connecton string may look like this:
' Connect = "Provider=SQLOLEDB;Server=SRV;Database=mydb;UID=sa;PWD=xxx"
' Use ADO Recordset object
Set rs = Server.CreateObject("adodb.recordset")
' Optional: check whether this file already exists using MD5 hash
'Hash = File.MD5Hash
' rs.Open "SELECT * from bilder WHERE Hash='" & Hash & "'", Connect, 2, 3
'If Not rs.EOF Then
'Response.Write "This file already exists in the database."
' Response.End
' End If
' rs.Close
' Reopen recordset to insert file
Addera = "SELECT * FROM bilder"
rs.Open Addera, Connect, 2, 3
rs.AddNew
rs("rubrik") = Upload.Form("rubrik")
rs("kategori") = Upload.Form("kategori")
rs("subkategori") = Upload.Form("subkategori")
rs("stylist") = Upload.Form("stylist")
rs("modell") = Upload.Form("modell")
rs("hair_make") = Upload.Form("hair_make")
rs("sokvag") = Upload.Form("sokvag") & File.Filename
rs("sokvag_thumb") = Upload.Form("sokvag_thumb") & File.Filename
rs.Update
rs.close
connect.close%>
<% Set Connect = Server.CreateObject("ADODB.Connection")
Addera = "SELECT * FROM bilder order by id DESC"
rs.Open Addera, Connect, 2, 3 %>
<table width="500" border="0" cellpadding="5" cellspacing="0" bgcolor="#CCCCCC">
<tr>
<td class="vanligtext"><strong>FÖLJANDE BILD HAR LAGTS TILL: </strong><br>
<br>
<strong>Rubrik:</strong><br>
<% =rs("rubrik") %><br>
<strong>Kategori:</strong><br>
<% =rs("kategori") %><br>
<strong>Jobb:</strong><br>
<% =rs("subkategori") %><br>
<strong>Stylist:</strong><br>
<% =rs("stylist") %><br>
<strong>Modell:</strong><br>
<% =rs("modell") %><br>
<strong>Hår & Make:</strong><br>
<% =rs("hair_make") %><br><br>
<strong>Photo:</strong><br>
<img src="<% =Mid(rs("bild"), 7)%>" alt=""><br>
<a href="make_thumb.asp">[SKAPA THUMBNAIL]</a>
</td>
</tr>
</table>
<% rs.close
connect.close%>
<% Else %>
<% Response.Write("Ingen bild har lagts till!!")%>
<%End If%>
</html>
Martin
