Sökvägen till databasen är felaktig.
Följande felmeddelande uppstår när jag ska logga in på admin. Det är ett bild galleri som jag har laddat ner.
Microsoft OLE DB Provider for ODBC Drivers error '80004005'
[Microsoft][ODBC Microsoft Access Driver]General error Unable to open registry key 'Temporary (volatile) Jet DSN for process 0x1160 Thread 0xe9c DBC 0x1429024 Jet'.
/gallery/admin/Default.asp, line 23
Linje 1-30:
' FileName="Connection_odbc_conn_dsn.htm"
' Type="ADO"
' HTTP="false"
' Catalog=""
' Schema=""
MM_connDUgallery_STRING = "DRIVER={Microsoft Access Driver (*.mdb)};DBQ=" & Server.MapPath("..\_private\DUgallery.mdb")
%><% Response.Buffer = True %>
' *** Validate request to log in to this site.
MM_LoginAction = Request.ServerVariables("URL")
If Request.QueryString<>"" Then MM_LoginAction = MM_LoginAction + "?" + Request.QueryString
MM_valUsername=CStr(Request.Form("id"))
If MM_valUsername <> "" Then
MM_fldUserAuthorization=""
MM_redirectLoginSuccess="pictures.asp"
MM_redirectLoginFailed="default.asp"
MM_flag="ADODB.Recordset"
set MM_rsUser = Server.CreateObject(MM_flag)
MM_rsUser.ActiveConnection = MM_connDUgallery_STRING LINJE 23
MM_rsUser.Source = "SELECT U_ID, U_PASSWORD"
If MM_fldUserAuthorization <> "" Then MM_rsUser.Source = MM_rsUser.Source & "," & MM_fldUserAuthorization
MM_rsUser.Source = MM_rsUser.Source & " FROM USERS WHERE U_ID='" & Replace(MM_valUsername,"'","''") &"' AND U_PASSWORD='" & Replace(Request.Form("password"),"'","''") & "'"
MM_rsUser.CursorType = 0
MM_rsUser.CursorLocation = 2
MM_rsUser.LockType = 3
MM_rsUser.Open
