Fixade själv tillslut - lade till det som är i fet txt
Denna kod fungerar bra, men hur gör jag för att också skapa en fil 'main.jpg' på 350px width - i tillägg till originalen och thumben?
' Variables
Dim mySmartUpload
Dim file
Dim intCount
intCount=0
' Object creation
Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
' Upload
mySmartUpload.Upload
' Select each file
For each file In mySmartUpload.Files
' Only if the file exist
If not file.IsMissing Then
' Save the files with his original names in a virtual path of the web server
'file.SaveAs("/aspSmartUpload/Upload/" & file.FileName)
file.SaveAs(Server.MapPath(mySmartUpload.Form("map")& "/" & file.FileName))
' sample with a physical path
' file.SaveAs("c:\temp\" & file.FileName)
mappa = file.FileName
' Display the properties of the current file
Response.Write("Name = " & file.Name & "<BR>")
Response.Write("Size = " & file.Size & "<BR>")
Response.Write("FileName = " & file.FileName & "<BR>")
Response.Write("FileExt = " & file.FileExt & "<BR>")
Response.Write("FilePathName = " & file.FilePathName & "<BR>")
Response.Write("ContentType = " & file.ContentType & "<BR>")
Response.Write("ContentDisp = " & file.ContentDisp & "<BR>")
Response.Write("TypeMIME = " & file.TypeMIME & "<BR>")
Response.Write("SubTypeMIME = " & file.SubTypeMIME & "<BR>")
intCount = intCount + 1
Next
' Display the number of files which could be uploaded
Response.Write("<BR>" & mySmartUpload.Files.Count & " files could be uploaded.<BR>")
' Display the number of files uploaded
Response.Write(intCount & " file(s) uploaded.<BR>")
Set Jpeg = Server.CreateObject("Persits.Jpeg")
Path = Server.MapPath(mySmartUpload.Form("map")) & "/" & mappa
Jpeg.Open Path
' New width
L = 100
' Resize, preserve aspect ratio
Jpeg.Width = L
Jpeg.Height = Jpeg.OriginalHeight * L / Jpeg.OriginalWidth
Jpeg.Save Server.MapPath(mySmartUpload.Form("map")) & "/th_main.jpg"
[B]Path = Server.MapPath(mySmartUpload.Form("map")) & "/" & mappa
Jpeg.Open Path
' New width
L = 350
Jpeg.Width = L
Jpeg.Save Server.MapPath(mySmartUpload.Form("map")) & "/main.jpg"[/B]
