filnamnsproblem med aspjpeg
3 svar · 257 visningar · startad av timedia
Medlem sedan maj 2001420 inlägg
Får detta fel
1 file(s) uploaded.
Microsoft VBScript runtime error '800a01a8'
Object required: ''
/admin/bild/pic2.asp, line 37
Nåt konstigt gör jag, men vad? Linje 37 i fet txt.
'  Variables
   Dim mySmartUpload
   Dim intCount
   Dim map
   Dim bilden
'  Object creation
   Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
'  Upload
   mySmartUpload.Upload
'  Save the files with their original names in a virtual path of the web server
   intCount = mySmartUpload.Save(Server.MapPath(mySmartUpload.Form("map")))
   ' sample with a physical path
   ' intCount = mySmartUpload.Save("c:\temp\")
'  Display the number of files uploaded
   Response.Write(intCount & " file(s) uploaded.")
Set Jpeg = Server.CreateObject("Persits.Jpeg")
'Path = Server.MapPath("photoalbum\Webmaster") & "\test.jpg"
[B]Path = Server.MapPath(mySmartUpload.Form("map")) & "\"&File.ExtractFileName&".jpg"[/B]
Jpeg.Open Path
	if Jpeg.OriginalWidth > 100 then
		strPercent = 100 / jpeg.originalwidth
		Jpeg.Width = "100"
		Jpeg.Height = Jpeg.OriginalHeight * strPercent
Jpeg.Save Server.MapPath(mySmartUpload.Form("map")) & "\th_"&File.ExtractFileName&".jpg"
Såhär ser formuläret ut:
<FORM METHOD="POST" ACTION="pic2.asp" ENCTYPE="multipart/form-data">
<select name="map">
<option value="">Välj Katalog</option>
<option>---------------</option>
	set fso = server.createobject("scripting.filesystemobject")
set folder =fso.getfolder(Server.Mappath("../bild"))
for each fo in folder.subfolders
response.write "<option value="& fo.name &">"& fo.name &"</option>"
 next %>
</select> <br>
   <INPUT TYPE="FILE" NAME="FILE1" SIZE="50"><BR>
   <INPUT TYPE="SUBMIT" VALUE="Upload">
</FORM>
Du använder File nedan.
Hur ska jag göra då?
Byt File mot Jpeg. (Jag såg flera förekomster.)
127 ms — deklarationer (db)
133 ms — ändringar (db)
