<!-- #include file="./gaaah.inc" -->
<html>
<title>Uppdatering av uppgifter</title>
<body bgcolor="white">
Response.Expires = -1000
Response.Addheader "Pragma", "no-cache"
Dim mobil
mobil=request.form("mob")
Dim Info
info=request.form("info")
Dim id
id=request.querystring("id")
Dim faxnr
faxnr=request.form("fax")
Dim epostpriv
epostpriv=request.form("Epostpriv")
Dim tfnhem
tfnhem=request.form("tfnhem")
Conn.Open connString
Strsql="select * from Vytelpersoninfo where PersonID = '"&id&"' "
Set rs = Conn.execute (Strsql)
SQL1="update Vytelpersoninfo set info='"&info&"' where PersonID = '"&id&"'"
Do while not rs("typk")="TfnMobil"
rs.movenext
loop
if rs("typk")="TfnMobil" then
SQL= "update Vytelpersoninfo set Kontakt='"&mobil&"' where PersonID = '"&id&"' and typk='TfnMobil'"
SQL="insert into tbltelpersonkontakt(personid,kontakttyp,kontakt) values('"&id&"','2','"&mobil&"')"
rs.movefirst
[b]Do while not rs("typk")="Fax"[/b]
rs.movenext
loop
if rs("typk")="Fax" then
SQL2= "update Vytelpersoninfo set Kontakt='"&faxnr&"' where PersonID = '"&id&"' and typk='Fax'"
SQL2="insert into tbltelpersonkontakt(personid,kontakttyp,kontakt) values('"&id&"','7','"&faxnr&"')"
rs.movefirst
do while not rs("typk")="EpostPrivat"
rs.movenext
loop
if rs("typk")="EpostPrivat" then
SQL3="update Vytelpersoninfo set Kontakt='"&epostpriv&"' where PersonID = '"&id&"' and typk='EpostPrivat'"
SQL3="insert into tbltelpersonkontakt(personid,kontakttyp,kontakt) values('"&id&"','5','"&epostpriv&"')"
rs.movefirst
do while not rs("typk")="TfnHem"
rs.movenext
loop
if rs("typk")="TfnHem" then
SQL4="update Vytelpersoninfo set Kontakt='"&tfnhem&"' where PersonID = '"&id&"' and typk='TfnHem'"
SQL4="insert into tbltelpersonkontakt(personid,kontakttyp,kontakt) values('"&id&"','6','"&tfnhem&"')"
conn.execute(SQL)
conn.execute(SQL1)
conn.execute(SQL2)
conn.execute(SQL3)
conn.execute(SQL4)
response.redirect "info_person.asp?id="&id&""
</html>
Får felmedelandet......
Error Type:
(0x80020009)
Exception occurred.
/adress/nytele/update.asp, line 61
Det feta är rad 61.....
Är man medlem på WF så behöver man inga vänner !
Varför du får fel vet jag inte, men det är några problem med din kod.
innebär att recordsetet blir forwardonly, dvs du kan inte använda movefirst. I så fall måste du använda open med en dynamisk eller keyset cursor.
rs.movenext
loop
Här kontrollerar du aldrig om du EOF blir sant.
Do while not rs.eof
if ("typk")="TfnMobil" then exit do
rs.movenext
loop
if rs.eof then
sql = "insert"
sql = "update"
I och för sig så borde det gå att skriva om koden så att du bara behöver traversera recordsetet en gång
sql1 = ""
sql2 = ""
'osv
sql5 = ""
while not rs.eof
if rs("typk") = "tfnMobil" then
sql1 = "update ..."
elseif rs("typk") = "fax" then
sql2 = "update ..."
'osv
rs.movenext
wend
if sql1 = "" then
sql1 = "insert ..."
if sql2 = "" then
sql2 = "insert ..."
'osv
------------------ essentitia preter non sans multiplicandum
Nu har jag ändrat lite efter att Lars G en engång givit meg en Lektion i ASP-konsten,Men jag får det inte att funka... ändå
<html>
Dim mobil
Dim Info
Dim id
Dim faxnr
Dim epostpriv
Dim tfnhem
Strsql="select * from Vytelpersoninfo where PersonID = '"&id&"'"
[b] rs.Open Strsql,Conn,1,2[/b]
rs.movefirst
Do while not rs.eof
exit do
rs.movenext
loop
if rs.eof then
rs.movefirst
Do while not rs.eof
exit do
rs.movenext
loop
if rs.eof then
rs.movefirst
Do while not rs.eof
exit do
rs.movenext
loop
if rs.eof then
rs.movefirst
Do while not rs.eof
exit do
rs.movenext
loop
if rs.eof then
conn.execute(SQL)
conn.execute(SQL1)
conn.execute(SQL2)
conn.execute(SQL3)
conn.execute(SQL4)
</html>
Felmedelandet lyder...
Error Type:
Microsoft VBScript runtime (0x800A01A8)
Object required: ''
/adress/nytele/update.asp, line 35
Det har väl med cursor och lock type att göra förmodar jag.....
Nej! :-) Detta fungerar.
SQL = "SELECT * FROM [job]"
set mySQL = Conn.Execute(SQL)
DO UNTIL mySQL.EOF
response.write mySQL("x_ID") & " "
mySQL.MoveNext
LOOP
mySQL.MoveFirst
DO UNTIL mySQL.EOF
mySQL.MoveNext
LOOP
