devotionMedlem sedan jan. 20013 582 inlägg :)
Hur gör jag en funktion som skriver ut med Response.write "Användarnamn eller lösenord är fel, försök igen!" i denna koden. Det ska skrivas under formuläret...
Koden är lång och ful.....
Help, please!
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.ConnectionString = "DSN=IntranetSydostel"
objConn.Open
strSQL = "SELECT * FROM tblUser WHERE userName = '" & replace(Request.Form("User"), "'", "''") & "' AND passWord = '" & Replace (Request.Form("Password"), "'", "''") & "'"
set objRS = objConn.Execute(strSQL)
If Request.Querystring("logoff")="yes" Then
Session.Abandon
Response.redirect "leftframe2.asp"
End if
If objRS.eof then
Response.Write "<span Class=""statusText"">Ej inloggad!</span><br><br>"
Response.Write "<div id=""menu"">"&_
"<a href=""avdelning1.html"" onmouseover=""fnMouseEffect( this, '../menuImages/foretaget2.gif' )"" onmouseout=""fnMouseEffect( this, '../menuImages/foretaget.gif' )"" onclick=""return fnShowHide( this )""><img src=""../menuImages/foretaget.gif"" height=""18"" width=""120"" border=""0""></a><br>"&_
"<ul>"&_
"<li><table width=""150"" border=""0"" cellspacing=""0"" cellpadding=""0""><tr><td width=""16"" valign=""middle""><img src=""../menuImages/pil.gif"" width=""16"" height=""16""></td><td width=""134"" valign=""middle""><a href=""test.asp"">Policy</a></td></tr></table></li>"&_
"</ul>"&_
"<a href=""avdelning2.html"" onmouseover=""fnMouseEffect( this, '../menuImages/uppdragNu2.gif' )"" onmouseout=""fnMouseEffect( this, '../menuImages/uppdragNu.gif' )"" onclick=""return fnShowHide( this )""><img src=""../menuImages/uppdragNu.gif"" height=""18"" width=""120"" border=""0""></a><br>"&_
"<ul>"&_
"<li><table width=""150"" border=""0"" cellspacing=""0"" cellpadding=""0""><tr><td width=""16"" valign=""middle""><img src=""../menuImages/pil.gif"" width=""16"" height=""16""></td><td width=""134"" valign=""middle""><a href=""test.asp"">Visa uppdrag</a></td></tr></table></li>"&_
"</ul>"&_
"<a href=""avdelning3.html"" onmouseover=""fnMouseEffect( this, '../menuImages/arbetsmiljo2.gif' )"" onmouseout=""fnMouseEffect( this, '../menuImages/arbetsmiljo.gif' )"" onclick=""return fnShowHide( this )""><img src=""../menuImages/arbetsmiljo.gif"" height=""18"" width=""120"" border=""0""></a><br>"&_
"<ul>"&_
"<li><table width=""150"" border=""0"" cellspacing=""0"" cellpadding=""0""><tr><td width=""16"" valign=""middle""><img src=""../menuImages/pil.gif"" width=""16"" height=""16""></td><td width=""134"" valign=""middle""><a href=""test.asp"">Företagets policy</a></td></tr></table></li>"&_
"<li><table width=""150"" border=""0"" cellspacing=""0"" cellpadding=""0""><tr><td width=""16"" valign=""middle""><img src=""../menuImages/pil.gif"" width=""16"" height=""16""></td><td width=""134"" valign=""middle""><a href=""test.asp"">lagar och regler</a></td></tr></table></li>"&_
"</ul>"&_
"<a href=""avdelning4.html"" onmouseover=""fnMouseEffect( this, '../menuImages/adresslista2.gif' )"" onmouseout=""fnMouseEffect( this, '../menuImages/adresslista.gif' )"" onclick=""return fnShowHide( this )""><img src=""../menuImages/adresslista.gif"" height=""18"" width=""120"" border=""0""></a><br>"&_
"<ul>"&_
"<li><table width=""150"" border=""0"" cellspacing=""0"" cellpadding=""0""><tr><td width=""16"" valign=""middle""><img src=""../menuImages/pil.gif"" width=""16"" height=""16""></td><td width=""134"" valign=""middle""><a href=""test.asp"">Sök adresser</a></td></tr></table></li>"&_
"<li><table width=""150"" border=""0"" cellspacing=""0"" cellpadding=""0""><tr><td width=""16"" valign=""middle""><img src=""../menuImages/pil.gif"" width=""16"" height=""16""></td><td width=""134"" valign=""middle""><a href=""test.asp"">Visa adresser</a></td></tr></table></li>"&_
"</ul>"&_
"</div>"
Response.Write "<form action=""leftFrame2.asp"" method=""post"" name=""logIn""><table width=""150"" border=""0"" cellspacing=""0"" cellpadding=""0"">"&_
"<tr><td class=""logIn"">Logga in </td></tr><tr><td class=""userName_passWord"">Användarnamn:</td></tr>"&_
"<tr><td><input name=""User"" type=""text"" class=""formular"" size=""20"" maxlength=""20""></td></tr>"&_
"<tr><td class=""userName_passWord"">Lösenord:</td></tr>"&_
"<tr><td><input name=""passWord"" type=""password"" class=""formular"" size=""20"" maxlength=""20""></td></tr>"&_
"<tr><td><input name=""Submit"" type=""submit"" class=""knapp"" value=""Logga in""></td></tr></table></form"
Session("userId") = objRS("UserId")
Session("Name") = objRS("name")
Response.Write "<span class=""statusText"">Inloggad som: " & Session("Name") & "</span><br><br>"
"<ul>"&_
"</ul>"&_
"<ul>"&_
"</ul>"&_
"<ul>"&_
"</ul>"&_
"<ul>"&_
"</ul>"&_
"</div>"
Response.Write "<a href=""leftframe2.asp?logout=yes"">Logga ut!</a>"
Session.Timeout = 10
objRS.Close
Set objRS = Nothing
objConn.Close
Set objConn = Nothing
@ndersMedlem sedan juni 200032 969 inlägg Du saknar > i din form-avslutningstagg, f.ö.
"<tr><td><input name=""Submit"" type=""submit"" class=""knapp"" value=""Logga in""></td></tr>" & _
"<tr><td colspan=""2"">Närru, det där blev allt fel. Jag kräver att du försöker igen!</td></tr>" & _
"</table></form>"
devotionMedlem sedan jan. 20013 582 inlägg :q
Hur menar du?
Det där hjälpte inte. Det finns ju inga villkor för det. Det visas ju alltid.
Behövs det inte if satser för att lösa det?
@ndersMedlem sedan juni 200032 969 inlägg Jag antog att du bara körde SQL-frågan om man försökt logga in, det finns ju ingen anledning att köra den annars. Det här borde fungera (men jag orkar inte fixa indenteringen just nu):
objConn.Open
sUser = replace(Request.Form("User"), "'", "''")
sPassword = Replace (Request.Form("Password"), "'", "''")
blnLoginError = false
if sUser <> "" and sPassword <> "" then
strSQL = "SELECT * FROM tblUser WHERE userName = '" & sUser & "' AND passWord = '" & sPassword & "'"
Session.Abandon
End if
If objRS.eof then
blnLoginError = true
"<ul>"&_
"</ul>"&_
"<ul>"&_
"</ul>"&_
"<ul>"&_
"</ul>"&_
"<ul>"&_
"</ul>"&_
"</div>"
objRS.Close
Set objRS = Nothing
objConn.Close
if (sUser = "" and sPassword = "") or blnLoginError then
"<ul>"&_
"</ul>"&_
"<ul>"&_
"</ul>"&_
"<ul>"&_
"</ul>"&_
"<ul>"&_
"</ul>"&_
"</div>"
If blnLoginError then
Response.write "<tr><td colspan=""2"">Felaktigt användarnamn eller lösenord.</td></tr>"
End if
Response.write "</table></form>"
End if
Kanske lite dåligt förklarat.... :r
Men det var just det... Jag kom inte på hur jag skulle göra för att inte köra sql-frågan direkt utan bara vid inloggning...
Fungerar inte helt perfekt dock... ;)
Om jag skriver rätt användarnamn med felaktigt lösenord får jag felmeddelandet.
Om jag lämnar fälten blanka kommer inget felmeddelande.
Om jag skriver i endast användarnamn men inget lösenord blir sidan helt blank.
Om jag skriver fel användarnamn OCH fel lösenord får jag felmeddelande.
I o f s så behövs ju inget felmeddelande om varken användarnamn eller lösenordf fylls i så mycket vett borde man ha...
Och vad betyder indenteringen... :r
@ndersMedlem sedan juni 200032 969 inlägg Indentering:
If 1=2 then
If 2=3 then
If 3=4 then
For i = 0 to 7
'gör något
Next
End if
End if
End if
http://www.susning.nu/Indentering
Ok, då har jag lärt mig nått nytt idag :) :)
Jag är inte så bra på det... :r
Har du några ideer om mina andra frågor?
mvh
@ndersMedlem sedan juni 200032 969 inlägg Det är bara att pilla till if-satserna så de gör det du vill. You can do it, Bobby Boucher! :)
Bytte
Mot
if sUser <> "" or sPassword <> "" then
Fungerar nu!! :)
Om man däremot lämnar båda fälten blanka händer ingenting...
Men det gör inget
mvh
