Detta script skriver över andra poster i databasen när det bara ska uppdatera en specifik post, hur kan jag fixa det?
Jag prövade använda:
Conn.Open "PROVIDER=MICROSOFT.JET.OLEDB.4.0;DATA SOURCE=C:\data\WebData\katalog.mdb;"
SQL = "SELECT * from Kat WHERE USERNAME = '" & mySmartUpload.Form("ID") & "'"
Set RS_prod = Conn.Execute(SQL)
Så att det bara skulle välja den post som hade samma ID som den som skulle uppdateras. men det funkade inte riktig
'Declare all local variables
dim conn
dim rs
dim strID
dim strconn
'set a local variable to my DSN-less connection String
strconn = "PROVIDER=MICROSOFT.JET.OLEDB.4.0;DATA SOURCE=C:\data\WebData\katalog.mdb;"
'Create the Connection object
set conn = server.createobject("adodb.connection")
conn.open strconn
'Create the recordset object
'set rs = server.createobject("adodb.recordset")
'This statement opens the table so we can add a record notice the addnew
'The 2, 2 is how the table is opened there are many ways it can be opened
rs.open "Kat", conn, 2, 2, adCmdTable
rs.update
'Set the table column = to my input text box from my form
rs("Namn") = mySmartUpload.Form("Namn")
rs("Naradress") = mySmartUpload.Form("Naradress")
rs("Postnr") = mySmartUpload.Form("Postnr")
rs("Ort") = mySmartUpload.Form("Ort")
rs("Tel") = mySmartUpload.Form("Tel")
rs("Fax") = mySmartUpload.Form("Fax")
rs("Epost") = mySmartUpload.Form("Epost")
rs("www") = mySmartUpload.Form("www")
rs("Amnesomrade") = mySmartUpload.Form("Amnesomrade")
rs("Password") = mySmartUpload.Form("Password")
rs("Ovrigt_swe") = mySmartUpload.Form("Ovrigt_swe")
rs("Ovrigt_fin") = mySmartUpload.Form("Ovrigt_fin")
rs.update
His Divine Shadow is the most despicable being ever created, short and to the point.
http://forums.planetdivine-shadow.com
Sprit löser inga problem. Men det gör inte mjölk heller.
[Redigerat av His Divine Shadow den 11 okt 2001]
LarsGMedlem sedan dec. 200012 464 inlägg <%
dim conn
dim rs
dim strID
dim strconn
conn.open strconn
rs.open sql, conn, 2, 2, adCmdText
rs.update
red: cut and paste fel.
[Redigerat av LarsG den 11 okt 2001]
Jag får:
Microsoft VBScript runtime error '800a01a8'
Object required: ''
/katalog/swe/redigera2.asp, line 42
Linje 42:
@ndersMedlem sedan juni 200032 969 inlägg Du har ju kommenterat bort skapandet av recordsetet.
Ta bort kommenteringen...
All your base are belong to me.
UPS! :e
Men nu fick jag
Microsoft JET Database Engine error '80040e07'
Data type mismatch in criteria expression.
Linje 42 är igen:
LarsGMedlem sedan dec. 200012 464 inlägg Hur ser sql-satsen ut?
Lägg till en
response.write sql
precis innan open.
Detta fick jag:
SELECT * from Kat WHERE ID = '64'
LarsGMedlem sedan dec. 200012 464 inlägg Vilken datatyp har kolumnen id?
Om det är nuneriskt så skall det inte vara några ' kring värdet, dvs
OK tack
