formulär och funktioner
2 svar · 176 visningar · startad av timedia
Medlem sedan maj 2001420 inlägg
Har följande kod:
<!-- #include file="config.asp" -->
func = request.querystring ("func")
if func = "addform" then
addform
if func = "delform" then
delform
select case request.Querystring ("function")
case "add"
call add
case "remove"
call remove
end select
<% function addform%>
<form method="POST" action="mlmlist.asp?function=add">
   <p align="center"><b><i>Subscribe</i></b></p>
<div align="center">
  <center>
  <table border="1" bgcolor="#008080">
    <tr>
      <td>
        <p align="center"><b>Email</b><br>
        <input type="text" name="newmail" size="20"></td>
    </tr>
    <tr>
      <td>
        <p align="center"><input type="submit" value="Subscribe" name="B1"><input type="reset" value="Reset" name="B2"></td>
    </tr>
  </table>
  </center>
  <p align="center">&nbsp;</p>
<%end function%>
<% function delform%>
<form method="POST" action="mlmlist.asp?function=remove">
   <p align="center"><i><b>Unsubscribe</b></i></p>
    <center>
    <table border="1" width="149" bgcolor="#008080">
      <tr>
        <td width="139">
          <input type="text" name="remmail" size="20"></td>
      </tr>
      <tr>
        <td width="139">
          <p align="center"><input type="submit" value="remove" name="B1"><input type="reset" value="Reset" name="B2"></td>
      </tr>
    </table>
    </center>
<%end function%>
<% sub add
email = Request.form ("newmail")
If IsEmpty(Request("newmail")) Then
      Msg = "Please enter your email address."
   ElseIf InStr(Request("newmail"), "@") = 0 Then
      response.write ("Please Enter An Email Address <br> in the form username@location.domain <br> <a href=""javascript:history.back()"">Back</a> ")
response.end
set mailcheck = conn.Execute ("Select email from list where email='" & email & "'")
		if mailcheck.eof then
already_in_list="No"
mailcheck.close
if already_in_list="No" then
sql = "select * from list"
rs.open sql,conn,1,3
rs.addnew
rs("email") = email
rs("dateadded") = date()
rs.update
rs.close
conn.close
Response.write "added"
		Response.Write "Your are already subscribed"
end sub
<% sub remove
 remmail = Request.form ("remmail")
 if remmail = "" then
Response.Write ("Please enter a valid email<br> <a href=""javascript:history.back()"">Back</a>")
response.end
sql = ("select email From list where email='" & remmail & "'")
set rs = conn.execute (sql)
if rs.eof then
	response.write "there are no emails  here "
	response.end
set rsdel = conn.execute ("delete * From list where email='" & remmail & "'")
response.write  remmail & " Has Been Removed"
response.end
 end sub
Jag önskar ett formulär med ett fält där man matar in sin epostadress och två knappar där man väljer antingen add eller remove. Har provat länge men får det inte att funka (som förväntad alltså)
Någon som kan hjälpa? PS! Jag hittade maillisten på www.justasp.net och den är bra (om det inte vore för detta :))
www.moviemix.nu
Prova detta
addform
elseif func = "delform" then
delform
case "add"
call add
case "remove"
call remove
end select
sub addform
<center>
<tr>
<td>
</tr>
<tr>
<td>
</tr>
</table>
</center>
<p align="center"> </p>
end sub
sub delform
<center>
<tr>
<td width="139">
</tr>
<tr>
<td width="139">
</tr>
</table>
</center>
end sub
sub add
If IsEmpty(Request("newmail")) or InStr(Request("newmail"), "@") = 0 Then
response.end
sql="INSERT INTO list (email,dateadded) VALUES('" & email & "',date())"
conn.execute sql,,128
mailcheck.close
set mailcheck=Nothing
conn.close
set conn=Nothing
end sub
sub remove
dim lngAff
response.end
conn.execute "delete * From list where email='" & remmail & "'",lngAff,128
if lngAff<=0 then
end sub
If-satserna i början var lite fnuliga, jag har tagit bort överflödiga <% och %>, bytt från function till sub (eftersom en function ska returnera något) och gjort databasoperationerna med ett par små sql-satser.
Tack, men jag förstår nog inte helt. jag förklarade kanske lite dåligt. Sorry. Jag har följande formulär och funktioner på en annan sida:
<form name="form" method= "POST">
  <table width="34%" cellpadding=2 cellspacing=2 border=1 bgcolor="#FFF4FA" align="center">
<tr>
<td align="center">
  <input type="text" class="text" name="newmail" size="17" value="Email?"><br>
  <input TYPE="radio" NAME="meld" Value="yes" checked onsubmit="func1();">Prenumerera <br>
  <input TYPE="radio" NAME="meld" value="no" onsubmit="func2();">Avbeställ
  </td>
</tr>
</table>
              <p align="center"><input type="submit" value="Skicka" name="B1"><input type="reset" value="Återställ" name="B2"></p>
          </td>
        </tr>
      </table>
Här är functionerna:
function func1(){
document.form.action = 'mlmlist.asp?function=addform';
document.form.submit();
function func2(){
document.form.action = 'mlmlist.asp?function=delform';
(mlmlist.asp är sidan som jag bifogade innan) Detta får jag inte att fungera? Vad gör jag fel :r ?
www.moviemix.nu
125 ms — deklarationer (db)
121 ms — ändringar (db)
