Aspupload & databas fel
ASPur ASP
11 svar · 417 visningar · startad av paddan
Medlem sedan dec. 2002299 inlägg
Hej allihopa!
Jag har fått ett mysko fel på mitt blivande bildgalleri!
Felmeddelandet:
Microsoft OLE DB Provider for ODBC Drivers error '80004005'
Multiple-step OLE DB operation generated errors. Check each OLE DB status value, if available. No work was done.
/admin/page/upload2.asp, line 14
Line 14 är:
Recset("namn") = Request.Form("namn") i upload2.asp
Vad kan vara fel??
Fattar ingeting!
Här är koden, både upload funktionen och formuläret!
<form action="page/upload2.asp" method="post" enctype="multipart/form-data" name="form1" >
  <table width="100%" border="0" cellspacing="4" cellpadding="0" id="vanligtext">
    <tr>
      <td colspan="2"><div id="sportrubrik">Ändra nyhet</div>
        <font color="#FF9900">
        </font></td>
    </tr>
    <tr>
      <td width="60" valign="top">Rubrik:</td>
      <td width="109">
        <input type="file" name="fil1" id="vanligtext">
        </td>
    </tr>
    <tr>
      <td valign="top">Bilden:</td>
      <td>
	  <input name="namn" type="text" id="vanligtext" size="20"></td>
    </tr>
    <tr>
      <td width="60" valign="top"><p>Text:</p>        </td>
      <td width="109">
        <textarea name="info" wrap="PHYSICAL" rows="10" class="textruta" id="vanligtext"></textarea>
		</td>
    </tr>
    <tr>
      <td valign="top">Kategori:</td>
      <td><select name="kategori" id="vanligtext">
Set RSkat = Server.CreateObject("Adodb.RecordSet")
Sql = "SELECT * FROM sport where lang = 'sv' "
Set RSkat= Connect.Execute(Sql)
Do until RSkat.EOF
                  <option value="<%=RSkat("ID")%>"><%=RSkat("namn")%></option>
				RSkat.MoveNext
loop
RSkat.Close
 </select>
	  </td>
    </tr>
    <tr>
      <td width="60"></td>
      <td width="109">
        <input type="submit" name="Submit" value="Ändra" id="fettext">
        </td>
    </tr>
  </table>
Set Upload = Server.CreateObject("Persits.Upload")
Count = Upload.SaveVirtual("../../upload/img/")
Upload.OverwriteFiles = False
Connect.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & server.mappath ("../../db/jsif.mdb")
lol = "Select * FROM bild"
RecSet.Open lol, connect, 3,3
    RecSet.addnew
	Recset("kategori") = Request.Form("kategori")
	Recset("info") = Request.Form("info")
	Recset("datum") = date
   RecSet("fil").Value = File.FileName
    RecSet.Update
  RecSet.Close
    session("bildmess") = "Produkten är nu tillagt."
     response.Redirect "default.asp?page=13"
Mvh Martin
Medlem sedan juni 200032 969 inlägg
Kolla så du inte har fält i din tabell som är obligatoriska, som du utelämnar i din kod (eller har tomma värden).
Nej...inga obligatoriska...!
Fattar nte vadsoom kan vara fel...!
Förresten..vad menar du med tomma värden??
Om fälten i tabellen är inställda på att inte tillåta nollängd, så måste du lägga in värden i fälten. Vad innehåller Request.Form("namn") och Request.Form("kategori")?
Det väljer du i formuläret...kategori skickas det ett nummer med...
och i namn text!
Jag tog bort alla request.form och provade..då funkade att lägga upp filen...
men när jag la in:
RecSet("namn") = Request.Form("namn")
så skrev den:
Request object error 'ASP 0207 : 80004005'
Cannot use Request.Form
Cannot use Request.Form collection after calling BinaryRead.
Man kan inte använda Request.Form när man laddar upp filer. Använd uppladdningskomponentens motsvarighet istället.
Provade me bara datum...då funkade det...!
Vad är det???
Det står fint beskrivet i manualen.
Tackar så hemskt mycket...fattar nu..hottade det manualen...!
248 ms totalt · 3 externa anrop · v20260731065814-full.8a4e7caf
245 ms — hämta tråd, inlägg och bilagor (db)
