Sablar, aspsmartupload vill krångla
1 svar · 220 visningar · startad av His Divine Shadow
Medlem sedan sep. 20004 079 inlägg
aspSmartUpload.Files error '800404b5'
Invalid Files Name '' (Error 1205)
/katalog/swe/produkt_redigera2.asp, line 48
Koden:
'  Variables
   Dim mySmartUpload
 '  Dim intCount
'  Object creation
   Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
'  Upload
set skapamapp = mySmartUpload.Form("Username")
'  Save the files with their original names in a virtual path of the web server
   intCount = mySmartUpload.Save("/Katalog/Images/" & skapamapp)
   ' sample with a physical path
   ' intCount = mySmartUpload.Save("c:\temp\")
'Declare all local variables
dim conn
dim rs
dim strID
dim strconn
'set a local variable to my DSN-less connection String
strconn = "PROVIDER=MICROSOFT.JET.OLEDB.4.0;DATA SOURCE=C:\data\WebData\katalog.mdb;"
'Create the Connection object
set conn = server.createobject("adodb.connection")
conn.open strconn
'Create the recordset object
set rs = server.createobject("adodb.recordset")
'This statement opens the table so we can add a record notice the addnew
'The 2, 2 is how the table is opened there are many ways it can be opened
rs.open "Kat", conn, 2, 2, adCmdTable
rs.update
'Set the table column = to my input text box from my form
linje 48 -> rs("produktbild") = mySmartUpload.Files.Item(1).FileName
rs("produkt_namn_swe") = mySmartUpload.Form("produkt_namn_swe")
rs("produkt_namn_fin") = mySmartUpload.Form("produkt_namn_fin")
rs("pris") = mySmartUpload.Form("pris")
rs("Layout") = mySmartUpload.Form("Layout")
rs("produkt_info_swe") = mySmartUpload.Form("produkt_info_swe")
rs("produkt_info_fin") = mySmartUpload.Form("produkt_info_fin")
rs.update
'I do a movelast here to get the ID that is automatically generated
'I also set the value to a local variable so I can write out to the database
His Divine Shadow is the most despicable being ever created, short and to the point.
http://forums.planetdivine-shadow.com
Sprit löser inga problem. Men det gör inte mjölk heller.
[Redigerat av His Divine Shadow den 03 okt 2001]
Medlem sedan jan. 2001373 inlägg
jag andvänder denna kod som är en aning slarvig men du kanske kan hitta nått. Den fungerar iaf.
Dim Connect, RS, Addstmt, SQLMAX, MaxFileName, filenamex, item, value
Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq="& dbpath &""
Set RS = Server.CreateObject("ADODB.Recordset")
SQLMAX = "SELECT * FROM table01 WHERE unifilename = (SELECT MAX(unifilename) FROM table01)"
RS.Open SQLMAX, Connect, adOpenStatic, adLockOptimistic
If RS.EOF AND RS.BOF THEN
MaxFileName = 1
Response.write("EOF AND BOF")
Else
MaxFileName = RS("unifilename") + 1
Response.write("found ...<BR>")
RS.Close
' Variables
Dim mySmartUpload
Dim intCount
' Object creation
' Only allow PDF files
mySmartUpload.AllowedFilesList = "pdf"
' Upload
mySmartUpload.Upload
intCount = mySmartUpload.Save("D:\inetpub\wwwroot\crs\salesreports\movingdir")
' intCount = mySmartUpload.Save("/someshit")
' Display the number of files uploaded
Response.Write(intCount & " file(s) uploaded.")
' Informations about files
Response.Write("Number of files =" & mySmartUpload.Files.count &"<BR>")
Response.Write("Total bytes of files =" & mySmartUpload.Files.TotalBytes &"<BR>")
' Select each file
For each file In mySmartUpload.Files
Response.Write(file.FileName & " (" & file.Size & "bytes)<BR>")
filenamex = file.filename
Next
' FORM Collection
Addstmt = "SELECT * FROM table01"
RS.Open Addstmt, Connect, adOpenStatic, adLockOptimistic
RS.AddNew
RS("unifilename") = MaxFileName
RS("MyDate") = Date
' Select each item
For each item In mySmartUpload.Form
' Select each value of the current item
For each value In mySmartUpload.Form(item)
RS("" & item & "") = value
Next
Next
RS.Update
RS.Close
Connect.Close
Dim fso, file
Set fso = CreateObject("Scripting.FileSystemObject")
Set file = fso.GetFile("D:\inetpub\wwwroot\crs\salesreports\movingdir\"& filenamex &"")
file.Move ("D:\inetpub\wwwroot\crs\salesreports\database\img\"& MaxFileName &".pdf")
<% = MaxFileName %>
//Martin
259 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
118 ms — deklarationer (db)
123 ms — ändringar (db)
