db = Server.MapPath("db/nyheter.mdb")
Tabbe = "nyheter"
falt1 = "Id"
falt2 = "Rubrik"
falt3 = "Nyhet"
falt4 = "Datum"
falt5 = "Skribent"
<%If Request.QueryString("do") = "" Then%>
<table cellspacing="0" cellpadding="0" width="300" border="0">
<tr>
</tr>
<tr>
<form name="sok" method="post" action="search.asp?do=sok">
<td><input type="text" name="sokord" size="22" maxlength="20"> <input type="submit" name="Submit" value="Sök"></td>
</tr>
</table>
<%End If
If Request.QueryString("do") = "sok" Then%>
<tr> </tr>
<tr>
</tr>
<tr> </tr>
<tr> </tr>
<tr>
<td> </td>
</tr>
<tr>
<td><strong>Search Results</strong></td>
</tr>
<tr>
<td> </td>
</tr>
<%Falt = Trim(Request.Form("falt"))
If Len(Request.Form("sokord")) > 0 then
Conn.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & db
SQL = "Select * From " & Tabbe & " Where " & falt1 & " Like '%" & Request.Form("sokord") & "%' OR " & falt2 & " Like '%" & Request.Form("sokord") & "%' OR " & falt3 & " Like '%" & Request.Form("sokord") & "%' OR " & falt4 & " Like '%" & Request.Form("sokord") & "%' OR " & falt5 & " Like '%" & Request.Form("sokord") & "%' Order By " & falt1 & " Desc"
RecSet.Open SQL, Conn
If RecSet.EOF Then
Response.write "<tr><td class=normal>Your search of <b>" & Request.Form("sokord") & "</b> returned no results</td></tr>"
Else
Do Until RecSet.EOF
Response.Write "<tr height=15><td class=normal><b>»</b> <a href=search.asp?do=visa&id=" & RecSet(falt1) & ">" & Left(RecSet(falt2),30) & "</a></td></tr>"
RecSet.MoveNext
Loop
RecSet.Close
Set RecSet = Nothing
Else
Response.write "<tr><td class=normal>Please try again...</td></tr>"
End If%>
</table>
<%End If
If Request.QueryString("do") = "visa" Then
Set RecSet = Conn.Execute("Select * From " & Tabbe & " Where id=" & Request.QueryString("id"))%>
<table cellspacing="0" cellpadding="0" width="300">
<tr>
<td><b><%=RecSet(falt2)%> - <%=RecSet(falt4)%></b></td>
</tr>
<tr>
<td></td>
</tr>
<tr>
<td class="normal"><%=Replace(RecSet(falt3), vbCrLf, "<br>")%></td>
</tr>
</table>
<%End If%>
Hej.
Jag vill ta bort hela selectväljaren.
Så att man automatiskt söker i alla fälten sammtidigt! Utan att behöva välja. Hur gör jag detta?
Det skall alltså bara vara ett sökfält och en knapp bort med resten...
Tabbe = "nyheter"
falt1 = "Id"
falt2 = "Rubrik"
falt3 = "Nyhet"
falt4 = "Datum"
falt5 = "Skribent"
<tr>
</tr>
<tr>
<td><input type="text" name="sokord" size="22" maxlength="20"> <select name="falt">
<option value="<%=falt2%>" name="falt"><%=falt2%>
<option value="<%=falt3%>" name="falt"><%=falt3%>
<option value="<%=falt4%>" name="falt"><%=falt4%>
<option value="<%=falt5%>" name="falt"><%=falt5%> </select> <input type="submit" name="Submit" value="Sök"></td>
</tr>
</table>
<%End If
<tr> </tr>
<tr>
</tr>
<tr> </tr>
<tr> </tr>
<tr>
<td> </td>
</tr>
<tr>
</tr>
<tr>
<td> </td>
</tr>
SQL = "Select * From " & Tabbe & " Where " & Falt & " Like '%" & Request.Form("sokord") & "%' Order By " & falt1 & " Desc"
If RecSet.EOF Then
Else
Do Until RecSet.EOF
RecSet.MoveNext
Loop
RecSet.Close
Else
End If%>
</table>
<%End If
<tr>
</tr>
<tr>
<td></td>
</tr>
<tr>
</tr>
</table>
<%End If%>
