Lite mera hjälp.
8 svar · 160 visningar · startad av His Divine Shadow
Medlem sedan sep. 20004 079 inlägg
I mitt upload script så måste man ju skriva in filnamnet skillt, det är klumpigt, jag vill att det ska kunna ta filnamnet och lägga det i ett annat fält automatiskt
Koden som jag använder:
'  Variables
   Dim mySmartUpload
   Dim intCount
'  Object creation
   Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
'  Upload
   mySmartUpload.Upload
dim skapamapp
skapamapp = mySmartUpload.Form("Username")
Set Skapa = Server.CreateObject("Scripting.FileSystemObject")
Set Mapp = Skapa.CreateFolder(Server.MapPath("/Katalog/images/" & skapamapp))
'  Save the files with their original names in a virtual path of the web server
   intCount = mySmartUpload.Save("/Katalog/Images/" & skapamapp)
   ' sample with a physical path
   ' intCount = mySmartUpload.Save("c:\temp\")
'Declare all local variables
dim conn
dim rs
dim strID
dim strconn
'set a local variable to my DSN-less connection String
strconn = "PROVIDER=MICROSOFT.JET.OLEDB.4.0;DATA SOURCE=C:\data\WebData\katalog.mdb;"
'Create the Connection object
set conn = server.createobject("adodb.connection")
conn.open strconn
'Create the recordset object
set rs = server.createobject("adodb.recordset")
'This statement opens the table so we can add a record notice the addnew
'The 2, 2 is how the table is opened there are many ways it can be opened
rs.open "Kat", conn, 2, 2
'Use the addnew method of the recordset object to add a record
rs.addnew
'Set the table column = to my input text box from my form
rs("Namn") = mySmartUpload.Form("Namn")
rs("Naradress") = mySmartUpload.Form("Naradress")
rs("Postnr") = mySmartUpload.Form("Postnr")
rs("Ort") = mySmartUpload.Form("Ort")
rs("Tel") = mySmartUpload.Form("Tel")
rs("Fax") = mySmartUpload.Form("Fax")
rs("Epost") = mySmartUpload.Form("Epost")
rs("www") = mySmartUpload.Form("www")
rs("Amnesomrade") = mySmartUpload.Form("Amnesomrade")
rs("Ovrigt_swe") = mySmartUpload.Form("Ovrigt_swe")
rs("Ovrigt_fin") = mySmartUpload.Form("Ovrigt_fin")
rs("Username") = mySmartUpload.Form("Username")
rs("Password") = mySmartUpload.Form("Password")
rs("Filename") = mySmartUpload.Form("Filename")
rs.update
'I do a movelast here to get the ID that is automatically generated
'I also set the value to a local variable so I can write out to the database
rs.movelast
strID = rs("ID")´
Iden är att filnamnet automatiskt ska läggas in i ("filename")
His Divine Shadow is the most despicable being ever created, short and to the point.
http://forums.planetdivine-shadow.com
Sprit löser inga problem. Men det gör inte mjölk heller.
Medlem sedan dec. 1999707 inlägg
Vad heter formulärelementet som innehåller den fil som skall uppladdas? Alltså den input-kontroll som är av typen "file".
/ Torbjörn Hansson, webbutvecklare,
Density
Har inte upload objectet en egen metod för att plocka fram filnamnet typ:
strFileName = binUploadFile.FileName
Nackdelen med detta som jag ser det är att du måste bygga in någonsorts felkontroll då flera personer kan namnge filer exakt likadant.
Själv skulle jag ta id'et för posten som filnamn, i.e: <UniqueID>.gif
cya,
PatrikB
*ordning och reda!, pengar på fredag.*
[Redigerat av PatrikB den 26 sep 2001]
Nej som du ser i min förra tråd så får varje användare sin egen mapp att ha bilder i.
Den heter FILE1
Jag har för mig jag gjorde så att jag tog värdet från file-elementet innan formuläret postades och plockade ut filnamnet och lade med den i ett hidden-element som jag plockade fram på serversidan.
Density
Jag använder ju aspsmartupload, hittade en sida om detta här: http://www.aspsmart.com/liblocal/docs/en/aspsmartupload/help/FileObject.htm
Men jag förstår inte riktigt hur jag ska kunna lägga till detta i mitt script.
hmmm... behöver hjälp fortfarande och jag fattar noll av instruktionerna som fanns på dendär länken :(
Medlem sedan juli 2000534 inlägg
rs("Filename") = mySmartUpload.Files.Item(1).FileName
Alla filer du laddar upp hamnar i samlingen (eng. collection) Files. Du refererar till en enskild fil genom Item(index).
/Morph
Tech Support: "I need you to boot the computer."
Customer: (THUMP! Pause.) "No, that didn't help."
123 ms — deklarationer (db)
123 ms — ändringar (db)
