NoteID = 0
11 svar · 319 visningar · startad av Fraggel
FraggelMedlem sedan sep. 2003301 inlägg
Av någon anledning så vill denna kod inte hämta värdet somligger i fältet note_ID, det finns data i fältet men vad som än står där så returneras värdet 0.
Tabellen är en qry av ett flertal tabeller i ACCESS xp.
Function presentActivity(unid)
    Dim strTHTML
    Dim strSQL
    strSQL = "SELECT * FROM qryActivity WHERE activity_ID=" & unid
    Set objConn = server.CreateObject("ADODB.Connection")
    Set objRs   = server.CreateObject("ADODB.Recordset")
    objConn.Open (strDatabase)    ' Opens database, strDatabase public
    objRs.Open strSQL,objConn,1,2 ' Opens Recordset
    Dim name
    Dim f_name
    Dim s_name
    Dim username
    Dim note
    Dim statusText
    Dim description
    Dim priority
    customer_ID = objRs("customer_ID") 'public
    noteID      = objRs("note_ID")     'public
    name        = objRs("name")        'Company name
    f_name      = objRs("f_name")      'Contact f_name
    s_name      = objRs("s_name")      'Contact f_name
    username    = objRs("username")    'Customer owner short username
    statusText  = objRs("statusText")  'Text for Activity status
    description = objRs("description") 'Text for describing type of activty
    priority    = objRs("priority")    'Priority of activity
    objRs.Close
    objConn.Close
    note	    = insertNote(noteID) 'Gets Notes from table Notes in db.
    strTHTML = strTHTML &_
               "<table><tr>" &_
               "<td align=""right"">Företag:</td><td class=""boxed"">" & name & "</td>" &_
               "<td align=""right"">Kontakt:</td><td class=""boxed"">" & f_name & " " & s_name & "</td>" &_
               "<td align=""right"">Kundanvarig:</td><td class=""boxed"">" & username & "</td>" &_
               "<tr><td colspan=""6"">" & note & "</td></tr>" &_
               "<td align=""right"">Status:</td><td class=""boxed"">" & statusText & "</td><td align=""right"">Angående:</td><td class=""boxed"">" & description & "</td>" &_
               "<td align=""right"">Prioritet:</td><td class=""boxed"">" & priority & "<td>" &_
               "</tr></table>"
    presentActivity = strTHTML
  End Function
1. Tycker att detta borde gå att hämta med en sql-sats
2. vad/var är funktionen insertNote()?
strSQL = "SELECT *, note FROM qryActivity q,notes n WHERE q.noteid=n.noteid and activity_ID=" & unid
1 Men det gör jag ju...
2 inserNote()
Hämtar texten note ur en annan tabell som är gemensam för ALLA tabeller som innehåller en note, detta för att spara plats, då kanske inte alla poster har en note...
Tycker att allt detta borde gå att hämta med en sql-sats
Hmm saken är den att den "godkänner" ju objRs("note_ID") så datan finns ju där... Ialla fall så finns det med i "collectionen"
Vad får du för resultat om du ändrar :
till
presentActivity = noteID
presentActivity = noteID = 0
Jag hittade dock problemet,
I tabellen finns det flera fält med samma namn från olika tabeller...
men dom står som activity.note_ID, contact.note_ID och customer.note_ID men det går inte att hämta upp värdet av dem med objRs("activity.note_ID") osv utan den sväljer enbart objRs("note_ID") men då levererar den fel värde...
Så jag har löst det tillfälligt... MEN hur löser jag det för att få det att funka med ALLA dessa fälten? utan att göra om hela djävla databasen (det är för längt gånget för att jag skall hinna med det...
Använd inte * i din sql utan deklarera ut samtliga kolumner du skall ha istället.
Suck :) kan du gissa vilken SQL sats vi snackar om då !!!
Det rör sig om ett 30tal fält :)
Stjärnan suger "fet elefantballe" (citat från en kändis).
Använd inte stjärnan.
Du kan DIMa kod på detta sättet:
Dim name, f_name, s_name, username, note, statusText ... osv
Samma sak med att tilldela värde,
name = myRow(1,0) : f_name = myRow(2,0) : s_name = myRow(3,0) : username = myRow(4,0) : note = myRow(5,0) : statusText = myRow(6,0) ... osv
Jag håller med dig, 30 poster är många poster och det tar mycket plats. Men om du inte skriver all kod i höjdled utan även utnyttjar bredden blir det lite mer överskådligare.
Det är bättre du skriver så här:
SQL = "SELECT ID, name, f_name, s_name, username, note, statusText ... FROM [minTabell]"
set mySQL = Conn.Execute(SQL)
och sen som ovan,
name = mySQL(1) : f_name = mySQL(2) : s_name = mySQL(3) : username = mySQL(4) : note = mySQL(5) : statusText = mySQL(6) ... osv
Hajjar nästa vad du är ute efter jag löste det dock genom att Lägga ALLA fält namni en separat tabell och "auto generera" min SQL sats...
Fult men det funkar och blir lätt läst i koden :)
Och mycket enkelt att felsöka då...
135 ms totalt · 3 externa anrop · v20260731065814-full.cf67ef55
