suddenMedlem sedan okt. 2002341 inlägg Kan någon vänlig själ kompletera denna kod så att jag får sidvisningar...dvs antal sidor, framåt, bakåt och så :)
<%@LANGUAGE="VBSCRIPT"%>
<html>
<link rel="stylesheet" href="style.css" type="text/css">
<title>Boklager</title>
<script language="javascript">
function launchpopup()
window.open ("addnew.asp", "test", "width=500, height=200, location=0, menubar=0, resizable=0, scrollbars=yes, status=1, titlebar=1, toolbar=0");
<body leftmargin="20">
<%Set conn = Server.CreateObject("ADODB.Connection")
conn.open "DRIVER={MySQL ODBC 3.51 Driver};SERVER=localhost;DATABASE=boklager;USER=root;PASSWORD=;OPTION=3;"
SQL = "SELECT * FROM bestallningar ORDER BY efternamn ASC"
Set rs = conn.execute(SQL)%>
<table width="100%" height="100%" border="0">
<tr>
<td width="13%" align="left" valign="top">
<table width="94" border="0">
<tr>
<td width="88" height="70">
<a href="#">Start</a><br>
<a href="#">Beställningar</a><br>
<a href="#">Leveranser</a>
</td>
</tr>
</table>
</td>
<td width="87%" valign="top">
<table width="670" border="0" cellspacing="2" cellpadding="0">
<tr>
<td width="109" bgcolor="#666666" align="center"><font color="#ffffff" size="1" face="Verdana"><b>Datum</b></font></td>
<td width="110" bgcolor="#666666" align="center"><font color="#ffffff" size="1" face="Verdana"><b>Beställt åt</b></font></td>
<td width="235" bgcolor="#666666" align="center"><font color="#ffffff" size="1" face="Verdana"><b>Artikel</b></font></td>
<td width="70" bgcolor="#666666" align="center"><font color="#ffffff" size="1" face="Verdana"><b>Antal</b></font></td>
<td width="77" bgcolor="#666666" align="center"><font color="#ffffff" size="1" face="Verdana"><b>Språk</b></font></td>
<td width="55" bgcoolor="#ffffff" align="center"><a href="javascript:launchpopup();"><img src="new.gif" border="0"></a></td><td><a href="delete.asp?do=all"><img src="deleteall.gif" border="0"></a></td>
<td></td>
</tr>
<tr>
<%Do while not rs.eof%>
<tr>
<td align="center" bgcolor="#999999"><%=rs("datum")%></td>
<td align="center" bgcolor="#999999"><%=rs("fornamn") & " " & rs("efternamn")%></td>
<td align="center" bgcolor="#999999"><%=rs("artikel")%></td>
<td align="center" bgcolor="#999999"><%If rs("antal") > 10 then%><font color=red><%=rs("antal")%></font><%else%><%=rs("antal")%><%end if%></td>
<td align="center"bgcolor="#999999"><%if not rs("sprak") = "Svenska(z)" then%>
<font color="blue"><%=rs("sprak")%></font>
<%else%>
<%=rs("sprak")%>
<%end if%></td>
<td align="center"><a href="delete.asp?id=<%=rs("id")%>"><img src="trash.gif" border="0"></a></td>
</tr>
<%rs.MoveNext
Loop
set conn = nothing
set rs = nothing
</table>
</td>
</tr>
</table>
</html>
Det här använder jag mig av när jag gör paging..
sida = Trim(Request.QueryString("page"))
If sida = "" Then
sida = 1
rs.PageSize = 10
rs.AbsolutePage = sida
rad = 0
While Not RecSet.rs and rad < rsPageSize
rad = rad + 1
Det du ska loopa ut
rs.Movenext
wend
Response.write "<font style='font-family:tahoma;font-size:11px;color:#000000'>"
Response.write "Totalt"
Response.write " "
Response.write rs("summa")
Response.write " "
Response.write "inlägg"
Response.write " "
Response.write "/"
Response.write " "
Response.write "Varav"
Response.write " "
Response.write rspagecount
Response.write " "
Response.write "sidor"
Response.write "</font>"
Response.write "<br>"
If rs.PageCount > 1 Then
For i = 1 to rs.PageCount
If i = CLng(sida) Then
Response.write "<font style='font-family:tahoma;font-size:13px;color:#000000'>"
Response.write "<b>"
Response.Write "[" & i & "] "
Response.write "</b>"
Else
Response.Write "<a href=""sidan.asp?page=" & i & " "">" & i & " </a> "
Next
Nu är det ju inte så att du kan bläddra bakåt och framåt med t.ex en > som i webforum. men det blir siffror som man trycker på så motsvarar sidorna..
suddenMedlem sedan okt. 2002341 inlägg Har nu koden:
Set rs = server.CreateObject("adodb.recordset")
rs.cursorlocation = 3
rs.open SQL, conn%>
<tr>
<tr>
</td>
</tr>
</table>
</td>
<tr>
<td></td>
</tr>
<tr>
If sida = "" Then
sida = 1
rs.PageSize = 10
rad = 0
do while not rs.eof and rad < rs.PageSize
rad = rad + 1%>
<tr>
[B]<td align="center" bgcolor="#999999"><%If rs("antal") > 10 then%><font color=red><%=rs("antal")%></font><%else%><%=rs("antal")%><%end if%></td>[/B]
<%else%>
<%=rs("sprak")%>
<%end if%></td>
</tr>
<%rs.MoveNext
Loop
set conn = nothing
set rs = nothing
</table>
<table width="200" border="0" cellspacing="0" cellpadding="0">
<tr>
<td>
Else
Response.Write "<a href=""index.asp?page=" & i & " "">" & i & " </a> "
Next
Men får felmeddelandet:
Feltyp:
Körningsfel i Microsoft VBScript (0x800A000D)
Inkompatibla typer
/boklager/index.asp, line 62
ta bort loop under rs.movenext och sätt dit wend i stället...
