rekursiv kod
7 svar · 560 visningar · startad av Eclipse
SQL = "SELECT a.intID, a.intParentID, a.strName, a.strURL, a.bolView " _
& ", b.intID, b.intParentID, b.strName, b.strURL, b.bolView " _
& ", c.intID, c.intParentID, c.strName, c.strURL, c.bolView " _
& " FROM (([catalogueSE] as a " _
& " LEFT JOIN [catalogueSE] as b on b.intParentID = a.intID) " _
& " LEFT JOIN [catalogueSE] as c on c.intParentID = b.intID) " _
& " ORDER BY a.strName, b.strName, c.strName;"
Resultat:
ID: 3 Name: Abbacadabra ParentID: 0 Add to this menu
ID: 5 Name: add me ParentID: 3 Add to this menu
ID: 1 Name: ddd ParentID: 0 Add to this menu
ID: 2 Name: krabban ParentID: 0 Add to this menu
ID: 4 Name: krabban nummer tre ParentID: 0 Add to this menu
ID: 6 Name: zzz ask me mooore!! ParentID: 5 Add to this menu
Denna koden finns och fungerar.
Jag undrar nu hur jag kan få detta att fungera ihop med Dtree??
d = new dTree('d');
d.add(0,-1,'Produktkatalog');
[b]d.add(1,0,'Elborstar', '/admin/catalogueSE/index.asp');[/b]
d.add(2,0,'Borsthållare', '/admin/catalogueSE/index.asp');
d.add(3,0,'Släpringar', '/admin/catalogueSE/index.asp');
d.add(4,0,'Lindningstråd', '/admin/catalogueSE/index.asp');
d.add(5,0,'Impregneringslack', '/admin/catalogueSE/index.asp');
d.add(6,0,'Ingjutningsmassa', '/admin/catalogueSE/index.asp');
d.add(7,0,'Kondensatorer', '/admin/catalogueSE/index.asp');
d.add(8,0,'Termokontakter', '/admin/catalogueSE/index.asp');
d.add(9,0,'Termistorer', '/admin/catalogueSE/index.asp');
[b]d.add(10,1, 'Silvergrafitborstar','/v2/se_products/silvergraphite/index.asp');[/b]
d.add(11,2, 'Borsthållare','/v2/se_products/brushholders/index.asp');
d.add(12,3, 'Släpringar','/v2/se_products/sliprings/index.asp');
d.add(13,4, 'Lindningstråd','/v2/se_products/winding/index.asp');
d.add(14,5, 'Impregneringslack','/v2/se_products/lack/index.asp');
d.add(15,6, 'Ingjutningsmassa','/v2/se_products/lack/index.asp');
d.add(16,7, 'Startkondensatorer','/v2/se_products/start/index.asp');
d.add(17,8, 'Termokontakter','/v2/se_products/termokontakter/index.asp');
[b]d.add(18,1, 'Koppargrafitborstar','/v2/se_products/coppergraphite/index.asp');[/b]
d.add(19,7, 'Driftkondensatorer','/v2/se_products/drift/index.asp');
[b]d.add(20,1, 'Elektrografitborstar','/v2/se_products/electrographite/index.asp');[/b]
d.add(21,7, 'Elektrolytkondensatorer','/v2/se_products/elektrolyt/index.asp');
d.add(22,7, 'Belysningskondensatorer','/v2/se_products/belysning/index.asp');
document.write(d);
Den behöver inte vara rekursiv ifrån databasen, den fixar det i js-scriptet. Se till att id och parentid hamnar rätt så hamnar de rätt.
Denna funkar finfint för mig:
Sub dtree(objConn, SQL, parentid)
Dim rs, strSQL
Set rs = objConn.Execute(SQL)
	Do Until rs.EOF
		Response.Write "d.add("& rs(0) &","& rs(1) &",'"& rs(2) &"','"& rs(3) &"');"& vbcr
	rs.Movenext
	Loop
rs.close : set rs = nothing
objConn.close : set objConn = nothing
End sub
SQL="Select id, parentid,strName,strUrl from tabell order by strName"
dTree objConn,SQL,0
Hmmm!!
Din kåd är ju mycket bättre än den jag har...!? Tror jag!!
Det fungerade jättebra! Jag förstår dock inte riktigt hur det fungerar, men det kan jag leva med!
Jag undrar, hur gör du ditt administrativa gränssnitt? Jag menar, för att lägga till, redigera och ta bort rubriker?
Man kan ju tänka sig att man har textlänkar på något vis...
Det känns ju som en hel vetenskap, vad menar du?
Man måste manipulera rubrikerna på nåt vis, men jag har löst det nu, rätt snyggt dessutom.
Jag är inte färdig, men om du vill kan jag föklara.
	& " FROM [" & myTable & "] as a " _
	& " ORDER BY a.strName;"
set mySQL = Conn.Execute(SQL)
IF NOT mySQL.EOF THEN listMyMenu = mySQL.GetRows()
' ## LOOP THROUGHT MENUS
IF IsArray(listMyMenu) THEN
	myRow = listMyMenu
	FOR j = 0 TO UBound(myRow,2)
		response.write "d.add(" & myRow(0,j) & "," & myRow(1,j) & ",'" & myRow(2,j) & "', '" _
		& request.serverVariables("PATH_INFO") & "?ID=" &myRow(0,j) & "');" & vbCRLF
	NEXT
END IF
kåden genererear sidor i stil med:
/admin/catalogueSE/index.asp?ID=6
och utifrån det kan man redigera post med ID 6. Man kan lägga till och ta bort osv.
I just detta fallet ska jag ladda upp PDF:er som kopplas till varje rubrik, men det kan ju lika gärna vara bilder, text eller vad som helst!
Det var väldigt lite kod för att få väldigt mycket gjort, måste jag säga. Snubben som skrev D-tree visste nog vad han gjorde!
Jag har implementerat menyn på webbplatsen, men vissa rubrikval blir ju markerade på varje sida på något slags mer eller mindre omotiverad sätt.
Kan man bli av med det på något vis!? Via kod...??
d = new dTree('d');
[b]d.config.useSelection= false;[/b]
d.add(0,-1,'Tree example','javascript: void(0);');
d.add(1, 0,'Node 1','javascript:void(0);');
document.write(d);
257 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
128 ms — deklarationer (db)
125 ms — ändringar (db)
