Dim objConn, strSQL, objRS, intPage, intCount
If Request.QueryString("pg") = "" OR IsNumeric(Request.QueryString("pg")) = False Then
intPage = 1
Else
intPage = Int(CInt(Request.QueryString("pg")))
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("db/listmygames.mdb")
strSQL = "SELECT * FROM forum WHERE sektion=" & Request.QueryString("sektion") & " AND forums_typ='topic' ORDER BY nyaste_tid DESC"
'response.write strSQL
Set objRS = Server.CreateObject("ADODB.Recordset")
objRS.Open strSQL, objConn, 1, 3
With objRS
.AbsolutePage = intPage
.PageSize = 1
End With
If objRS.EOF Then
Response.Write("Det finns inga poster...</TABLE>")
Else
Do Until objRS.EOF OR intCount = objRS.PageSize
With Response
.Write "<TR>"
.Write "<TD HEIGHT=""40"" BGCOLOR=""" & color7 & """ ALIGN=""center""><IMG SRC=""bilder/icoTOPIC.gif""></TD>"
.Write "<TD HEIGHT=""40"" BGCOLOR=""" & color7 & """><FONT SIZE=""1""><IMG SRC=""bilder/inv.gif""> <A HREF=""forum.asp?sektion=" & Request.QueryString("sektion") & "&topic=" & objRs("ID") & """>" & addforum(objRs("titel")) & "</A></TD>"
.Write "<TD HEIGHT=""40"" BGCOLOR=""" & color7 & """><FONT SIZE=""1""><IMG SRC=""bilder/inv.gif""> <A HREF=""profil.asp?anv_namn=" & objRs("skapad_anv") & """>" & objRs("skapad_anv") & "</A></TD>"
.Write "<TD HEIGHT=""40"" BGCOLOR=""" & color7 & """ ALIGN=""center""><FONT SIZE=""1""> " & objRs("svar") & "</TD>"
.Write "<TD HEIGHT=""40"" BGCOLOR=""" & color7 & """ ALIGN=""center""><FONT SIZE=""1""> " & objRs("besok") & "</TD>"
tid = Left(Right(objRs("nyaste_tid"),8),5)
datum = Left(objRs("nyaste_tid"),10)
manad = MonthName(Month(datum))
manad = Left(manad, 3)
manad = Ucase(Left(manad, 1)) & Right(manad,2) & "."
dag = Day(datum)
datum = dag & " " & manad & " " & tid
.Write "<TD HEIGHT=""40"" BGCOLOR=""" & color7 & """ ALIGN=""right""><FONT SIZE=""1""> " & datum & " <IMG SRC=""bilder/inv.gif""><BR><A HREF=""profil.asp?anv_namn=" & objRs("nyaste_anv") & """>" & objRs("nyaste_anv") & "</A> <IMG SRC=""bilder/inv.gif""></TD>"
.Write "</TR>"
End With
objRS.MoveNext
intCount = intCount + 1
Loop
Response.Write "</TABLE><P>"
If objRS.PageCount > 1 Then
If intPage > 1 Then
Response.Write("<a href=""forum.asp?sektion=" & Request.QueryString("sektion") & "&pg=1""><<</a> ")
Response.Write("<a href=""forum.asp?sektion=" & Request.QueryString("sektion") & "&pg=" & intPage - 1 & """><</a> ")
Else
Response.Write("<< ")
Response.Write("< ")
For i = 1 To objRS.PageCount
If i <> intPage Then
Response.Write("<a href=""forum.asp?sektion=" & Request.QueryString("sektion") & "&pg=" & i & """>" & i & "</a> ")
Else
Response.Write(i & " ")
Next
If intPage < objRS.PageCount Then
Response.Write("<a href=""forum.asp?sektion=" & Request.QueryString("sektion") & "&pg=" & intPage + 1 & """>></a> ")
Response.Write("<a href=""forum.asp?sektion=" & Request.QueryString("sektion") & "&pg=" & objRS.PageCount & """>>></a> ")
Else
Response.Write("> ")
Response.Write(">> ")
objRS.Close : Set objRS = Nothing
objConn.Close : Set objConn = Nothing
Satte pagesize till 1 eftersom jag ville testa om det funka (har bara 3 posts i databas). Men nu kommer det fina problemet...
När jag trycker på 2 (Nästa sida) så kommer jag till forum.asp och där säger den att det inte finns några poster... Vad kan vara fel?? Tack på förhand :)
