Kodar för fulla muggar men inget funkar
8 svar · 275 visningar · startad av Hallgren
Medlem sedan dec. 19991 606 inlägg
Kan inte de här fungera?
<%Session.LCID = 1053%>
<html>
<title></title>
Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=d:\inetpub\wwwroot\rhodos\info.mdb"
set rs = Connect.execute ("SELECT * FROM veckans")
Do until rs.EOF
<% dag = weekdayname(weekday(date)) %>
Select Case dag
  Case "Sunday"
   	dag = "response.write "<b>" & "Söndag: " & "<br>" & "Ingen veckans"
  Case "Monday"
    	dag = "response.write "<b>" & "Måndag: " & "<br" & rs("man1")"
  Case "Tuesday"
    	dag = "response.write "<b>" & "Tisdag: " & "<br" & rs("tis1")"
  Case "Wednesday"
    	dag = "response.write "<b>" & "Onsdag: " & "<br" & rs("ons1")"
  Case "Tuesday"
    	dag = "response.write "<b>" & "Torsdag: " & "<br" & rs("tor1")"
  Case "Friday"
    	dag = "response.write "<b>" & "Fredag: " & "<br" & rs("fre1")"
  Case "Saturday"
    	dag = "response.write "<b>" & "Lördag: " & "<br>" & "Ingen veckans"
End Select
rs.MoveNext
loop
rs.close
Connect.close
set Connect=nothing
<body>
<%=dag%>
</html>
Forumledare, webForum
[Redigerat av Hallgren den 18 aug 2001]
nej, det där kan inte funka.
dag = "<b>" & "Lördag: " & "<br>" & "Ingen veckans"
response.write dag
can i borrow your goat?
[Redigerat av @nders den 18 aug 2001]
Uh?
Do until rs.EOF
<%dag = weekdayname(weekday(date))%>
Select Case dag
  Case "Sunday"
   	dag =  "<b>" & "Söndag: " & "<br>" & "Ingen veckans"
  Case "Monday"
    	dag =  "<b>" & "Måndag: " & "<br" & rs("man1")"
  Case "Tuesday"
    	dag =  "<b>" & "Tisdag: " & "<br" & rs("tis1")"
  Case "Wednesday"
    	dag =  "<b>" & "Onsdag: " & "<br" & rs("ons1")"
  Case "Tuesday"
    	dag = "<b>" & "Torsdag: " & "<br" & rs("tor1")"
  Case "Friday"
    	dag = "<b>" & "Fredag: " & "<br" & rs("fre1")"
  Case "Saturday"
End Select
rs.MoveNext
loop
response.write dag
rs.close
Connect.close
set Connect=nothing
Expected statement
/rhodos/test.asp, line 15
du har ju massor med asp-avgränsare som är öppnade men inte avslutade.
sen återanvänder du variabeln dag utan att använda originaldefinitionen av den.
alltså:
Do until rs.EOF
[b]dag = weekdayname(weekday(date))[/b]
Select Case dag
Case "Sunday"
Case "Monday"
Case "Tuesday"
Case "Wednesday"
Case "Tuesday"
Case "Friday"
Case "Saturday"
End Select
rs.MoveNext
loop
response.write dag
rs.close
Connect.close
set Connect=nothing
den fetmarkerade raden gör du ingenting med, eftersom du direkt ger variabeln ett nytt värde.
Krävs väl för att allt ska fungera eller?
Do until rs.EOF
Select Case dag
Case "Sunday"
meny = "<b>" & "Söndag: " & "<br>" & "Ingen veckans"
Case "Monday"
meny = "<b>" & "Måndag: " & "<br" & rs("man1")"
Case "Tuesday"
meny = "<b>" & "Tisdag: " & "<br" & rs("tis1")"
Case "Wednesday"
meny = "<b>" & "Onsdag: " & "<br" & rs("ons1")"
Case "Tuesday"
meny = "<b>" & "Torsdag: " & "<br" & rs("tor1")"
Case "Friday"
meny = "<b>" & "Fredag: " & "<br" & rs("fre1")"
Case "Saturday"
meny = "<b>" & "Lördag: " & "<br>" & "Ingen veckans"
End Select
rs.MoveNext
loop
response.write meny
rs.close
Connect.close
set Connect=nothing
Unterminated string constant
/rhodos/test.asp, line 18, column 47
ta bort sista citationstecknet på varje rad där du ger meny sitt värde.
ehh, det var jag som var dum ihuvet. glöm det. :r :)
Do until rs.EOF
Select Case dag
Case "Sunday"
Case "Monday"
Case "Tuesday"
Case "Wednesday"
Case "Tuesday"
Case "Friday"
Case "Saturday"
meny = "<b>" & "Lördag: " & "<br>" & "Ingen veckan"
End Select
rs.MoveNext
loop
response.write meny
rs.close
Connect.close
set Connect=nothing
Efter ha tänkt till lite på mitt problem så valde jag att gå en annan väg. Det blev ett If-elseif-else skript som funkar jättebra. :)
Som vanligt kämpade du tappert @nders. Det kan inte vara enkelt att försöka förklara saker för mig eller hur?
har du någon som helst aning om vad du håller på med egentligen? :p
Det är frågan det! ;) :e :e :e
274 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
131 ms — deklarationer (db)
130 ms — ändringar (db)
