Hur får man bilden att sparas
17 svar · 463 visningar · startad av WebbisNet
Medlem sedan feb. 20032 027 inlägg
Har inte lyckats med att spara filen till disk och även in i databasen, nån som kan hjälpa???????
'Option Explicit
Dim objUpload
Dim strName
dim objFile
Dim objFile2
Dim varyErrors
Dim iErr
Dim blnErr
blnErr = False
Set objUpload = New overrUpload
	strName = objUpload("txtName")
	'Response.Write("Textfield txtName = " & strName)
	'## -- get the first file for upload --
	Set objFile = objUpload.Form("theFile")
		'## -- check if we have a file --
		If objFile.IsFile Then
			'## -- file exists. proceed saving file. --
			Call objFile.SaveToFile(Server.MapPath("/images/gallery/" & objFile.Filename), True)
			'## -- check if any errors occured --
			If objFile.HasErrors Then
				blnErr = True
				'## -- HUSTON! we got errors. proceed --
				'## -- get all error messages --
				varyErrors = objFile.GetErrors()
				'## -- loop through all errors --
				For iErr = 0 TO UBound(varyErrors)
					'## -- print out error --
					Response.Write(varyErrors(iErr) & "<hr>")
				Next
	Set objFile = Nothing
	'## -- get second file for upload --
	Set objFile2 = objUpload.Form("anotherFile")
		If objFile2.IsFile Then
			Call objFile2.SaveToFile(Server.MapPath("/images/gallery/" & objFile2.Filename), True)
			If objFile2.HasErrors Then
				blnErr = True
				varyErrors = objFile2.GetErrors()
				Next
	Set objFile2 = Nothing
Set objUpload = Nothing
Dim objConn
varTillhor= Session ("userID")
varInlagd = Now()
varNamn=strName
	SET objConn = connect()
	picture = "INSERT INTO tblUsers_Galleri"
	picture = picture & "(bild,tillhor,inlagd,alt) "
	picture = picture & "VALUES(objFile.Filename,"& varTillhor &",#"& varInlagd&"#,"& varNamn &")"
	'objConn.Execute picture
response.write picture
<!--#include virtual="/pictureupload/upload1.asp"-->
<%'## -- check if we have any errors. If no errors redirect user to default page --
If blnErr = False Then Response.Redirect("/pictureupload/default1.asp")
ingenting händer efter uppladdning
Samma felmess som sist?
Jag skulle tippa, fast jag har haft en ganska hög felprocent på sista tiden ;) , att du får fel pga du har stängt ditt objekt, objFile, fast du försöker sen använda det.
Om du inte ens har lyckats spara filen till disk, får du felmess?
Finns mappen /images/gallery/?
Du ser ut att utgå från roten där.
Mappen finns och först fick jag felmess, object required....men nu bara kommer jag tillbaka till uppladdningssidan utan att nåt har sparats eller laddats upp
Kommentera bort raden med Response.Redirect och se vad du får för felmess samt sql-utskrift
INSERT INTO tblUsers_Galleri(bild,tillhor,inlagd,alt) VALUES(objFile.Filename,1,#2004-08-31 00:13:16#,test) när jag skriver ut
När jag ändrar objFile.Filename till '"&objFile.Filename&"' får jag
Microsoft VBScript runtime error '800a01a8'
Object required
/pictureupload/outputfile1.asp, line 74
För enkelhetens skull, testa att flytta ner raden:
till längst ner på sidan.
INSERT INTO tblUsers_Galleri(bild,tillhor,inlagd,alt) VALUES(Blåa kullar.jpg,1,#2004-08-31 00:21:47#,test)
och
Microsoft JET Database Engine error '80040e14'
Syntax error (missing operator) in query expression 'Blåa kullar.jpg'.
/pictureupload/outputfile1.asp, line 75
när jag exekverar
Rad 75 är objConn.Execute picture
picture = picture & "VALUES('"& objFile.Filename & "',"& varTillhor &",#"& varInlagd&"#,'"& varNamn &"')"
Nu kan du minska din felprocent, tack så jättemycket
Alla strängar abc_-"%eD?...osv skall omslutas av ' (enkelfnuttar)
några filer gick fint, nu får jag
Request object error 'ASP 0104 : 80004005'
Operation not Allowed
/pictureupload/upload1.asp, line 145 ERROR: Couldn´t find the form-field - txtname - in the collection.
txtname, har du ett fält som heter så i din form? Eller försöker du använda dig av det?
Koden på oh runt rad nr 145?
ett fält som heter txtName måste finnas enligt skaparen av scriptet för att slippa nåt fel
Kodrad 135-155
	Dim UploadControl	'## -- replace with array --
		Dim pos				' As Integer
		Dim Name			'## -- remove. save to array --
		Dim posFile			' As Integer
		Dim posBound		' As Integer
		Dim Value			'## -- remove. save to array --
		Dim Filename		'## -- remove. save to array --
		Dim ContentType		'## -- remove. save to array --
		ByteCount = Request.TotalBytes
		RequestBin = Request.BinaryRead(byteCount)
			'# Begin boundary
			PosBeg = 1
			'PosEnd = InstrB(PosBeg, RequestBin, getByteString(chr(13)))
			PosEnd = InstrB(PosBeg, RequestBin, GetBytesFromString(chr(13)))
			boundary = MidB(RequestBin, PosBeg, PosEnd - PosBeg)
			boundaryPos = InstrB(1, RequestBin, boundary)
			'Get all data inside the boundaries
			Do until (boundaryPos = InstrB(RequestBin, boundary & GetBytesFromString("--")))
				'Members variable of objects are put in a dictionary object
Hm... det där förstår jag inte riktigt, källa?
scriptet kommer från Override
Jo, och du har verkligen det fältet med i din form som du skickar till scriptet?
Du har inte bytt namn på det eller något?
Red,/ skriver som en trött mupp.
<form action="/pictureupload/outputfile1.asp" method="post" enctype="multipart/form-data" name="form1">
Bild 1 <input class="textbox" name="theFile" type="file" id="theFile">
<p>
<!--Bild 2 <input class="textbox" name="anotherFile" type="file" id="anotherFile">-->
<p>
<!--Other field:-->
<input name="txtName" type="text" id="txtName" value="test"><br>
<input class="button" type="submit" name="Submit" value="Skicka fil">
Varför får jag
/pictureupload/gallery/outputfile.asp, line 10
med raden RequestBin = Request.BinaryRead(byteCount)
hoppas att nån kan lösa problemet
filerna ligger på Http://www.webbisen.com/download/gallery.zip
264 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
128 ms — deklarationer (db)
131 ms — ändringar (db)
