Ombyggnad till aspUpload
0 svar · 198 visningar · startad av Asa
Medlem sedan dec. 20011 860 inlägg
Någon som kan hjälpa mig bygga om detta till aspupload?
<!--#Include file="function.asp"-->
<%byteCount = Request.TotalBytes
RequestBin = Request.BinaryRead(byteCount)
Set UploadRequest = CreateObject("Scripting.Dictionary")
BuildUploadRequest RequestBin
contentType   = UploadRequest.Item("fil").Item("ContentType")
filepathname  = UploadRequest.Item("fil").Item("FileName")
filename      = Right(filepathname,Len(filepathname)-InstrRev(filepathname,"\"))
value         = UploadRequest.Item("fil").Item("Value")
pdf           = "pdf/" & filename
' hämtar filextension
extension = right(pdf,len(pdf) - instr(pdf,".") +1)
Filen = "pdf_" & Request.Querystring("id")
' bygger ihop det nya filnamnet
newfilename = Filen & extension
Make_upload = False
Filetype           = lCase(right(Filename, len(Filename)-instrRev(Filename,".")))
Select Case Filetype
  Case "pdf"
    Make_upload = True
End Select
If Make_upload = True Then
  Set ScriptObject = Server.CreateObject("Scripting.FileSystemObject")
  pathEnd = Len(Server.mappath(Request.ServerVariables("PATH_INFO")))-14
  Set MyFile = ScriptObject.CreateTextFile(Server.mappath("../pdf/"& newfilename))
  For i = 1 to LenB(value)
     MyFile.Write chr(AscB(MidB(value,i,1)))
  Next
  MyFile.Close
  Conn.execute("Update artiklar Set pdf1='pdf/" & newfilename & "'  Where id = "& Request.Querystring("id"))
  Response.Redirect "admin.asp?do=inne"
Else
End If%>
282 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
149 ms — deklarationer (db)
146 ms — ändringar (db)
