Hej !
Jag har gjort ett skript som plockar ut alla kolumnrubriker ur min databas. Sedan loopar jag in informationen i en array. Det smäller dock då loopen loopar en extra gång efter det att sista posten har passerats. Varför blir det så? Hur kommer jag runt detta?
<!--- Hämtar alla rubriker --->
<% sql_question = "SELECT * FROM T_inventory "
'response.write sql_question
set rsLabelNames = Connect.Execute(sql_question)
if rsLabelNames.eof then
response.write "<hr> No data found <hr>"
dim myArray(200) ' Sätter länden på arrayen till antalet kolumner
x = 0
while not rsLabelNames.eof %>
<i><%=x%>)</i> <%=rsLabelNames.fields(x).name%><br>
<% myArray(x) = rsLabelNames.fields(x).name %>
<% rsLabelNames.movenext %>
<% x = x +1
wend
end if %>
- ID
- status_id
- location
- history
- last_leased_by
- leased_by
- leased_date
- return_date
- network_name
- department_id
- info_last_updated_date
- info_last_verified_by
- info_last_verified_date
- detail_1
- detail_2
- detail_3
- detail_4
- detail_5
- detail_6
- detail_7
- detail_8
- detail_9
- detail_10
- manufacturer
- model
- serialnumber
- service_tag
- purchased_date
- purchased_from
- order_number
- warranty_number
- warranty_time
- office_id
- category_id
- workstation_pc
- used_as_text
Det smäller alltså på rad 36 då den inte existerar.
ADODB.Recordset error '800a0cc1'
Item cannot be found in the collection corresponding to the requested name or ordinal.
/tab_offices/off_uppsala/itjour/cid2/options/define_list_look.asp, line 56
