Jag skickar upp koden här så får ni se...
Response.Expires=0
Response.Buffer = TRUE
Response.Clear
byteCount = Request.TotalBytes
RequestBin = Request.BinaryRead(byteCount)
Dim UploadRequest
Set UploadRequest = CreateObject("Scripting.Dictionary")
BuildUploadRequest RequestBin
Function Createpass(arg)
Dim vPasswd, i
const vPasschars = "qwertyuipkjhgfdsazxcvbnm23456789QWERTYUPLKJHGFDSAZXCVBNM"
Randomize
For i = 1 To arg
vPasswd = vPasswd & mid ( vPasschars, Int(rnd*Len(vPasschars))+1, 1 )
Next
Createpass = vPasswd
End Function
Dim vPassword
vPassword = Createpass(5)
Dim u
u = 1
Password = vPassword
If UploadRequest.Item("homepage").Item("Value") = "" THEN
http = "http://"
Else
http = UploadRequest.Item("homepage").Item("Value")
If UploadRequest.Item("mobil").Item("Value") = "" THEN
mob = "07"
Else
mob = UploadRequest.Item("mobil").Item("Value")
namn = UploadRequest.Item("name").Item("Value")
email = UploadRequest.Item("email").Item("Value")
tfn = UploadRequest.Item("tfn").Item("Value")
typ = UploadRequest.Item("type").Item("Value")
category = UploadRequest.Item("category").Item("Value")
subject = UploadRequest.Item("subject").Item("Value")
Response.Write namn & "<br>" & email
body = UploadRequest.Item("body").Item("Value")
body = REPLACE(body,vbCrLf,"<br>")
tid = Now
datum = Now
lan = UploadRequest.Item("lan").Item("Value")
pris = UploadRequest.Item("pris").Item("Value")
password = password
intevisa = UploadRequest.Item("notfn").Item("Value")
homepage = http
mobil = mob
ursprung = u
klick = 0
expo = UploadRequest.Item("expo").Item("Value")
betal = UploadRequest.Item("betalkod").Item("Value")
contentType = UploadRequest.Item("fil").Item("ContentType")
filepathname = UploadRequest.Item("fil").Item("FileName")
filename = Right(filepathname,Len(filepathname)-InstrRev(filepathname,"\"))
value = UploadRequest.Item("fil").Item("Value")
Bild = filename
' hämtar filextension
extension = right(Bild,len(Bild) - instr(Bild,".") +1)
' bygger ihop det nya filnamnet
newfilename = password & extension
Make_upload = False
Filetype = lCase(right(Filename, len(Filename)-instrRev(Filename,".")))
Select Case Filetype
Case "jpeg"
Make_upload = True
Case "jpg"
Make_upload = True
Case "png"
Make_upload = True
Case "gif"
Make_upload = True
End Select
If Make_upload = True Then
If (byteCount / 1000) > 70 then
Response.Redirect "add.asp?mess=Filen för stor! Max 70 kb. Denna bild var " & Round(byteCount/1000,1) & " kb"
Else
Set ScriptObject = Server.CreateObject("Scripting.FileSystemObject")
pathEnd = Len(Server.mappath(Request.ServerVariables("PATH_INFO")))-14
Set MyFile = ScriptObject.CreateTextFile(Server.mappath("adimages/" & newfilename))
For i = 1 to LenB(value)
MyFile.Write chr(AscB(MidB(value,i,1)))
Next
MyFile.Close
OpenDatabase
SQL = "INSERT INTO annonser "
SQL = SQL & "(name,email,tfn,typ,category,subject,body,date,time,lan,homepage,pris,password,intevisa,klick,mobil,ursprung,godkann,expo,betal,expokod,betalkod,file1)"
SQL = SQL & "Values('" & namn & "','" & email & "','" & tfn & "','" & typ & "','" & category & "','" & subject & "','" & body & "','" & datum & "','" & tid & "','" & lan & "','" & homepage & "','" & pris & "','" & password & "','" & intevisa & "','" & klick & "','" & mobil & "','" & ursprung & "','no','" & expo & "','" & betal & "','" & expokod & "','" & betalkod & "','" & newfilename & "')"
Connect.execute(SQL)
Sub BuildUploadRequest(RequestBin)
PosBeg = 1
PosEnd = InstrB(PosBeg,RequestBin,getByteString(chr(13)))
'boundary = MidB(RequestBin,PosBeg,PosEnd-PosBeg)
boundaryPos = InstrB(1,RequestBin,boundary)
Do until (boundaryPos=InstrB(RequestBin,boundary & getByteString("--")))
Dim UploadControl
Set UploadControl = CreateObject("Scripting.Dictionary")
Pos = InstrB(BoundaryPos,RequestBin,getByteString("Content-Disposition"))
Pos = InstrB(Pos,RequestBin,getByteString("name="))
PosBeg = Pos+6
PosEnd = InstrB(PosBeg,RequestBin,getByteString(chr(34)))
Name = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
PosFile = InstrB(BoundaryPos,RequestBin,getByteString("filename="))
PosBound = InstrB(PosEnd,RequestBin,boundary)
If PosFile<>0 AND (PosFile<PosBound) Then
PosBeg = PosFile + 10
FileName = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
UploadControl.Add "FileName", FileName
Pos = InstrB(PosEnd,RequestBin,getByteString("Content-Type:"))
PosBeg = Pos+14
ContentType = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
UploadControl.Add "ContentType",ContentType
PosBeg = PosEnd+4
PosEnd = InstrB(PosBeg,RequestBin,boundary)-2
Value = MidB(RequestBin,PosBeg,PosEnd-PosBeg)
Else
Pos = InstrB(Pos,RequestBin,getByteString(chr(13)))
PosBeg = Pos+4
Value = getString(MidB(RequestBin,PosBeg,PosEnd-PosBeg))
UploadControl.Add "Value" , Value
UploadRequest.Add name, UploadControl
BoundaryPos=InstrB(BoundaryPos+LenB(boundary),RequestBin,boundary)
Loop
End Sub
Function getByteString(StringStr)
For i = 1 to Len(StringStr)
char = Mid(StringStr,i,1)
getByteString = getByteString & chrB(AscB(char))
Next
End Function
Function getString(StringBin)
getString =""
For intCount = 1 to LenB(StringBin)
getString = getString & chr(AscB(MidB(StringBin,intCount,1)))
Next
End Function
Else
Response.Redirect "upload.asp?bildid=" & Request.Querystring("bildid") & "&id=" & Request.Querystring("id") & " &mess=Filen var med fel filformat. Endast .jpg, .jpeg, .gif och .png tillåtna."
